Vizio VP422 won't turn on.
    Re: Vizio VP422 won't turn on.
    Check the resistance between pin 5 and pin 9, (look at the spec sheet on how to count the pin of the IC).
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      #122
      Originally posted by Malachi
      Ok. I wish that was is English. Lol
      I could repeat it in Welsh
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        #123
        Please do. Lol
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          #124
          So how do you guys remove these from the heatsink since there isn't enough room to unscrew it?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            #125
            Can you cut down a screwdriver to make a real stubby driver to gain access?
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #126
              I doubt it. I have a right angle one somewhere. I could try it.
              In the mean time I ordered a working psu from eBay for $38.
              Hopefully that fixes the TV.
              Then I can order the part for the other one from China and won't have to worry on how long it takes to get here.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #127
                Or something like this that you can use over and over.
                http://tinyurl.com/jcvqp2a
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #128
                  Thanks. That's a neat tool to have.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #129
                    Fixed. A new power supply took care of it. Cost of $38.
                    Without your help, I wouldn't have know which board was faulty.
                    Now I also know what's wrong with the faulty one.
                    I can take my time fixing it if I want.
                      Thanks for the follow-up on the repair.
                      • Smald
                        • Jan 2017
                        • Usa
                        #131
                        I enjoyed following this thread. I have the same issue (amber light is on. One click when I plug the unit in, no picture or audio). If I understand correctly, the issue was with an integrated circuit. My question is what caused the failure? Was there an underlying problem? Was there something about the main board that caused this? Malachi - is your tv still working?
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #132
                          I don't know what caused it. I bought it as it was and sold it shortly after.
                          • pocketwatch62
                            • 74
                            • US
                            #133
                            I have the same set what does 2 blinks on the little stand-up board mean?
                            • R_J
                              • 9514
                              Check if you have D5V/VG/A12v, Check if F8201 fuse is ok, if open, you may have an issue in the U8301 circuit.
                              • pocketwatch62
                                • 74
                                • US
                                #135
                                Thanks for replying R_J
                                All i have is
                                5VSB--5.33
                                PS_ON--0.49
                                AC_DET--5.21
                                VS_on---0.13
                                would the U8301 cause a blown fuse?
                                all the fuses are good.
                                • R_J
                                  • 9514
                                  If U8301 was shorted, it would likely blow F8201.
                                  • pocketwatch62
                                    • 74
                                    • US
                                    #137
                                    Vizio 0940-0000-2270 Power Supply
                                    LJ92-01508A
                                    How do i force this power supply on?
                                    It clicks 2 Quick times when i first plug it in.
                                    no response from power button or remote.
                                    The stand up board on PSB flashes 2 times.
                                    • pocketwatch62
                                      • 74
                                      • US
                                      #138
                                      R_J, Budm,
                                      How would i force this power supply on?
                                      LJ92-01508A
                                      • pocketwatch62
                                        • 74
                                        • US
                                        #139
                                        anybody??
