Micro SMD probe tip for Rigol oscilloscope ?
  • irnard
    • Jun 2017
    • 7
    Any advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
  • mon2
    • 14794
    Re: Micro SMD probe tip for Rigol oscilloscope ?
    Contact Rigol factory and update this thread with the feedback. Have the same scope here.
    • RRice25541
      Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
      by RRice25541
      So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
      the color is all outa wack, like the settings have been corupted,
      I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
      so
      The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
      when i bring up the menu and type the pass codes to access either mode the menu disappears...
      05-13-2022, 10:44 PM
    • Taurus12
      Optiplex 3050 micro 2 blinks followed by 3 blinks issue
      by Taurus12
      Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
      I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
      i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
      Any recommendation on what I have to do next? Thanks in advance
      06-10-2025, 05:05 PM
    • Tarot Superstars
      How not to Damage an Oscilloscope
      by Tarot Superstars
      Hello.
      I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
      I want to learn how not to damage it, and I found instructions on the internet obscure.
      They talk about ground, earth, floating ground, this, that....
      But they don't actually say anything anything useful so far.
      I want to know:
      Don't connect exactly this to exactly there or it blows up.
      For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
      I want to know what not to connect...
      08-29-2023, 02:27 PM
    • thinkcentre
      Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
      by thinkcentre
      this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
      What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
      I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
      11-09-2025, 12:39 PM
    • howardc64
      Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
      by howardc64
      Samsung have been using this style LED connector for few years now
      Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
      The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
      10-12-2025, 08:13 PM
