Sony KDL40W4100: no signs of life?
  • whyexactly
    • Apr 2014
    • 28
    Re: Sony KDL40W4100: no signs of life?
    Should I use an iron or a heatgun? It looks like there's a lot of them on here.
    • whyexactly
      • Apr 2014
      • 28
      I tried using a heat gun on the back of the main board but no dice, I'll try an iron on the larger caps this evening. I was able to confirm the backlight works by hooking it to my brothers KDL40S4100 so if I need to buy a new main board I'm not as worried as I would be if I couldn't have tested that.
      • whyexactly
        • Apr 2014
        • 28
        How do I determine which numbers matter for ordering a new main board? From what I can tell A1506072C and 1-876-561-13 are the relevant ones, but can I use one from a KDL-52W4100?
        • whyexactly
          • Apr 2014
          • 28
          Bringing this back up, according to Shop Jimmy I need an "A-1643-237-A" board, however I can't find one anywhere. Nobody on eBay seems to be able to confirm the serial number or panel number of the TVs they pull boards from, can anyone tell me if there's anywhere else that I can see if the board is cross compatible with another one? Failing that, anyplace I might be able to send this board for repair?
          From ShopJimmy:
          Part Number: A-1643-237-A
          Board Number(s): 1-876-561-13, A1506072C
          Panel Sticker Number: LTY400HF01
          Panel Manufacturer: Samsung
          Important Message: BU Board 8200001-8400000
          My TV serial number is actually higher than that (844xxxx), but from what I can tell Sony doesn't put the part number anywhere on the actual board?
          • ozzy214
            • Nov 2013
            • 319
            • usa
            You didnt look to hard
            http://www.ebay.com/sch/i.html?_from...13%2C&_sacat=0
            40 usd
            • whyexactly
              • Apr 2014
              • 28
              I've looked plenty, all of the 40W4100 use 1-876-561-13 (along with a whack of other TVs), but they aren't all interchangeable as that's just the number for the bare board. The number for the assembled board is A-1643-237-A which is only used in the KDL-40W4100's with the panel sticker LTY400HF01/serial number 8200001-8400000. I've yet to find one for sale where either the ad or the seller can confirm that it's the correct board.
              That's based on the best info I've found so far, so please correct me if I'm wrong, but I've yet to come across anything confirming that the boards can be interchanged. The only service manual I can find predates my TV so I can't use that to confirm or deny anything either (manual is 4/2008, TV is 11/2008).
              • whyexactly
                • Apr 2014
                • 28
                I tried replacing the board with one I managed to find locally, I couldn't confirm it was an exact match but I figured it was worth a shot. There's still no change (no LEDs, no clicks) I would've guessed it would at least try to turn on even if it was the wrong board but maybe not?
                • whyexactly
                  • Apr 2014
                  • 28
                  I decided to re-measure the voltages going from the PSU to the BU/main board and the T Con to see if anything is out of place to you guys, this is with the standby power jumped to POWER_ON with a 1k resistor and the BU/main board unplugged from all connections:
                  DIMMER: 2.1V
                  BACK_LIGHT_ON/OFF: 0V
                  INV_ERR: 15V
                  GND: 0V
                  BALANCER_ERR: 0V
                  REG12V: 12V
                  REG12V_GND: 0V
                  UNREG_15V_GND: 0V
                  UNREG_15V: 16.2V
                  STBY3.3V: 3.4V
                  AC_OFF_DET: 0V
                    You have some bad signals. Training manual CTV-45 Chassis EX1
                    More service manuals, too big for attachment.
                    http://elektrotanya.com/?q=showresul...at2=schematics
                    • CapLeaker
                      Leaking Member
                      • 8352
                      Jump BLon to STBY, same as you did with PSON and the resistor. Recheck inverr pin.
