ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
  • waakye
    • Dec 2018
    • 340
    • Electronada
    I was giving this ASUS ROG G750JM that exhibit the following behavior:
    When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
    My issue is the laptop doesn't stay on for a long time and turn itself off.
    Any lead on how to resolve this will be appreciated.
    I cannot boot in windows and no liquid damage.
    Thanks in advance.
  • waakye
    • Dec 2018
    • 340
    • Electronada
    The screen was the culprit. The laptop turns on now that I change the screen.
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • Kambi13
      Asus X551MA-SX051H Turns on and after 5 seconds turns off
      by Kambi13
      Hi guys, need some help trying to figure out what is happening in this Asus X551MA-SX051H - Board X551MA Rev 2.0
      So when pressing the power button power light comes on and after 5 seconds goes off, no shorts found on the board, 19v, 3.3v (at SIO) and 5v present. Measuring bios chip at pin 8 (25Q64FWSIG - 1,8V) there's nothing there but here's the funny part if I remove the ram stick and press power button the board turns on and stays on, now all voltages are present and the cpu is getting warm. Tried different ram sticks but no change.
      10-27-2023, 12:00 PM
    • twonk9098
      Lenovo Legion 5 high fan spin turns off after 34 seconds
      by twonk9098
      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
      I have tried a few new bios but exactly...
      07-14-2024, 11:19 AM
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • limxrich
      Asus TUF Gaming FX504GM DABKLIMBAB0 - No POst, Turns OFF after a few seconds
      by limxrich
      I would say this is a no fix, but want to pick the brains of the veterans here.
      All voltages present, already tried several BIOS bins. All voltages present when power button is pressed. All reset signals present. Unit does not post, but turns off after around 10-12 seconds.
      Some interesting details:
      1. Unit toggles from 7 & 12 mA when plugged in
      2. Units goes up to 1.5A when turned on (10-12 secs)
      3. Current toggles between 37mA & 42mA when it turns off.
      4. Unit is on continuously ON w/ all voltages present when no RAM is present....
      12-18-2022, 02:43 AM
