Ok i will admit i haven't done anything to this tv other than plug it in. This tv as soon as i plug it in, the green power light will start blinking and do so infinitely. the tv itself will not boot, no backlights, no screen no sound. Before i start tearing this tv apart, I wanted to hear if there was anything common that people might know about. As soon as i clear my workstation i can tear it apart to look for issues.
Sharp LC-52D85U Won't turn on
Re: Sharp LC-52D85U Won't turn on
Download the service manual and see if it has error codes:
It uses Master and Slave Inverter boards because the lamp for 52" are very long so they need to drive the lamps in push-pull mode.Never stop learning
ok so i reseated the boards, then i performed the test for getting into the adjustment menu. i get a solid green power light and can hear the tv poweringup. the backlight is on for about half a second then goes out. shortly after the power light goes back to repeated green blinking. At this point i'm assuming this means one of the inverter boards is bad or if i'm really unlucky one of the lights themselves. what would be the next step? i feel like trying to measure voltages with this won't be easy with this weird diagnostic setup.
there was a simillar tv a sharp lc-32 where they had the same issue but overwrote a capacitor which controlled the diagnostics. which seemd to temporarily fix the problem. i doubt the power supply in mine is the same as the one i found. anyone know anything about that?
Can we see the pictures of the whole backside of the TV so we can see all the boards?Never stop learning
