LG 42LV5400 panel failure or internal board?
  • johnboy1313
    • Nov 2012
    • 1959
    My gut tells me panel failure. The menu shows the same condition.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: LG 42LV5400 panel failure or internal board?
    I can only post one pic at a time from my phone.
    • johnboy1313
      • Nov 2012
      • 1959
      Another pic
      • dskall
        • Oct 2016
        • 2905
        • usa
        Only a guess for me but don't think it is panel. Lines look like they go across full screen. Usually panel is only on part of the screen.
        • diif
          • Feb 2014
          • 6978
          • England
          As it's an LV i'd suspect it's the BGA on the mainboard.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            i'll put a vote in for main board. looks too even to be panel to me, but it is only my guess.
            you will always be able to isolate it a bit more by disconnecting one side of the t-con and see if the fault changes at all.
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • dhavalrpatil
              • Feb 2017
              • 11
              • india
              check lvds cable...reinsert it or apply wd40 to both connectors..this will fix this problem.if not then motherboard is suspect
              • mu2
                • Oct 2009
                • 217
                Your symptom looks a little like the issue I had with a 42LV5500.
                Here is my post.
                https://www.badcaps.net/forum/showth...light=42lv5500
                I didn't believe that baking the main board in the oven would fix the problem but the tv is working for well over 1 year.
                Good luck - I bet it's a main board issue.
                Mike
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I'll try to reflow the processor and see if it makes any difference. Thanks guys.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Just reheated a LV5500 on the BGA, came back to life. I'll vote mainboard, main processor
                    • rccrasher65
                      • Mar 2014
                      • 622
                      +1 did a few of these.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Well, seems like that's what it was. A shame this thing doesn't have Wifi. Would any USB wifi dongle work or does it have to be an LG branded one?
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Firestick should work.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Roku
                            • Chungalin
                              • Jul 2014
                              • 422
                              • Spain
                              (deleted, my mistake)
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
                              • delpiero3
                                Sony Vaio SVS MBX-261 board failure
                                by delpiero3
                                Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                Nevertheless, let's say, i don't come as a total beginner.
                                I have this old laptop, which suit perfectly my needs, with the...
                                10-29-2024, 06:16 AM
