Emerson LF501EM4F turn on then off.
    Someone just gave me this tv.
    When I plug it in, it turns on it can see the Emerson logo then for a split second it it goes to the normal screen before turning off. When it turns off I speakers make a popping sound.
    Hard for me to figure out main board or power board.
    Re: Emerson LF501EM4F turn on then off.
    Is it the backlight just turning off, or is the whole TV that turns off, reboots etc.
    If it is the later, I would say main board. There are EEPROM kits or main boards available at SJ.
    Also try to unhook that IR sensor from the main board and see what happens.
      The tv turns off. I have to unplug it for it to turn back on but it will it again. Seems like a short on one of the boards.
          The whole tv turns off. No reboot. I unhooked the ir sensor but still the same thing.
            Disconnect the power supply and measure the dc voltages as given on the board. 5V,3,3V,12V, 24V whatever they are.
              On the main board there is a ribbon cable that goes over to the power supply. There is pin called PSon on the main board. Set your meter to DCV, put your probe between it and GND and observe what happens to that pin when it is off, when you turn the TV on and then when it shuts itself off.
                It's a little hard there is no 5v,3.3v, 12v, etc by the ribbon connector on the board. Only jumper pins close to the connector.
                I see
                all+3.3v
                Amp+137
                P-on+21v
                P-on_h2
                  P-on_h2 shows 3.2v then goes to 0v when it turns off.
                  P-on+21v shows 21.1v then goes to 11.65v when it turns off
                    Is the All3.3 voltage there and stable?
                      3.3v there but when it turns off it goes to 0v
                        So you do not have any standby voltage? If that is the case you need to take a look at the power supply to find what the problem is.
                          Have you run the power supply up disconnected from the main board to see what supplies on it are stable.
                            Sorry I gave wrong info.
                            All 3.3v is there all the time. Even After it turns off, main connected and disconnected .
                            So I do have 3.3v
                              OK so the 3.3V is your standby voltage. With the main board still disconected connect your 3.3V using a 1K resistor to P-on_H2 (I think) and check the other votages come up and if they are stable.
                                So jump 3.3 to p-on_h2 with 1k resistor! I got to see if I have a 1k resistor. Does the wattage of the resistor matter?
                                  No, any 1K will do.
                                    No, any 1K will do.
                                    Im trying to jump it with a resistor that I'm reading 1.032 but I'm getting 3.3v at the end but once I touch the p-on_h2 it drops down to 0.57v
                                      Ok I tested with a different resistor and jumped all3.3v to p_on-h2 and got 12v on 13v rail. And got 21v on the 21v rail..
                                        When doing the above test did the backlights come on and stay on?
