skybox f3
  • gobby009
    • Oct 2014
    • 63
    skybox f3
    hi guys not sure if this is the correct forum for this post if its not maybe someone could move it.got an skybox f3 no life.the cable that connexts to the mainboard from the power supplyone end is soldered to the power supply and the other end clips into the motherboard.with the power on i put the black probe of my multimeter on the top ground and go down the voltages with the red probe heres what i get.
    gnd=0
    24v=35v
    12=11.5v
    gnd=0
    5v=0
    5v=0
    just wondering if it is a badcap issue.any help would be appreciated.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: skybox f3
    Possibly IC1, if its a 7805....
    PSU is running--so its confined to 5V rail, or maybe D9...
    TELEFIX
    • CapLeaker
      Leaking Member
      • 8327
      Re: skybox f3
      5V rail is dead. So I think we need better pictures from top and bottom of the psu.
        • 31196
        Re: skybox f3
        that shit looks worse than a spiderbox HD series!
        check for cracked solder joints on the psu.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Re: skybox f3
          The f5 is a lot better!
          Follow the white rabbit.
          • PhaseCoder
            • Nov 2013
            • 62
            • Uk
            Re: skybox f3
            Join this group here, he is well maintained in selling lines etc and tgere is alot of people who can help there as they play with these all day
            https://www.facebook.com/groups/freeskysatelliteuk/
            • PhaseCoder
              • Nov 2013
              • 62
              • Uk
              Re: skybox f3
              but if you are looking for another box to get a good line, i swear by these never let me down
              http://www.ebay.co.uk/itm/GENUINE-OP...-/141676955868
                Re: skybox f3
                IC1 is probably TL431 series ref diode which drives the OPTP OPT for Voltage regulation..
                We do need good clear pictures of the bottom side of the board.
                • gobby009
                  • Oct 2014
                  • 63
                  Re: skybox f3
                  here are some pictures of the bottom.
                    Re: skybox f3
                    You need to check the Diode (I cannot read the designator on the board) for the 5V supply and check all the connections from the Diode all the way to the 5V terminal.
                    The regulation is done by taking the 5V output for feedback to maintain output Voltage.
                    Nothing complicate on the outputs side just simple Half-wave rectifying and Pi filters.
                    BTW, what is the resistance reading between 5V pin and the GND pin?
                    • perfm2
                      Wson8 spring pin probe WORKS
                      by perfm2
                      I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
                      I recently ordered one to give it a shot and it actually worked quite well.
                      The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
                      I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
                      This aided greatly in allowing the probe to stay in place...
                      03-30-2023, 11:19 AM
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • Askic
                      Probe point corrosion -Macbook repair
                      by Askic
                      Hello guys,
                      I'm learning about logic board (motherboards) repairs. I don't do repairs professionally, but I manage from time to time to repair something for my family and friends.
                      What caught my attention is this visual inspection guide written by Louis Rossmann. It seems that corosion on probe points on the motherboard can "kill" Macbook. https://wiki2.rossmanngroup.com/inde...ual_inspection
                      I wonder how corrosion cause this. If there is a track that has a probe point made on it and corrosion is build up on that place, does this means...
                      01-31-2021, 10:46 AM
                    • JimBanville
                      MOSFET mystery
                      by JimBanville
                      N channel mosfets testing as P type?
                      Working on a smps.
                      Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                      Removed a pair of mosfets marked 1L02AB FDP
                      26N40 from the circuit.
                      The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                      I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                      09-14-2023, 04:22 PM
                    • irnard
                      Micro SMD probe tip for Rigol oscilloscope ?
                      by irnard
                      Any advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
                      02-09-2023, 09:22 AM