                      • whyexactly
                        • Apr 2014
                        • 28
                        @budm: Following page 38 of the training manual the BU board needs to be replaced. Page 50 goes into the inverter, I haven't got time to check that today but I will this evening. Anything I should be wary of when checking this? According to the manual:
                        "Check for the presence of 395VDC at CN6600 on the DF1
                        board. This voltage line is referenced to hot ground so you will have to
                        read across pins 1 and 3 of the connector. "
                        @CapLeaker: With BLon and PSon jumped to STBY with resistors, inverr is 1VDC but the backlight doesn't come on. Trying it multiple times I saw 1V, 15V and 3V. I should note that the manual states BLon should get 3.3V from the BU board ~5 seconds after the unit is powered on, however I'm connecting both resistors and then plugging in the unit all at once. I'm not sure if that could cause a problem or not.
                        • whyexactly
                          • Apr 2014
                          • 28
                          Woops, looks like I was looking at the wrong page. Pg 43 covers the inverter:
                          "Once the IP5 board receives a power on high at CN6150-1 the power
                          supply begins generating the necessary voltages. The PFC circuit
                          increases the rectified 160VDC to approximately 395VDC to supply
                          power for the inverter switching transistors.
                          The oscillator provides the
                          necessary 41KHZ drive for the inverter switching transistors. The inverter
                          stage outputs approximately 1000VRMS at 2 output lines that are 180
                          degrees out-of-phase.
                          Note the inverter detect stage. The detector consists of small-value
                          capacitors and diodes to detect the AC voltage. If either AC line fails to
                          output the inverter detect circuits will output a high to CN6154-3. This will
                          be detected by BE Micro IC3001 on the BU board and the unit will shut
                          down and blink the standby LED in groups of 6. The event will also be
                          registered into the diagnostics menu for viewing when entering that mode.
                          This will be covered in Chapter 7.
                          The inverter also has over-voltage and over-current detection circuits (not
                          shown). If either circuit detects a malfunction the oscillator will stop and
                          create an inverter detect failure"
                          Looking at the bold part I take it I should see 395VDC at the PFC output when the board is powered on regardless of the inverter error?
                            You should have the PFC Boosted Voltage on the main cap when the PS-ON (Power on signal from the main board to the power supply board), it will drop down if the main board gets an error from the inverter circuit then it will shut down the PS-ON signal, BL-ON signal.
                            BTW, since you are not even getting any LED error codes on the front panel, then some thing is not right with the main board.
                            • whyexactly
                              • Apr 2014
                              • 28
                              I've managed to source a new main board, that's in the mail and should be here soon. I was hoping to verify that PSU is fully functional before it arrives but at this point it's probably best to wait for the main board before proceeding.
                              • davidk35
                                Lenovo ThinkBook 15 G2 ITL, some little signs of life
                                by davidk35
                                So i got above mentioned laptop. Which shows only some little signs of life.
                                When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                                What ive already done:
                                -Flashed both bios chips 16 and 8 mb.
                                -Tried adding another stick of ram
                                -Check if backlight is faulty.
                                So any ideas?
                                Thank you
                                09-03-2025, 06:34 AM
                              • cheeky2
                                Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                by cheeky2
                                For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                01-08-2024, 05:56 AM
                              • KYBOSH
                                Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                by KYBOSH
                                I picked this one up today.
                                Previous owner says no signs of life.
                                TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                The TV model is QN65LS03BAFXZA - version: CB06
                                The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                Will keep you all...
                                04-05-2025, 08:32 PM
                              • tranquility
                                HP EliteBook 850 G5 without signs of life
                                by tranquility
                                hello, i have a problem with HP EliteBook 850 G5
                                shoring no signs of life. led near charging port and on/off button are off.
                                board it taking just a few mA..i think it was 10mA
                                i measured some things but i don“t find anything
                                the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
                                but i dont know why
                                i cant really understand what the mosfets in the pictures are doing for crazy things.
                                i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
                                12-02-2024, 05:57 AM
                              • KYBOSH
                                Trying to Save - Samsung UN40MU6300 - No Signs of Life
                                by KYBOSH
                                Picked this one up today.
                                No signs of life whatsoever. No red led light from the IR module.
                                Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
                                Checked the power button for continuity when buttons were pressed and I got readings.
                                Disconnected various components (speaker, wifi module) with no difference.
                                Checked mainboard's fuses (found 3) and they were all good.
                                I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
                                Then it dawned...
                                10-12-2024, 11:20 PM
