LG 32LC46 Model 32LC46-ZC not turning on or showing any sign of life.
  • stephenc
    • Oct 2015
    • 27
    This 7 year old TV is like new, but sadly doesn't work at all. Just to be clear, there is absolutely no sign of power.
    It just would not switch on one day. I moved it about and it came on but then went off.
    I replaced the power cable and even removed the back to ensure there was life going to the power supply (which there is) but am frightened to go any further.
    Any advice on next step would be greatly appreciated.
    With some research, I found a manual at http://elektrotanya.com/?q=showresul...oria=&kat2=all
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 32LC46 Model 32LC46-ZC not turning on or showing any sign of life.
    Do you have standby Led ?
      How about uploading good clear pictures so we will know what we are dealing with?
      • stephenc
        • Oct 2015
        • 27
        Actually I'd forgotton that if you tap it hard on a work bench (which I've just done) you can get the power LED to come on, but as you move it around it goes off again and you have to give it another sharp tap or bang.
          Bad connections, bad mounting screws for the circuit board grounding, bad connection on the connectors, etc. you will need to do really good visual inspection.
          • stephenc
            • Oct 2015
            • 27
            images attached - even when there is no sign of power and the LED light won't come on there is still 240V on either side of the fuse as shown.
              OK.
              1) The connectors of the power supply have labels for each pin to tell us what they are, you need to check the DCV of each pin to see if any of them has any DCV on them.
              You will need to report the readings and you MUST pin the pin number and pin names AFTER each pin so we can see what is present and what is not present.
              2) What is the power supply board P/N as shown on the barcode sticker?
              • stephenc
                • Oct 2015
                • 27
                Originally posted by budm
                OK.
                I'm not sure I fully understand this? Is DCV the DC voltage across the connector block? Do I just stick the probes up the connector block? If so, should I set the multimeter to DC which seems odd as it's 240V AC.
                By the way, I've checked and there is full continuity from the pins right back to the plug which goes into the wall socket.
                The part number looks like B791B330585010904 and I've tried to attach an image of it.
                • stephenc
                  • Oct 2015
                  • 27
                  Not sure if this is what you have asked for but the blue negative cable has a label with E13933B (or maybe the B is an 8). There is NO AC voltage between it and earth chassis.
                  The red live cable has a label with 600V FT1 22AWG and it has 232V AC between the terminal and earth chassis.
                  • stephenc
                    • Oct 2015
                    • 27
                    Anyone any suggestions where I go from here please?
                    • Rickig
                      • Mar 2015
                      • 112
                      • England
                      I think what budm is asking is next to the white connectors on the top right of the power supply is writing (printed on the board) which tells you what each pin does.
                      What are those? Ie top pin (1) =
                      And so on
                      • stephenc
                        • Oct 2015
                        • 27
                        Apologies for confusion. I have now attached an image of the pins for the 2 connector blocks. Their details are below -
                        1 AOC - 5.09
                        2 ON/OFF - 0
                        3 ST 5V - 5.09
                        4 GND - 0
                        5 I-C - 0
                        6 ERR - 0
                        7 I-B - 0
                        8 ST 5V - 5.09
                        9 GND - 0
                        10 DIM - 0
                        11 6V - 6.08
                        12 GND - 0
                        13 ???? - 0
                        1 19V - 18.47
                        2 19V - 18.44
                        3 GND - 0
                        4 GND - 0
                        5 6V - 5.95
                        6 GND - 0
                        7 3.4 - 0
                        8 GND - 0
                        9 12V - 11.82
                        10 GND - 0
                        To take these DC voltage readings, I removed the connector blocks from the board and connected the probes between the earth chassis and each pin in turn.
                        Pin 7 on the second block should I assume have a 3.4V but has 0
                        • stephenc
                          • Oct 2015
                          • 27
                          Just to follow up on earlier posts -
                          1 There definitely seems to be a bad connection somewhere as I can easily get it to come on and off by a sharp tap on the worktop.
                          2 When it comes on, there is 3.4V from Pin 7
                          Should I assume it is definitely in the power board and order a new one??
                            OK, you need to have all the connectors in place and then take the readings again because the main board sends some command signals to the power supply board and the backlights circuit. So far you do have STANDBY Voltage.
