Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    HV490QUB-B05
    DUMP PLS.
      Hi, if possible, I need a Dumb Dump. Please help, my group. Thank you. A new screen is not necessary for you to work. Thank you
      dell-se2216h-monitor
        Originally posted by skyx View Post
        Thank you very much .. but for Philips 17MB82 file (panel)?
        What is VES code?
        https://www.badcaps.net
          Hello all,
          Does anyone have a dump for a Element?
          Model----ELEFW248
          serial #----F75BM
          MAIN BOARD--- TP.MS3553.PA671------------ELEFW248 F7B5M Main---H17051233
          UF1 on the board.
          THANKS
            hi someone have a firmware for a SANSUI tvc2510
              Please can anyone help, i need serial flash (25Q32FVSIG) for technika
              model 22E21B-FHD
              board T.MSD306.80
              panel M215HGE-L21
                I have a plasma which the standby led is in red without response, the model LG 42PN4500-UA I need the dump of the 8mb spi if someone could provide it. These are the photos of the pcbs with their respective modelsD
                  good presiso of firmware for tv
                  Blaupunkt "32" B32A173TCFHD - Mainboard t.msd309.9B 10345 could someone help me
                    Model: Crown ALCD1509SGB
                    MainBoard: B.SPC81B-1 9245
                    Screen: LP156WH1-TLA1
                    Model: Grundig 22VLE4520BF
                    MainBoard: VTY190R-23
                    Screen: T215HVN01
                      Toshiba_32PT200ZE DUMP
                      PANEL LTA320HN03
                      TCON DUMP included
                        Blaupunkt "32" REF: B32A173TCFHD -
                        Model code: 32 / 173I-GB-5B-FHBKU-EU
                        Customer code: BA320173BFBKUE340
                        could someone help me turn on the led but it turns red
                          model number is different but board is same.backup before flashing.
                          if it starts and turn off immediately check power supply for bad capacitors.
                            Hi!
                            Can you send me this firmware? Download link does not work
                            Thanks!
                            Originally posted by cheeky2 View Post
                            Just had a Blaupunkt 43/134M-GB-11B-FEGUX-UK with main board TP.MS6486.PB711 and screen LC430DUY-SHA1
                            It required firmware which can be requested from here:
                            http://www.umc-poland.com/datasheet/...-11b-fegux-uk/
                            Use email to request it:
                            poland@blaupunkt-europe.com
                            Its 297MB in size so unable to upload here!
                            However looking at one of the files the 'UMC_KMODE.txt' contains details as to what is enabled ie PVR which is currently disabled so by changing these I have now enabled the PVR options on the TV. It works well now
                            Attached is the original file and modified one to enable the PVR options.
                            I would suggest if you wish to use the PVR that you use the 297MB file that UMC send you just substitute the 'UMC_KMODE.txt' file with the one in the modded folder.
                            The original and modded files are attached.
                            See attached pictures of PVR working
                              Anyone have a dump from a LG 32LH500B / LG 32LH520B ?
                                Originally posted by baluka3 View Post
                                Hi!
                                Thanks!
                                Why have I put the following here in the details???
                                Use a better web translator for translation to your language.
                                  Welcome to the EEPROM SE2216HV Main Board 790JW1300601R00
                                  Dell
                                  https://www.4shared.com/get/JS_pneAR...4_E2216HV.html
                                    Hi all
                                    I'm looking for firmware for a logic 46 inch lcd tv..stuck on standby
                                    Chassis number:Rsag7.820.2164
                                    Panel. :Lta460hm05
                                    Thanks in advance
                                      Hi anyone available
                                        Originally posted by Farasa View Post
                                        Hi anyone available
                                        There are 3 files try one by one.if you have any programmer try to read dump from your tv then write one of any file from my zip file.then again write your dump some time this helps.
                                          Finlux fl5031uswk chassis 17mb120
                                          Hell. This tv not work. the front led, flash one time when the tv is conected in ac and not work. i need the data for memory dump. the pael is ves500qndc-2d-n12.
