Samsung LE26r71b power supply issue. Any thoughts ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Greetings fellows, this is my first ever post here asking for help, so please don't be too rough on me if I mess anything up )
    So I've got this small Samsung TV (model LE26r71b) with a bad power supply. The power supply board is a BN96-03058a (the one in the first picture - hope you guys can see it). I've repaired several of these before and all of them had either bad caps (the irony), or the IC in the second picture gone bad (or, of course, a combination of both). The IC is a F9222L and it's a pretty obscure thing, as I couldn't find a detailed datasheet about it. I do know that's it basically two MOSFETs with a control IC built it. On all of the supplies where I've encountered this F922L so far, the problem was the classic flashing red light or a completely dead set (blown mains fuse due to one of the FETs in the F922L becoming shorted, sometimes taking out the mains rectifier with it).
    Replacing the F922L fixed the issue every time, however, the symptoms on this one are quite different: the set doesn't turn on (duuh), but the power light doesn't actually flash, it sort-of FLICKERS accompanied by a rhythmic whistling sound, indicating that the PSU is trying to power on but can't...strange.
    Taking some basic measurements showed that the 5VSb line is Ok....and that was about it, since applying those 5 volts to the ON/OFF pin produced the same result: whistling sound and no power to the 12V rails (inverter and main board were disconnected). I checked the diodes in the secondary side for shorts and they all reported fine. So did the KIA278R and the 33167t (both in the upper left of the board: the KIA is a 12v voltage regulator and, while not showing any shorts, I can't exactly check whether it's working or not, since the 12V rail doesn't show any sign of life (the transformer is not supplying anything to the secondary). The 33167t is a transistor and it's part of what I'd identify as a buck converter that produces the 5Vsb, so that's definitely working. Now my question is: could this defect be caused by the F922L ? It's a fairly expensive part, so I wouldn't want to get it and realize it's not that (TVs not mine btw). I know there's a whole lot of other parts that can go bad on a SMPS, but maybe someone else has had this particular issue before and can at least guide me. I must admit, I haven't fully checked the PFC section, so maybe you could give me some pointers there too. Sorry for the wall of text, but I wanted to give as much info as possible. Cheers
    Wattevah...
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung LE26r71b power supply issue. Any thoughts ?
    There's some info on a previous thread that could help you
    https://www.badcaps.net/forum/showth...ghlight=F9222L
    They put the fault down to the coupling capacitor C802 in the schematic shown on their page
      Can we get straight shot pictures of the bottom and top sides?
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        I'll post the pics tomorrow (I'm at home now and the board and camera are at work where the TV is being serviced). I'll have a look at your other ideas in the meantime.
        Wattevah...
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Pictures of BN96-03058A
          Here are the pics you asked for: top and bottom. Hope they're clear enough. I have already removed the F9222L from the board, so that's why it's missing.
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Posted the pics above, plus an update: I've replaced F9222L and still the same issue: flickering power LED and no 12v. Supply makes that ticking sound when I attempt to power it on. Big reservoir cap reads 324v with nothing connected to the board and the STBY pin floating (not connected to 5v standby).
            Wattevah...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              NEW UPDATE: upon shorting the power on/off pin to stby 5v, I was SOMEHOW able to fire up the board (got stable 12v on the rails). It took a few tries though, so it seems like there's a bad cap/joint somewhere - I suspect one of those red caps near the F9222L, as I read somewhere else that they caused issues in another supply using this IC.
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Will try replacing that and see what happens, since the circuit is pretty much the same, though the value of the cap is different.
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Forgot to ask: in the schematic you were so kind to provide, do the red boxes indicate which parts I should check/replace ?
                  Wattevah...
                  • CapLeaker
                    Leaking Member
                    • 8132
                    Check those little capacitors, specifically the ones that are near a heat sink.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      I'll start replacing caps tomorrow (I too immediately thought of heat damage, especially since the bloody things are always strategically placed near hot parts). Hopefully one of them will cause it to fire on. Again, I'm placing my hopes on that CM802. I've also talked to a guy today who's more tech-savvy than I am and he also suggested I'd check the 5 SMD resistors on the back (RP809 through RP813) that provide the feedback for the PFC, so I'll also do that as well. Another thing he suggested was applying 5V to the 5V stand-by pin of the main board to see whether the power LED still flickers or remains stable, to rule out the possibility of a bad main board, which would be a tremendous laugh after all this trouble I went through (not to mention money spent on parts - lesson learned: CHECK THE MAIN BOARD FIRST!) )
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Sadly I had to return this TV today (client didn't want to wait any longer and just said f-it). It's a shame, since I feel I was getting close. Even though it's pointless to carry on the discussion, let's at least theorize further to get some pointers for a possible future board like this, since I couldn't find the exact model anywhere on the forum and others may be facing a similar problem. So I made another discovery: I wanted to make sure it's not the main board to blame, so I powered it directly with a small 5V adapter on the 5VSb and sure enough, the red LED came on and remained stable, so that told me there's a problem with the 5v output of the supply as well ! I initially dismissed this idea, since I was reading 5v from the board, but that was with nothing connected to it - once I plugged the main board , I got the flickering LED and instability on the 5v rail AS WELL. I'm pointing my finger towards the PFC circuit not reaching the right voltage, but like I said, if I don't have the board I can't test it, so that's about it for now...thanks for your support nonetheless
                        Wattevah...
                        • CapLeaker
                          Leaking Member
                          • 8132
                          I just remember a while back there was a mega thread with over a 184 posts where the PSU did weird things. We were going all over this thing, had the secondary apart, then went all over the PFC etc. It eventually boiled down to 2 bad little capacitors.
                          https://www.badcaps.net/forum/showthread.php?t=51817
                          Funny thing is, this would have been an absolute easy fix, if the guy had an ESR meter and checked all the caps first! Have fun reading this... it's gonna take you a while...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            I will. Thanks for digging it up. Hopefully I can use that info for other supplies as well, since they're all basically the same concept. As far as I can tell just by skimming a few posts, it's about an RCA TV.
                            Wattevah...
                            • CapLeaker
                              Leaking Member
                              • 8132
                              There is tons of information like this here on badcaps. You just have to find it.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Yeah, that's what I was saying about trying to "mirror" the info from other posts about other supplies - you can't always find the exact one, that's for sure. For example now I have an LG with the same friggin' issue on hand (flickering power LED), but I won't talk about it here, since that would be...what do you guys call that ? I think hijacking ? :|
                                Wattevah...
                                • CapLeaker
                                  Leaking Member
                                  • 8132
                                  new TV new thread. PLEASE! It's confusing already at times as it already is.
                                  • Cookybaby
                                    Samsung UN60ES6500FXZA Power Supply Issue
                                    by Cookybaby
                                    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                    Make: Samsung
                                    Model: UN60ES6500FXZA
                                    Power Supply P/N: BN44-00525A
                                    Symptoms: The TV was...
                                    08-20-2023, 12:26 PM
                                  • lp20th
                                    Samsung Plasma TV Power Supply Issue
                                    by lp20th
                                    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                    11-28-2023, 10:28 AM
                                  • captainKKK
                                    Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                    by captainKKK
                                    Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                    02-17-2022, 08:59 PM
                                    09-07-2024, 05:50 AM
                                  • cheeky2
                                    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                    by cheeky2
                                    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                    06-15-2025, 05:12 AM
