All my Panasonic tv's will not connect to wifi the see the router.the just won't connect.They were working fine just suddenly stop working.I can use Ethernet cable and it will work just not through wifi.Any ideas what I can check.
Panasonic tv will not connect to internet
Re: Panasonic tv will not connect to internet
If the device has custom IP settings try enabling DHCP or allocating it a static IP you know to be free.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by AquaMan UaHello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....2 Photos -
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπ€?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting π.
...1 Photo11-20-2024, 08:52 PM -
by KYBOSHI picked this one up today.
Previous owner says no signs of life.
TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
The TV model is QN65LS03BAFXZA - version: CB06
The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
Will keep you all... -
by An-klammHello!
I have a TV that I can't get any further with.
It is a Samsung UE 55HU8590 with one connect box.
When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
Since the TV works without ocb, I assume that it can't be the PSU?!
I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
Is there... -
by EazyBoneI got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small... - Loading...
