Vizio E390-A1 main board firmware corruption
  • crosstalk
    • Feb 2014
    • 68
    • Usa
    I got a vizio e390-a1 that wouldn't boot (power led on, no backlight). Main board 756TXCCB02K042. Based on other reports, it seemed like a firmware corruption problem. I couldn't find the firmware online, so I bought a working board on ebay for about the same price as a pre-programmed chip. Sure enough the firmware fixed the old board. Send me a PM if you need the file.
    Re: Vizio E390-A1 main board firmware corruption
    Main board for $15?
    http://www.shopjimmy.com/catalogsear...=vizio+e390-a1
    • crosstalk
      • Feb 2014
      • 68
      • Usa
      $26 delivered. I figured that was a more sure bet than just replacing the flash.
        Good price, just hope that EEPROM on this one does not go out either, hate EEPROM.
        • Shane711
          • 493
          Note: In my experience the program on the EEPROM does not go bad but the IC does. I have copied the program from the bad EEPROM IC and wrote it to a NEW IC and the TV was fixed. I am sure this is not true for all cases but it has worked for me so far. I pay about 0.25 cents for my blank EEPROMs.
          I just got this Vizio E390-A1 yesterday and I am about to try this method. The TV power indicator turns white but no backlight.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Perhaps you would be prepared to share the file. Hamie has an EEPROM thread which is being added to.
            https://www.badcaps.net/forum/showthread.php?t=59877
            • Shane711
              • 493
              I got a few files I can share. Every time I copy an EEPROM I save the file. That is after I confirm it is working.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Hello Shane
                That's excellent and could be added to Hamie EEPROM thread if that was OK with you.
                • Shane711
                  • 493
                  Copying the EEPROM for this E390-A1 did not work, like I said, it doesn't work every time. Maybe my problem is not the EEPROM but I will have to order a new one or the whole kit and find out just what the problem is.
                  I think I may have used the wrong EEPROM, I did not have a perfect match. I will order some blank ones and try again.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Sorry Shane711,
                    My request should have been made to Crosstalk.
                    • jones
                      • Jan 2012
                      • 23
                      vizio e390-a1
                      the led turns white but no picture no sound and cant turns off after that, this is how i fixed it:
                      test around the eeprom for the voltage should get 3.5 to 5v. test the connector goes to keypad board, if you click to any button should see some change in voltage 1 to 3v
                      thats mean the main board and processor are good, is just the eeprom software crashed
                      remove the eeprom read and save it to the computer, and rewrite it with the same file and it will work, can use the same eeprom.
                      if this didnt help, write another epprom with the same saved file and try
                      hope this will help someone and save the earth from waste electronics
                      • Mmcintosh01
                        • Jul 2021
                        • United states
                        Bought a vizio v435-g0 yesterday from walmart it was on clearance. Got it home connected to wifi and updated filmware and now tv is stuck on vizio logo screen. From what I'm seeing people say it's a corrupt main board is there anyway to fix filmware through usb?
                        • lotas
                          • Jan 2016
                          • 4900
                          • Russia
                          https://support.vizio.com/s/article/...language=en_US
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            I wound up with this same model V435-g0 stuck on the logo screen. I downloaded the firmware from the webpage above, made sure my thumb drive was FAT formatted, extracted the 2 files to the thumb drive, put the drive in the TV and plugged it in. It turns on by itself after AC power is applied. The indicator light on the thumb drive flashed 11 times and the TV doesn't download $hit.
                            Vizio TVs are worthless as tits on a chicken. Honestly I'd like to have two of them....one to $hit on and one to cover it up with, like a cat does a turd in a god d@mn sandbox. I've read new TVs of this model getting a firmware update during their first setup then restarting only to freeze on the Vizio logo.
                            What a crock...an absolute crock!
                            They call me......."threadkiller"
                            • joby91
                              SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                              by joby91
                              I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                              I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                              I found one chat about firmware on ************** forum but i cannot read the comments.
                              https://**************/forum/108-114100-1#880537
                              09-04-2024, 01:34 PM
                            • howardc64
                              HiSense 65H6510G no boot
                              by howardc64
                              TV standby light flash once after plug-in AC power. Then silent. No backlight, no LCD image on flash light test, no SPDIF light.
                              All PSU voltages to main looks good (12v, 20v (label says 18v but is 20), standby voltage) Probing main board shows what appears to be a DCDC converter (MSH6103A can't find datasheet) providing 5v, 3.3v and 1v. 5v present to the standby light power switch board.
                              These HiSense TVs appears to have lots of firmware corruptions that takes out the main board either through smartTV use or firmware update. Used main board...
                              03-29-2023, 12:52 PM
                            • GardevoirForEver
                              Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                              by GardevoirForEver
                              I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                              Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                              The motherboard of my ASUS...
                              11-15-2025, 04:30 PM
                            • jason123
                              Vizio D50-F1 - Can't update Software / Firmware
                              by jason123
                              Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
                              I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
                              I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
                              08-15-2021, 06:48 AM
                            • Lee M.
                              Vizio E55-DO firmware corrupted?
                              by Lee M.
                              I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find...
                              04-02-2023, 03:12 PM
