SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
  • joby91
    • Sep 2018
    • 43
    • german
    I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
    I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
    I found one chat about firmware on ************** forum but i cannot read the comments.
    https://**************/forum/108-114100-1#880537
  • imran333
    • Apr 2012
    • 48
    Did you get the dump ?
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
    • saghi88
      i need eMMC Dump for Sony KDL-55W805C
      by saghi88
      The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
      This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
      does anyone have the EMMC dump file?
      Model: Sony KDL-55W805C
      Mainboard: 1-980-805-31
      EMMC: SK HYNIX H26M52103FMR
      Display-Panel: T550HVF06.0
      07-04-2025, 02:11 PM
    • mhd bero
      Sony KD-65XD8505 EMMC NEED
      by mhd bero
      Hi.
      I'm searching for an eMMC dump for Sony KD-65XD8505
      Motherboard: 1-980-832-11
      THE TV NO BOOTING HE HAVE 8 TIME RED LED BLINKING I THINK EMMC DUMP FILE IS DAMAGE.
      Thank you.
      09-09-2025, 09:31 AM
    • 5m44p1x
      Looking for Sony KD-55X750F EMMC dump
      by 5m44p1x
      The TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
      Model: Sony KD-55X750F
      Mainboard: 1-982-454-11
      EMMC: SK HYNIX H26M52208FPR
      08-01-2025, 12:26 AM
    • Morosan Dimitrie
      Sony KDL 55W-955B Sony EMMC dump search :)
      by Morosan Dimitrie
      Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
      KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,...
      06-08-2024, 04:13 PM
