Vizio VP422 won't turn on.
    Re: Vizio VP422 won't turn on.
    Check the resistance between pin 5 and pin 9, (look at the spec sheet on how to count the pin of the IC).
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #122
      Originally posted by Malachi
      Ok. I wish that was is English. Lol
      I could repeat it in Welsh
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        #123
        Please do. Lol
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          #124
          So how do you guys remove these from the heatsink since there isn't enough room to unscrew it?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #125
            Can you cut down a screwdriver to make a real stubby driver to gain access?
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #126
              I doubt it. I have a right angle one somewhere. I could try it.
              In the mean time I ordered a working psu from eBay for $38.
              Hopefully that fixes the TV.
              Then I can order the part for the other one from China and won't have to worry on how long it takes to get here.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #127
                Or something like this that you can use over and over.
                http://tinyurl.com/jcvqp2a
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #128
                  Thanks. That's a neat tool to have.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #129
                    Fixed. A new power supply took care of it. Cost of $38.
                    Without your help, I wouldn't have know which board was faulty.
                    Now I also know what's wrong with the faulty one.
                    I can take my time fixing it if I want.
                      Thanks for the follow-up on the repair.
                      • Smald
                        • Jan 2017
                        • Usa
                        #131
                        I enjoyed following this thread. I have the same issue (amber light is on. One click when I plug the unit in, no picture or audio). If I understand correctly, the issue was with an integrated circuit. My question is what caused the failure? Was there an underlying problem? Was there something about the main board that caused this? Malachi - is your tv still working?
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #132
                          I don't know what caused it. I bought it as it was and sold it shortly after.
                          • pocketwatch62
                            • 74
                            • US
                            #133
                            I have the same set what does 2 blinks on the little stand-up board mean?
                            • R_J
                              • 9588
                              Check if you have D5V/VG/A12v, Check if F8201 fuse is ok, if open, you may have an issue in the U8301 circuit.
                              • pocketwatch62
                                • 74
                                • US
                                #135
                                Thanks for replying R_J
                                All i have is
                                5VSB--5.33
                                PS_ON--0.49
                                AC_DET--5.21
                                VS_on---0.13
                                would the U8301 cause a blown fuse?
                                all the fuses are good.
                                • R_J
                                  • 9588
                                  If U8301 was shorted, it would likely blow F8201.
                                  • pocketwatch62
                                    • 74
                                    • US
                                    #137
                                    Vizio 0940-0000-2270 Power Supply
                                    LJ92-01508A
                                    How do i force this power supply on?
                                    It clicks 2 Quick times when i first plug it in.
                                    no response from power button or remote.
                                    The stand up board on PSB flashes 2 times.
                                    • pocketwatch62
                                      • 74
                                      • US
                                      #138
                                      R_J, Budm,
                                      How would i force this power supply on?
                                      LJ92-01508A
                                      • pocketwatch62
                                        • 74
                                        • US
                                        #139
                                        anybody??
                                        • Mulp
                                          VIZIO M65-C1 Does Not Turn On
                                          by Mulp
                                          Hi All,
                                          I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                          When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                          I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                          01-13-2024, 09:57 PM
                                        • Noah Glasse
                                          LG 50PK590 - three clicks and steady red light, won't turn on.
                                          by Noah Glasse
                                          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                          02-24-2025, 07:23 AM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
