Sharp LC-60LE640U 1 long, 1 short blink
  • sacosta80
    • Aug 2016
    • 8
    • united states
    Hoping someone can tell me what the errors im getting mean
  • nuala
    • Aug 2013
    • 37
    Re: Sharp LC-60LE640U 1 long, 1 short blink
    I was able to force the set on using sharps force on procedure for this model which is to unplug the set from ac simutanously press and hold ch down & vol up down and while holding buttons down, plug set into ac,
    • sacosta80
      • Aug 2016
      • 8
      • united states
      I did get it to turn on but only showed the screen I attached a pic of above.
      I will try that when I get home and update, Thank you!
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Looks like burned out led on the lower left.
        Same issue I had with a 60 sharp but on the lower right.
        • R_J
          • 9535
          By looking at your screen, it has logged 6 lamp errors so I would suspect, (like Malachi said) defective led
          • sacosta80
            • Aug 2016
            • 8
            • united states
            Thanks guys, that's what I figured through my research the past few days. Only thing now is to weigh my options between fixing myself and taking it into a repair shop. Now, Im not an expert on electronics but I can complete projects when necessary. what do you guys think?
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              The thing about fixing is, trying to find the same led strip, which I wasn't able to.
              Also it is very easy to break the lcd screen getting off or putting back on. If you even look at to hard it might crack. I've cracked 2, lol, and the bigger they are the flimsier they are.
              One sharp 52" had the screen that came off with the metal bezel around it all in one piece, so it was safer and easier to remove.
              • fixitelectronix
                • Nov 2013
                • 18
                I have same issue. I cant source the individual LEDs. I'd rather not replace the strip if I dont have too. Anyone have individual LED part number or a link?
                  • 12187
                  • U.S.
                  Not the best idea to replace individual leds, because by the time one is ready to go others are usually right behind it, strip it down first, then decide if you want to do it again in a day a week a month?
                  • fixitelectronix
                    • Nov 2013
                    • 18
                    Agreed, and I usually dont. In this case, the LEDs weren't the issue. I have a shopjimmy backlight tester and narrowed it down to the strip. Turned out that the connector had broken solder joints. Couldn't get the connector to go back on so I removed and soldered the wires directly to the strip. Now the LED strip gets power from the backlight tester and will allow me to light up the strip without issue. Put everything back together and the power board is only putting out 64v per connection...total of 4 connections(2 strips powered by 2 negative wires and 2 positive wires each). Dont have a schematic to know if these values are correct or not. With the tester, I can power up the TV and apply voltage to one of the strips and the backlights light up the panel enough for me to navigate. I can navigate with no issue as long as the tester is connected. I feel like the power board is either underpowering the strips or the main board isnt giving the go ahead to allow full power. Anyone have any ideas? Appreciate the help.
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      U may have soldered the strips together incorrectly. sharp designs there strips to work differently than most led sets. Leds are probably 6 volts also. use your tester and see what voltages fire up each lead.
                      • fixitelectronix
                        • Nov 2013
                        • 18
                        I traced the leads, checked and double checked my work prior to putting everything back together. Like I said, I can power each section of the strips from the cable that plugs into the power board using the LED tester and everything works flawlessly when I do that but I cant find a schematic that would show me the voltage coming from that section of the board. Its tests as 64.6v per section. I'm not throwing any codes since repair but I still cant get the TVs backlights to work without powering them with the tester.
                        And yes they are 6 volt LEDs.
                        • budwich
                          • Jul 2015
                          • 3097
                          Did you clear the counters?
                          • fixitelectronix
                            • Nov 2013
                            • 18
                            To the best of my knowledge. I cleared the lamp code in the K menu. TV is turning on, still no backlight. No more codes. I can manually power on one of the strips and get a partial picture. Just cant get the power board to kick on the LEDs strips by itself. I was hoping someone had the schematic to tell me what was suppose to be coming out of the power board into each strip.
                            • budwich
                              • Jul 2015
                              • 3097
                              I think you have to clear the counters... post a picture again like you did in the first post.
                              • fixitelectronix
                                • Nov 2013
                                • 18
                                I cant get the best shots to show but on the first menu it says lamp reset....I turn it on and unplug the unit and let it sit for a bit and turn back on and nothing. Is there a save changes option I'm missing. Could have swore i read something that said unplugging it saves the changes.
                                • gfosterCA
                                  • Dec 2019
                                  • 13
                                  Sorry for reviving this old thread. I have this exact blink sequence, and powering on with Chan_down+Vol_up does in fact force the set to come online. I can't seem to find the maintenance menu/screen that shows me the lamp failure count, etc. Any pointers?
                                  • gfosterCA
                                    • Dec 2019
                                    • 13
                                    Also to note, it appears that the left hand 6-12" is much dimmer.
                                    • Superbee_dad
                                      Sharp 80” long short flash backlight error - Help
                                      by Superbee_dad
                                      Hello Sharp TV experts
                                      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                      01-24-2025, 11:51 PM
                                    • Rotorcraft230
                                      Sharp LC 80C6500U 1 long 1 short blink
                                      by Rotorcraft230
                                      Hello all, I have been here from time to time and now I'm back for some assistance.
                                      So I have the TV above and its doing the one long and one short "V" blinking. I did the reset on the controls on the side of the TV and while holding down the volume - and the input button, then plugging in the TV the "V" light is solid, then very briefly I see the backlight flash, then the "V" goes back to the 1 long and 1 short blinking. I just want to make sure its the backlights before I get the parts to fix it. Is there anything else I can do to confirm its the lights....
                                      02-28-2021, 04:14 PM
                                    • SONY_E-WASTER
                                      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                      by SONY_E-WASTER
                                      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                      does...
                                      12-26-2021, 05:46 PM
                                    • Mitike
                                      SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                                      by Mitike
                                      Hello guys,
                                      I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                                      According to other sharp SM-s it is lamp error (I can't find SM for this model)
                                      And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                                      If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                                      02-16-2020, 08:11 PM
                                    • gette
                                      Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
                                      by gette
                                      Hi...
                                      Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
                                      SHARP LC-70LE732U
                                      Delta DPS-222BP
                                      Icon Flash 2 Long 3 Short
                                      Power PWB Failure
                                      Power supply error 2 (*2) D+3.3V error
                                      D_POW
                                      Digital 3.3V failure Flashes fast 3 times
                                      DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
                                      If error is detected during start-up or operation, the power is turned on again by polling.
                                      Above is what manual states not what I confirmed, but would lie to but not...
                                      09-06-2021, 11:33 AM
