Samsung un40f6300 power issue
  • birdboy385
    • Nov 2015
    • 145
    Hey guys i recently got this smart tv in and the problem with it is, now i'm going to split this up from what the seller told me, what i first experienced and then when things went down hill.
    *What I was told - This tv went through what he described as a powersurge through an unprotected outlet because he noticed other electronics acting weird through this outlet. He described that the tv would randomly turn itself off and on during random intervals of the day. sometimes it would stay on for a few hours sometimes it would shut off instantly.
    *When i got home - I experienced just what he described about random shutting off and turning on. So, I took the tv to my work area, ripped it apart ( almost breaking the rear connector which is for the Infra-red sensor/ input control and wifi card) and took a look at the power supply. I figured it was relatively safe to assume since the screen looked fine, picture came in, backlights were fine, that I was looking at a Power supply issue. I didn't notice anything wrong with the supply at least nothing obvious. No caps looked busted, I checked the fuse on the supply and it checked out. I even checked a few various resistors. couldn't find anything that way so I decided just for the heck of it to switch power cables as well and plugged the tv back in without that rear cable for the input and wifi plugged in. Well, the tv fired up and stayed on for a good few minutes. So i decided to switch power cables. Again Tv stayed on, no sign of trouble. So i plugged that input cable back in and fired it up. Yet again no problem. So i decided to completely reassemble it and give it a full on test.
    *3 days later - ok so the tv's been working 100% I was getting ready to sell it when....disaster it started rebooting again. It started at about 10 second intervals. It would fully load the menu's then shut off and reboot. Then i noticed it slowly becoming quicker until the point where all you would see is the backlight flicker before it rebooted then it was just off / on.
    I haven't ripped it back apart after it started doing this again but I have a feeling I'm not going to find anything different from what I found before. I have heard that several Samsungs like this one had power issues. I'm not sure if this one is suffering from something similliar ( I can never figure out what in those Supplies went, just that samsung covered alot of repairs where they replaced the power board). I'm also not sure if it was just electrical malfunction from the "surge". If anyone has any thoughts please let me know. I'd like to fix this board if i can rather than simply replace it.
  • sordids999
    • May 2013
    • 2149
    Re: Samsung un40f6300 power issue
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Kilroys
      • Feb 2014
      • 70
      • Sweden
      Do you have the latest software ?
      Check the wathdog and error count.
      • birdboy385
        • Nov 2015
        • 145
        I will upload pictures the next time i have a chance to tear it back apart. meanwhile how do i check the error count since i can't get it to stay on?. I beleive i do have the most up to date software because i did update it during the 3 day period that it was working.
        • birdboy385
          • Nov 2015
          • 145
          ok so i was ripping this back apart and decided to reseat the LVDS cable going to the tcon board. for some reason the tv is now (for the moment) working properly. How do i access this menu to check for error counts?
          • birdboy385
            • Nov 2015
            • 145
            Did a little digging and found out how to get into the menu. This was the rsult of the log
            • birdboy385
              • Nov 2015
              • 145
              I'm positive at this point its a power issue. just not sure what all to check.
              • CapLeaker
                Leaking Member
                • 8130
                I am not so convinced it is a power issue on the PSU, rather I think you have a main board issue. For that you would have to check PSon and BLon on the PSU while the TV is rebooting itself.
                As for the PSU, maybe check it over for cold solder joints, make sure all connectors make proper contact etc.
                You can try heating (hair dryer) or cooling (can of air upside down) on the boards and see what it does.
                Can we have high res, straight shot pics of the front and rear of the main and PSU, so we can see what we deal with?
                • Kilroys
                  • Feb 2014
                  • 70
                  • Sweden
                  Many "Power Fail Count" so it seems to be problems with the PSU.
                  As you said many have had their PSU replaced.
                  As you also said it could work randomly,
                  so I have checked the connector CNM803 to see that there is no
                  poor connection.
                  • birdboy385
                    • Nov 2015
                    • 145
                    sorry i've been busy with finals so just now have had a chance to look at this. I've checked the connectors you asked Kilroys, The connector seems fine.
                    CapLeaker. I have a basic smart phone, that's the best camera I have unfortunately. I can try measuring those the next time it acts up but it's random when it happens.
                    • birdboy385
                      • Nov 2015
                      • 145
                      Well...crap. I was reassembling the tv and apparently was a little too rough reconnective the part on the main board that connects the IR sensore, button, and WIFI. Those pins are too small for me to re solder and i can't find the main board online. ShopJimmy is out of stock, Ebay doesn't have the right one. The break was relatively clean but I just can't solder somethinglike that. :/ this might be a dead project. I appreciate everyone's help as always.
                      Edit: I did find a compatible board on ebay and am ordering it I'm hoping it kills 2 birbs with one stone. Fixes the connector issue i just broke, and fixes the power issue i was having.
                      • birdboy385
                        • Nov 2015
                        • 145
                        here's a picture
                        • birdboy385
                          • Nov 2015
                          • 145
                          Hey guys just wanted to give everyone an update. I installed the new main board and have been testing the tv for over a week now without incident. The Wifi is also now properly working and it wasn't before. It would appear that something did happen to the main board. Thanks everyone once again for their help.
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Glad you finally got a result.
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • Cookybaby
                              Samsung UN60ES6500FXZA Power Supply Issue
                              by Cookybaby
                              Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                              I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                              Make: Samsung
                              Model: UN60ES6500FXZA
                              Power Supply P/N: BN44-00525A
                              Symptoms: The TV was...
                              08-20-2023, 12:26 PM
                            • Drewwol11
                              Samsung QN49Q70RAFXZA Power Cycling Issue
                              by Drewwol11
                              My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                              I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                              08-31-2021, 09:32 AM
                            • lp20th
                              Samsung Plasma TV Power Supply Issue
                              by lp20th
                              I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                              11-28-2023, 10:28 AM
                            • mrtek
                              Samsung UN43NU6950FXZA No power
                              by mrtek
                              Hi
                              Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                              Main fuse = OK
                              Back light LED = OK. Power them with aux power source
                              LED output = OK 156V
                              I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                              Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                              07-20-2025, 08:06 PM
