Samsung ln46a550p3f solarized screen problem
  • stock2009
    • Jun 2017
    • 19
    • usa
    This 46 inch TV recently started giving me problems. It happened few weeks after a move, so not sure if something broke during the move.
    Model: LN46A550P3F
    Model code: LN46A550P3FXZA
    The bright areas on the screen seem to be solarized. Dark areas seem fine. Images below.
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Samsung ln46a550p3f solarized screen problem
    open the back up and check your gamma voltages, if it fails gamma test, then it will most likely be a failed as15 chip on the t-con board.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • stock2009
      • Jun 2017
      • 19
      • usa
      Thanks. I am new to these things. Will go real slow with the process so i don't mess up. I want to try to fix it myself.
      I should be easy to figure out where t-con board is. will have to see how to check gamma voltages. If there's some quick tutorial, please guide me to it too. Thanks again.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        open up the back and take a pic and one of us will guide you in the right direction.
        it is normally in either a central top or bottom position, under a shield. it is the one that the main leads to before the signal enters the panel.
        • stock2009
          • Jun 2017
          • 19
          • usa
          Great. Thanks ! soon will add pics of it.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            i would fire freeze spray at the above mention chip and see what happens . if it temporarily cures the fault it needs a new chip .
            freezing it might do nothing but it did on the one i fixed last . that chip was getting very hot to the touch .
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Yes this definitely looks like a T-CON Bd issue....Cool the AS15 Chip on the T-CON and see what happens.
              • maxvalutech
                • 804
                • australia
                Due to the move I would reset all cables and screen connections before getting too deeply into other fixes. Ribbon cables etc are often held down with tape and can come loose adding strain to connections.
                • CapLeaker
                  Leaking Member
                  • 8119
                  right on!
                  • stock2009
                    • Jun 2017
                    • 19
                    • usa
                    I finally got time to open up the TV. Here is the pic of the t-con board.
                    https://postimg.org/image/rum7fsnlx/
                    https://postimg.org/image/e27sk5wud/
                    • stock2009
                      • Jun 2017
                      • 19
                      • usa
                      Sure. This should be the quickest thing to try. Doing that now.
                      • neilc6
                        • Nov 2015
                        • 1550
                        I think I have seen 3 TV's of this model with bad tcons. You should be able to find a replacement tcon on ebay for around $30USD. Much easier to replace the tcon than replacing the AS15 chip.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          If you want to list your gamma voltages 1~18 in order we can check them. They are readily accessible between to ribbon cables. Be sure to ground your board first
                          • stock2009
                            • Jun 2017
                            • 19
                            • usa
                            Thanks. Will find one and replace. $30 is reasonable. That will be the easiest thing to do.
                            Do I have to get a t-con board for the same exact model and size? what t-con board should I search for?
                            will list these as well, if it's something easy to do.
                              go to shopjimmy.com and search for board assembly # as printed on the bar code sticker.
                              The V520H1-C6 as printed on the board is the blank board P/N which can be stuffed with parts to make various T-CON PCB assemblies.
                              Your TV uses CHI-MEI LCD panel. You should look for the sticker for the LCD Model number too.
                              • stock2009
                                • Jun 2017
                                • 19
                                • usa
                                Looks like this is the t-con board
                                http://www.shopjimmy.com/cmo-35-d025860-t-con-board.htm
                                Part Number (From barcode): 35-D025860
                                Board number: V520H1-C06
                                This numbers above should be enough to get the exact board I assume.
                                • stock2009
                                  • Jun 2017
                                  • 19
                                  • usa
                                  I see AS19 chip on middle right. Is that the one?
                                  Should I buy some special cooling spray, or just compressed air can should work?
                                  (Second image below shows the blown up image of the red marked area)
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Yes, it''s the AS19. If you don't have any, I personally wouldn't waste your money on freeze spray, it's only a quick way to sometimes check the fault, it may or may not affect the AS19 ic. Better to spend your money on tools/replacement parts or getting your tcon repaired.
                                    The quickest way is to measure the gamma voltages as detailed above although I just swap the AS chips if ever I see solarisation.
                                    • neilc6
                                      • Nov 2015
                                      • 1550
                                      Though it's not the official pat number, search "v520h1-c06" on eBay and you will find the part.
                                        That is blank PCB p/n, not the stuffed board P/N, that blank board has to be stuffed with correct parts for the particular LCD screen model number so do not go by the blank PCB number, you have to go by PCBA numbers as printed on the bar code sticker.
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
