Sharp LC-52D85U Won't turn on
  • birdboy385
    • Nov 2015
    • 145
    Re: Sharp LC-52D85U Won't turn on
    I took indiviual pictures of each Inverter board and the PSU board then a pic of the whole back.
    • birdboy385
      • Nov 2015
      • 145
      hmm something else i noticed. I watched a video on shopjimmy which showcasesan lc-32 with simillar problem. However when he goes through a hardreset, you'll briefly see the menu and channel indicator, I don't get any picture when attempting a hard reset, I'm wondering if there is more to this issue than just a potential backlight problem.
      • birdboy385
        • Nov 2015
        • 145
        any thoughts from anyone? Like i'm actually wondering if there;s an issue with the mainboard not showing video and if there is that issue could that be causing my error code altogether.
        • birdboy385
          • Nov 2015
          • 145
          i feel like there's probably a way to override the diagnostic mode as i mentioned in the other post but not sure how i'd do it since it was technically a different tv
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            I would start by measuring the secondaries on the inverter coils. write them down and compare values between all of them.
            Proud owner of dozens of broken TV's and many,many,many boards.
            Our website and passion:http://hollenhundshepherds.com/
            • birdboy385
              • Nov 2015
              • 145
              sorry for the late response. Um my knowledge of measuring this sort of thing is very minimal. forgive my inexperience but no idea what that means lol.
              • drkthundr
                • Feb 2016
                • 45
                Wrong post
                • birdboy385
                  • Nov 2015
                  • 145
                  Ok so this is the video i was referencing
                  https://www.youtube.com/watch?v=iIfdf0ut4Po
                  it shows the bridging of a cap to disable the error detection. I was wondering if the same method could be applied to this tv so that It would run "normally" so i could at least properly troubleshoot. With the error detection taking over, I can't get anywhere with it.
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    #29
                    Look at picture,I circled the legs of the coil which you need to check resistance between.
                    Write down the resistance from all coils,they should be within 10% of each other.
                    btw,parts are cheap for this tv.:
                    http://www.shopjimmy.com/catalogsear...harp+LC-52D85U
                    • birdboy385
                      • Nov 2015
                      • 145
                      My inverter boards are different than that. not sure where you're actually ahving me check to map to my own board.
                      • birdboy385
                        • Nov 2015
                        • 145
                        here's what mine look like
                        • birdboy385
                          • Nov 2015
                          • 145
                          Yeah i really don't know how to translate the board you showed with mine.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            Can you post a picture of the reverse side of the board in post #31
                            • birdboy385
                              • Nov 2015
                              • 145
                              both boards are shown in the original post. showing the other angle.
                              • birdboy385
                                • Nov 2015
                                • 145
                                anything else you need?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  Can you measure all your inverter transformers and see that they all match.
                                  • birdboy385
                                    • Nov 2015
                                    • 145
                                    i'm not getting any reading when measuring those legs. i have my multimeter set to 500v Since i read the reading should be over 1KV IDK if my multimeter just idn't powerful enough to read thjat
                                      The picture of the transformer pins are on the BOTTOM view so you have to look at it from top view perspective which will be opposite.
                                      ' i have my multimeter set to 500v'
                                      BTW, we are reading resistance not Voltage!
                                      NO POWER to the unit.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        These need to be measured in ohms resitance Not dc volts so leave the tv unplugged and take the readings so we can see if you have any issues.
                                        Last edited by vinceroger69; 04-29-2016, 03:39 PM. Reason: budm beat me to my reply
                                        • birdboy385
                                          • Nov 2015
                                          • 145
                                          lol i realized as soon as i posted that i'm like...wow i has the dumb today.These are the readings that im getting
                                          800
                                          800
                                          763
                                          768
                                          768
                                          768
                                          770
                                          Can't get a reading from the 8th one
                                          775
                                          765
                                          775
                                          775
                                          So probably safe to say that (i beleive that's the master board that has 12 transformers and the slave has 10) there is one bad transformer on the master. i'm going to read the slave now and report back
                                          • JunkmanJimbo
                                            Sharp lc-55p6000u won't turn on
                                            by JunkmanJimbo
                                            Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
                                            09-28-2024, 12:56 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Egidio85
                                            SHARP LC-40LE814E does not turn on 2 flashes
                                            by Egidio85
                                            hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                            the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                            reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                            now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                            to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                            07-21-2023, 11:49 AM
                                          • Mitike
                                            SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                                            by Mitike
                                            Hello guys,
                                            I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                                            According to other sharp SM-s it is lamp error (I can't find SM for this model)
                                            And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                                            If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                                            02-16-2020, 08:11 PM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
