Sharp LC-70LE650U Blinks 1 short and 3 Long
  • Ltank
    • Jun 2013
    • 776
    The set blink code is 1 short and 3 long. I downloaded the Service manual and that code is not listed. When the set is plugged into AC power the P.S. turns on has 400vdc on filter caps. disconnect PD connector to M.B. P.S. has 169 vdc. Evidently the M.B. sends a on command to P.S.
    I believe that the M.B. DKEYMF953FM06 is the problem. Endcompass has it for excess of 300 bucks, they show it compatible with 31 different sets from 60" to 80" sets. I and not sure of Ebay. I have been burnt by them and one supposedly reputable dealers. Before I spend al lot of money. Does anyone know the meaning of the Code 1 short and 3 long led flashes on the front panel?
  • R_J
    • 9550
    Re: Sharp LC-70LE650U Blinks 1 short and 3 Long
    3 SLOW Flashes and 1 FAST Flash is Initial communication error on the Main PWB
    • Ltank
      • Jun 2013
      • 776
      I was wondering. The Service Manual show the pulses and descriptions but not the 1 short and 3 long in that order.
      • Ltank
        • Jun 2013
        • 776
        I soldered a jumper across it, with the P.S. to M.B. cable disconnected. the It did not display any test patterns. The VS was 201 the VA was 55 the 15 and 5 vdc were also good. Bad panel I guess. Shame.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          This isnt a Plasma though wheres Vs come from ?
          • budwich
            • Jul 2015
            • 3097
            For the "heck" of it, disconnect the small lower corner cable (right or left side of the panel) that connects the side boards to the lower boards and see what the results are. IF you are lucky, you may get a picture which then means the panel is bad :-( BUT can be saved as there is a "save process" to get the set back to "normal".
            The error code may be misleading as panel issues can have some "unexplained" effects on the system and resulting "expert firmware reporting logic"... :-)
            • R_J
              • 9550
              I have no idea what he is working on.... What is the "it" Vs and Va on an LCD tv... I don't think so
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Post some pictures of your boards and the whole of the rear of the set as attachments.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Knew I couldn't avoid you again, Im out.
                  • R_J
                    • 9550
                    Is this like your tv and problem? https://www.youtube.com/watch?v=SUN40ZJF_Z0 According to this video it was his power supply with the problem.
                    • Diah
                      • Feb 2013
                      • 6376
                      Japanese almost make it so by diagram ( Pulse ) at end they are same meaning to describe the error code.
                      the fault not at panel. unless its Brocken .. because of CPU communication blocked. its highly MB issues
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Close but not there, the Mb is shutting down to protect its self. The fault is the panel which is causing the set to go "ohh shit theres a problem better turn off power now if not Im going to set on fire" common issue on this chassis them tabs on the Lcd panel shorting causing issues.
                        • Ltank
                          • Jun 2013
                          • 776
                          Sorry about the confusion. I was working on two different sets. One Plasma and a Led LCD tv at same time I screwed up thinking of one and entered it for the wrong set. Sorry guys. My Mistake.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Its fine, my post was about someone else here doing my head in.
                            • dacflyer
                              • Jan 2019
                              • 3
                              Hi all, I have the SHARP AQUOS LC-60LE650U , basically a larger screen, mine had the same issues, 3 long and 1 short. It took me a while, but here is the fix for that flash issue.
                              your 12v regulator has gone open. you can see the fix in my video link.
                              https://youtu.be/jHjBjIaQzXc i hope it helps you guys. feel free to comment.
                                • 12206
                                • U.S.
                                @dacflyer, Well done, easy to follow, strange orb effect of camera made me a little dizzy, otherwise all good.
                                Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
                                • lpatety
                                  • Sep 2020
                                  • 4
                                  • Estados Unidos
                                  Hello everyone, I have 2 Sharp LC-60LE650U and LC-70LE650U TVs with the same problem 3 slow flashes and one fast one. I measured the output of the regulator and I do not have the 12V, I proceeded to bypass the source to turn it on manually and that way I get the 12V in the regulator so I suspect a defective main board. But additionally I would like to try to turn on the LEDs manually but I have not been able to. The tests I have carried out on both TVs with the same results. Attached photo of the power source. My Power supply model is DPS-167CP REV:01
                                  • RDC55
                                    • Dec 2017
                                    • 180
                                    I am working a similar issue (3 long 1 short) on a Sharp LC-60C7500U, which uses the main PWB DKEYMF953FM06. I am awaiting a main board based on no panel on command and no green status light - error is also low, which I believe will disable the back lights - not sure on that one. I was curious if you had the green status light on the Main Board on either TV as demonstrated in post 15 YouTube link where the Power Supply was the actual fault?
                                    And, does anyone know for sure what the small green LED on the Main Board indicates - watchdog timer to determine processor status perhaps??
                                    Good luck finding the boards for cheap as they seem to start around $100 and quickly go up. Unfortunately, the TV is only worth about a $100 but I figure any TV with a good panel better to give it life than send it off to the bone yard.
                                    • lpatety
                                      • Sep 2020
                                      • 4
                                      • Estados Unidos
                                      I changed the Main, but now I have one long and one short blinks
                                      • RDC55
                                        • Dec 2017
                                        • 180
                                        Well I finally broke down and got a main board for this one but and as luck would have it there is another problem - a solid blue vertical line. I guess my thought is panel, but does anyone think this might be a connection issue at the gate COF that could be repaired with pressure?
                                        Oh, and the status light on the new board does blink once booted - still not sure just what it is indicating though.
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • Noobwithamultimeter
                                          Sharp LC60C6400U - 2 long binks, 5 short blinks error code
                                          by Noobwithamultimeter
                                          Hi, long time browser - first time poster. I got my hands on a Sharp LC60C6400U and from what I could find on youtube similar models of this set have a 12V power regulator that fails called "KIA378R12PI". So I go ahead and order the part, install it and badda-bing my set worked right away. Only a problem - it failed after about 3 hours. So I re-attempted my solder joints and it was back in business, for a couple of days. Failed again with the same error code. I think to myself no worries I have 4 spares since I bought a 5 pack in case anything went wrong. But now after roasting the solder...
                                          04-06-2021, 01:31 PM
                                        • cm0002
                                          Sharp LC-55N7000U 1 long 5 short blinking, no display
                                          by cm0002
                                          I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                                          Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                                          I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                                          06-19-2023, 06:21 PM
                                        • Charrlie
                                          Sharp Lc-70le734u blinking 2 long 5 short
                                          by Charrlie
                                          Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                                          So I busted into it and have done the following:
                                          -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                                          07-07-2022, 02:02 PM
                                        • gette
                                          Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
                                          by gette
                                          Hi...
                                          Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
                                          SHARP LC-70LE732U
                                          Delta DPS-222BP
                                          Icon Flash 2 Long 3 Short
                                          Power PWB Failure
                                          Power supply error 2 (*2) D+3.3V error
                                          D_POW
                                          Digital 3.3V failure Flashes fast 3 times
                                          DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
                                          If error is detected during start-up or operation, the power is turned on again by polling.
                                          Above is what manual states not what I confirmed, but would lie to but not...
                                          09-06-2021, 11:33 AM
