Sharp lc-55p6000u won't turn on
  • JunkmanJimbo
    • Mar 2017
    • 194
    Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!
  • Diah
    • Feb 2013
    • 6557
    before make judgment on MB... need to test yours PSU as stand alone to be sure when it receive power-.ON will switch on and provide V to MB
    • JunkmanJimbo
      • Mar 2017
      • 194
      I just found what appears to be a faulty IC chip on the main board.
      • lotas
        • Jan 2016
        • 4848
        • Russia
        This is eeprom 24C256, what makes you think that it is not working properly, it looks like paint.
        • JunkmanJimbo
          • Mar 2017
          • 194
          I scraped it off the best I could so maybe it was paint. Will this eeprom cause the tv to show the standby light but not turn on?
          • lotas
            • Jan 2016
            • 4848
            • Russia
            Your motherboard and power supply are not made by Sharp, but are assembled on the same chassis as HISENSE, and they have models that do not go into operating mode due to non-working backlighting (sophisticated backlight protection).
            • JunkmanJimbo
              • Mar 2017
              • 194
              So, are you saying that this eeprom will or will not cause the tv to show the standby light but not turn on?
              • JunkmanJimbo
                • Mar 2017
                • 194
                Can someone answer this question, please?
                • Diah
                  • Feb 2013
                  • 6557
                  we are here not for challenge... you suspect IC , lotas was hurry to tell its eeürom belong to SW.... look at it pin 1234 where and how they connected or goes... this had nothings to do with STBY and start,,, all this judgment regards the photos you upload,.
                  • JunkmanJimbo
                    • Mar 2017
                    • 194
                    Thank you Diah. With that said, can you tell me the repairs that need to be made to get this board working again? As I said there is someone on Ebay offering repair for a high price. I can't afford it so I would rather find a way to fix it myself, with you guys help.
                    • Diah
                      • Feb 2013
                      • 6557
                      first be sure yours PSU working, test it as standalone ,, if it supply all V needed abd as the print chart of it,,, then you go to MB to check why no power on signal send to PSU
                      • JunkmanJimbo
                        • Mar 2017
                        • 194
                        Actually I decided to order a board. It should be here Wednesday. I will update after that. Thanks for you help!
                        • JunkmanJimbo
                          • Mar 2017
                          • 194
                          UPDATE: The main board was the problem. I just wish there was someone on here that could have told me how to fix the old one in order to save money. But, thanks for the help as always!
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • ygorsan
                            by ygorsan
                            🧩 Problem Summary:
                            • I
                            07-28-2025, 08:34 AM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
