Emerson LF501EM4F turn on then off.
  • CapLeaker
    Leaking Member
    • 8146
    Re: Emerson LF501EM4F turn on then off.
    Originally posted by erickeri1234
    Im trying to jump it with a resistor that I'm reading 1.032 but I'm getting 3.3v at the end but once I touch the p-on_h2 it drops down to 0.57v
    Must be a bad resistor. Some resistors go high in value if there is current going through it, but measure fine out of circuit or if the unit is turned off. I've had that happen before.
    • erickeri1234
      • May 2013
      • 98
      • usa
      Originally posted by dick_barton
      When doing the above test did the backlights come on and stay on?
      I disconnected every from the PS board. But I will plug the backlight in and see.
      • erickeri1234
        • May 2013
        • 98
        • usa
        Yea something was up with it. I grabbed a different resistor 1.2xx and I got some readings.
        • erickeri1234
          • May 2013
          • 98
          • usa
          OK tested it with the backlight connected to the PS board. The back light doesn't come on.
          But it does come on when main board is connected. Weird!!!
          • CapLeaker
            Leaking Member
            • 8146
            yeah... you only have PSon jumped to fire up. You would have to do the same thing to BLon (backlights). There is nothing wrong with your PSU.
            • erickeri1234
              • May 2013
              • 98
              • usa
              #26
              It's got to be the main then right. It does seem like it.
              • erickeri1234
                • May 2013
                • 98
                • usa
                #27
                Ordered the main board today. Will post out come
                • erickeri1234
                  • May 2013
                  • 98
                  • usa
                  #28
                  UPDATE!!!
                  Git the main board in from SJ, installed it and it is doing the samething. Turns on for about 5 to 8 seconds then right off. So I ordered a PS board samething on then right off... should I RMA the main board??
                  • CapLeaker
                    Leaking Member
                    • 8146
                    measure the voltages on the back light led strings.
                    • erickeri1234
                      • May 2013
                      • 98
                      • usa
                      #30
                      Hard to measure no diagram on board.
                      It does it even when everything is unplugged . Just power to main.
                      • CapLeaker
                        Leaking Member
                        • 8146
                        So when the TV comes on for 8 seconds the TV acts normal (you can see picture on the LCD) and then the TV turns fully off? That is a main board problem in my book. So verify the PSon pin on the power supply again. If the PSon voltage drops out, it is the main board. PSon is generated on the main board. Try the same thing with the back lights unplugged, then with the Tcon unplugged. Are there 2 ribbon cables going to the tcon?
                        • erickeri1234
                          • May 2013
                          • 98
                          • usa
                          #32
                          Yea tv will power up I see the Emerson logo then for split second I can see the channel, then the tv goes turns off fully when speakers make like a small popping noise like the board is shorted. It does it with everything connected and when I disconnect everything. I just tested the power supply again samething.
                          PS_ON-H2 ..... 3.2v then drops to 0.0v when it shuts down
                          P-ON+21V.... 21v then to 11.5v when it shuts down
                          All+3.3v..... 3.279v there all the time.
                          • erickeri1234
                            • May 2013
                            • 98
                            • usa
                            #33
                            One ribbon going to the tcon.
                            • erickeri1234
                              • May 2013
                              • 98
                              • usa
                              #34
                              Pic
                              • CapLeaker
                                Leaking Member
                                • 8146
                                Where does that ribbon on the bottom left corner on the main board go? It looks like it goes to the Tcon for me?
                                • erickeri1234
                                  • May 2013
                                  • 98
                                  • usa
                                  #36
                                  Small ribbon goes to the ir board.
                                  • SLK001
                                    • May 2014
                                    • 264
                                    The description sounds like you have bad LEDs in your backlight. There appears to be more than one string of LED power. When you turn the TV on, the working strings will light up until the chip controlling the bad string flags a failure mode, shutting down the entire set to protection mode.
                                    The exact same problem presented itself to me with a VIZIO set. I struggled thinking that it was a PS problem for two days, then finally realizing that the LED FAULT line was being pulled low (indicating a fault). It is very slow to respond (over 6+ seconds), thus giving the impression that the backlights are okay. However, the backlights were NOT okay and a teardown of the panel showed two LEDs out in one of the strings. I am waiting for LEDs to replace them.
                                    • erickeri1234
                                      • May 2013
                                      • 98
                                      • usa
                                      #38
                                      Yea I understand that but it does it even went I have the back lights disconnected.
                                      I have only power to the ps board and the ribbon from ps to the main and it still shuts down.
                                      And if I jump 3.3v to ps-on the ps board stays on all with correct volts.
                                      It just seems like a bad main board. But it is from shopjimmy.
                                      • SLK001
                                        • May 2014
                                        • 264
                                        You should get an LED FAIL signal with the backlights disconnected, too (open circuit detected).
                                          No cable between the power supply board and the main board, LED connector in place, do the resistor jumper for the PS-ON (P-ON-H2) as before, then another resistor between the jumper J106/ BL-SW and the 3.3V to force the backlight on, see if the backlights will stay on.
                                          Pictures provided by shopjimmy.
                                          http://www.shopjimmy.com/emerson-a3a...pply-unit.htm#
                                          Emerson A3AU0MPW-001 Power Supply for LF501EM4 / LF501EM4F
                                          • waakye
                                            ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
                                            by waakye
                                            I was giving this ASUS ROG G750JM that exhibit the following behavior:
                                            When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
                                            My issue is the laptop doesn't stay on for a long time and turn itself off.
                                            Any lead on how to resolve this will be appreciated.
                                            I cannot boot in windows and no liquid damage.
                                            Thanks in advance.
                                            09-13-2024, 08:10 PM
                                          • gabrielA7
                                            IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                                            by gabrielA7
                                            Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                                            I saw that the room LED lights up only when the screen is connected, so quiet.
                                            We have all the power supplies, even processor, 1.8V
                                            One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                                            I suspect that there may be some leak in the processor.
                                            Anyway, when I press the power, it...
                                            10-29-2024, 06:48 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • JohnML1975
                                            Falcon FF32S53 turns off by itself then will not turn back on unless you wait
                                            by JohnML1975
                                            Dear Forum members
                                            I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
                                            I will upload some photos and share my trouble shooting steps so far
                                            07-20-2025, 12:28 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
