LG 42LV5400 panel failure or internal board?
  • johnboy1313
    • Nov 2012
    • 1959
    My gut tells me panel failure. The menu shows the same condition.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: LG 42LV5400 panel failure or internal board?
    I can only post one pic at a time from my phone.
    • johnboy1313
      • Nov 2012
      • 1959
      Another pic
      • dskall
        • Oct 2016
        • 2905
        • usa
        Only a guess for me but don't think it is panel. Lines look like they go across full screen. Usually panel is only on part of the screen.
        • diif
          • Feb 2014
          • 6978
          • England
          As it's an LV i'd suspect it's the BGA on the mainboard.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            i'll put a vote in for main board. looks too even to be panel to me, but it is only my guess.
            you will always be able to isolate it a bit more by disconnecting one side of the t-con and see if the fault changes at all.
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • dhavalrpatil
              • Feb 2017
              • 11
              • india
              check lvds cable...reinsert it or apply wd40 to both connectors..this will fix this problem.if not then motherboard is suspect
              • mu2
                • Oct 2009
                • 217
                Your symptom looks a little like the issue I had with a 42LV5500.
                Here is my post.
                https://www.badcaps.net/forum/showth...light=42lv5500
                I didn't believe that baking the main board in the oven would fix the problem but the tv is working for well over 1 year.
                Good luck - I bet it's a main board issue.
                Mike
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I'll try to reflow the processor and see if it makes any difference. Thanks guys.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Just reheated a LV5500 on the BGA, came back to life. I'll vote mainboard, main processor
                    • rccrasher65
                      • Mar 2014
                      • 619
                      +1 did a few of these.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Well, seems like that's what it was. A shame this thing doesn't have Wifi. Would any USB wifi dongle work or does it have to be an LG branded one?
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Firestick should work.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Roku
                            • Chungalin
                              • Jul 2014
                              • 422
                              • Spain
                              (deleted, my mistake)
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
                              • delpiero3
                                Sony Vaio SVS MBX-261 board failure
                                by delpiero3
                                Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                Nevertheless, let's say, i don't come as a total beginner.
                                I have this old laptop, which suit perfectly my needs, with the...
                                10-29-2024, 06:16 AM
                                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                by sam_sam_sam
                                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                Found shorted diodes on main controller relays there are 3 of them that...
                                01-07-2023, 05:43 PM
