Vizio D50-F1 - Can't update Software / Firmware
  • jason123
    • Oct 2015
    • 1083
    Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
    I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
    I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
    When I check the System Info, still lists V1.0.6 as current firmware (so process never completes)
    Got with Vizio Tech support - had me reset the TV (Back to Factory Reset) and the TV is doing exactly the same as above. They suggested I schedule service!
    Any thoughts on what can be wrong? I recall years ago a TV had "Allow FW update set to Disabled" in the service menu. Can't seem to get there.
    Also, I couldn't find earlier firmware for this TV. I'm thinking jumping from 1.0.6 to 2.60.23-1 maybe a big jump and if I can gradually get there, it might work.
    Help is always appreciated! Thank you
  • jason123
    • Oct 2015
    • 1083
    Re: Vizio D50-F1 - Can't update Software / Firmware
    If anyone has a way to access service menu, or has service manual, that would greatly help! menu 1 9 9 9 and others simply don't get you anywhere
    • jason123
      • Oct 2015
      • 1083
      No Vizio people out there
      • lotas
        • Jan 2016
        • 4708
        • Russia
        https://factory-reset.com/wiki/Vizio_Service_Menu
        • jason123
          • Oct 2015
          • 1083
          Thanks... none of these methods seem to work on this D50-f1
          • alfatv
            • Sep 2020
            • 353
            Try to press "last" or "return" button after digits
            • jason123
              • Oct 2015
              • 1083
              Thanks... just tried no luck
              • jason123
                • Oct 2015
                • 1083
                Only methods 3-6 are applicable as there is no "Ch+" or "Ch-" on this TV.
                Return (Enter / OK) or Back don't seem to make a difference. I don't see any special menus pop up.
                • jason123
                  • Oct 2015
                  • 1083
                  Does anyone know where this firmware is stored? is it in the nand flash? This board has an ARM processor and a Kingston EMMC04G-M627-M06U drive. Was curious if anyone had any luck programming this firmware with development tools? or if even worth it?
                  • lotas
                    • Jan 2016
                    • 4708
                    • Russia
                    It has no NAND, the firmware is in EMMC (Kingston EMMC04G-M627-M06U).
                    • TheUser
                      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                      by TheUser
                      Hello to everyone ,
                      This is my first post here, and i would like to share with you a small story in case you can help me.
                      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                      02-10-2024, 02:07 PM
                    • rumpumpel1
                      ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                      by rumpumpel1
                      Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                      10-24-2024, 08:59 AM
                    • dkneyle
                      Sony KDL-46HX850 Can't upgrade/update firmware
                      by dkneyle
                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                      09-25-2024, 10:44 PM
                    • pp74
                      Marantz NR1508 USB firmware update image
                      by pp74
                      Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
                      Regards
                      05-10-2025, 11:55 PM
                    • Faluky
                      firmware for Marantz SR5008 stuck in update loop
                      by Faluky
                      After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
                      Best regards.
                      Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
                      01-17-2023, 04:33 AM
