Eeprom dump thread!
This is a sticky topic.
  • salmad
    • May 2014
    • 8
    • maroc
    #461
    Re: Eeprom dump thread!
    Originally posted by salmad
    Hi someone have dump for Hisense 32h3e Main .Tp.ms3393.pb851
    pleas help i need this dump
    https://***********/threads/devant-3...3-pb851.35301/
    • salmad
      • May 2014
      • 8
      • maroc
      #462
      • salmad
        • May 2014
        • 8
        • maroc
        #463
        • meandyou123
          • Feb 2019
          • England
          #464
          Originally posted by dani502017
          After if its ok go to Copy Pattern profile for MB95M
          Here the procedure is a bit more complex, so will be created two folders
          1.downloadprofile.mb95 - responsible tuner, audio, subtitle
          2.downloadpq.mb95 - panel responsible (display)
          The operation is the same as the FAT32 stick, make the two folders with the above names, insert the stick into the TV, go into service with the MENU 4725 and the "USB OPERATION" option is ok from the remote control.
          After upload here the file,will then help repair
          Hello again,
          I finally got the TV to switch on but screen is scrambled & upside down,
          I have downloaded the files you requested as follows,
          Thank you
          • macrochip
            • Feb 2013
            • Italy
            #465
            I'm looking for two Eeprom dump for Q.Bell TV .
            MARQUE : Q.Bell led tv
            MAINBOARD: T.MSD309.B63B
            MEMORY: 25Q32
            PANEL: M185BGE - L23
            and
            MEMORY: 25Q32
            PANEL: LM215WF4 (TL)(G1)
            • Rajnhl
              • Oct 2018
              • 94
              • India
              #466
              MEMORY: 25Q32
              and
              MEMORY: 25Q32
              i have 3 files of this board but panel no. are different 1 is unknown and 2 are 1920x1080 res.
              if you need i will upload
              • Rajnhl
                • Oct 2018
                • 94
                • India
                #467
                Croma_CREL73151
                panel K320WD3
                board 4715-MV59T9-A2233K11
                • salmad
                  • May 2014
                  • 8
                  • maroc
                  #468
                  plaise help
                  • ajay shah
                    • Mar 2019
                    • nepal
                    #469
                    hi all,
                    we have lg=32lh604v .we want 1367*768 resolation file .
                    any one help me?
                    • amin limam
                      • Feb 2019
                      • 8
                      • morocco
                      #470
                      hi ; i need dump lg 50pn450b
                      eax65071308 (1.2)
                      pdp50t50010
                      lge pdp 130613 .
                      thanks...
                      • apokalipto
                        • May 2011
                        • 4
                        #471
                        plaise help
                        this model 32d37 have similar mainboard (pb851)
                        • salmad
                          • May 2014
                          • 8
                          • maroc
                          #472
                          Thank you my friend 10/10
                          • icefire
                            • Mar 2019
                            • 11
                            • Bulgaria
                            #473
                            Hello, does anyone have a dump for Samsung C6000 series?
                            TV Model: UE40C6000RWXXH
                            Mainboard: BN41-01444B / BN94-03611S
                            Chips are:
                            IC7301 4256BRP
                            IC4002 S24CS0
                            Thanks..
                            • pocketwatch62
                              • 74
                              • US
                              #474
                              Hi All
                              Does anyone have the dump for a COBY TFTV4028
                              Main Board---002-FV40-2812-00R
                              Panel---T400HW03 V.2
                              • lazevedo
                                • Apr 2019
                                • 13
                                • Portugal
                                #475
                                Hello
                                I would really appreciate if someone could share dumps for a SONY KDL-32BX400
                                Main Board :A-1738-304C.
                                Thanks in advance
                                • Moulay
                                  • Apr 2019
                                  • Morroco
                                  #476
                                  SALUT tt mes freres je cherche dump de tv LG 19 LP68A
                                  • Shane711
                                    • 493
                                    Is there a way to prevent the Eeprom from going bad? I am guessing they do not over heat so what is the cause other than static or a power surge?
                                    • jorpec
                                      • Feb 2015
                                      • 32
                                      • Portugal
                                      #478
                                      Hello
                                      I really appreciate if any member could share a dump for a TV LED Blaupunkt 39/401l, or some other brand that uses the same mainboard/panel combo
                                      Modelo Nr: 39/401L-GB-5B-1HUHBKUP-EU
                                      Modelo Ref: B39A401TCUHD
                                      Mainboard: TP.MSD309.BTU87
                                      Panel: v390DK1-LS1
                                      Thanks in advance
                                      • diuna2000
                                        • Dec 2015
                                        • 9
                                        • Irlandia
                                        #479
                                        Originally posted by Hamie
                                        17mb82s
                                        PANEL: VES490UNDL-2D-NO1
                                        both U10 and U12 flash.
                                        tested and working.
                                        U10 - 25Q16DV
                                        U12 - 25Q64FV
                                        Hi All
                                        I have hardware like above i reflashed u10 and u12. tv turned on but my screen is upside down and blurred any suggestions
                                        • Rajnhl
                                          • Oct 2018
                                          • 94
                                          • India
                                          #480
                                          Originally posted by diuna2000
                                          Hi All
                                          this is 49 inch dump you can try
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