                            • stephenc
                              • Oct 2015
                              • 27
                              OK thanks budm, I've now taken another 2 sets of readings -
                              1 With the power connected but the TV in the fault state.
                              1 AOC - 4.5
                              2 ON/OFF - 0.04
                              3 ST 5V - 4.5
                              4 GND - 0
                              5 I-C - 0.03
                              6 ERR - 0
                              7 I-B - 0
                              8 ST 5V - 4.5
                              9 GND - 0
                              10 DIM - 0
                              11 6V - 0.01
                              12 GND - 0
                              13 ???? - 0.04
                              1 19V - 0
                              2 19V - 0
                              3 GND - 0
                              4 GND - 0
                              5 6V - 0.1
                              6 GND - 0
                              7 3.4 - 0.05
                              8 GND - 0
                              9 12V - 0
                              10 GND - 0
                              2 With the power connected, TV knocked on the bench and the pilot light on.
                              1 AOC - 5.04
                              2 ON/OFF - 2.8
                              3 ST 5V - 4.98
                              4 GND - 0
                              5 I-C - 4.93
                              6 ERR - 0
                              7 I-B - 0
                              8 ST 5V - 4.98
                              9 GND - 0
                              10 DIM - 0.44
                              11 6V - 6.33
                              12 GND - 0
                              13 ???? - 0.04
                              1 19V - 18.51
                              2 19V - 18.51
                              3 GND - 0
                              4 GND - 0
                              5 6V - 6.34
                              6 GND - 0
                              7 3.4 - 3.43
                              8 GND - 0
                              9 12V - 12.35
                              10 GND - 0
                              • stephenc
                                • Oct 2015
                                • 27
                                Anybody any thoughts on the next step please?
                                  https://www.badcaps.net/forum/attach...8&d=1444936903
                                  What is that hanging red wire from the inverter board?
                                  So you do have pilot lights, one signal that does not look right to me is the:
                                  10 DIM - 0.44 which looks to be too low for the backlights Dimming signal.
                                  BTW: 1 AOC - 5.04 is actually ADC (AC DETECT signal).
                                  Your Voltage readings looks normal except the DIm pin 10.
                                  • stephenc
                                    • Oct 2015
                                    • 27
                                    There is both a red and a black wire suspended neither of which look as if they have ever been connected.
                                    The part number looks like B791B330585010904 and I tried to attach an image of it in an earlier post.
                                      Sorry, I found the board on SHOPJIMMY.
                                      Those wires should not be floating around like that, need to find which pins on the inverter connector they are connected to. Did any one else work on this TV before you?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        in this thread post 14 first picture it shows the red and black wires connected? are these connected on your set
                                        https://www.badcaps.net/forum/showth...ight=LG+32LC46
                                        can you post a clear picture ot that connector on your set?
                                        • jason123
                                          Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
                                          by jason123
                                          Hi Folks,
                                          I have a 65" newer (2021 model) that has no sign of life. No backlight, no front LED (assuming it has one) and no audio or turn on chime.
                                          Photos below of the system
                                          The CN6401 Connector has the following vitals:
                                          STBY_3.3V is 3.432 V
                                          BL_ON low (0.153 V)
                                          BL_ERR low (0.051V)
                                          POWER_ON 3.42 V (as soon as I plug it into the wall this comes on)
                                          REG12V pins 12.7 V
                                          TCON_VCC12V pins low (0.11V)
                                          TCON_ON low (0.155)
                                          Large caps are at 392V as soon as I plug into power
                                          Seems like a Mainboard...
                                          09-08-2024, 07:05 PM
                                        • Francisc Records
                                          Asus N751JK no power, no sign of life
                                          by Francisc Records
                                          First of all im glad i've found this forum and i'm happy to start learning new things and sharing my knowledge with others!
                                          Long story short : I have a laptop from work that has no power and no signs of life. My first question is: A 90W charger(19V 4.5A) is enough for this laptop? Because the original charger was 19V 6,4A(120W), so all the testing was done with the 90W charger because i don't have a 120W charger.
                                          This being said, i opened up the laptop and i've inspected the MB and the components, everything seems fine, no sings of explosion, burn,...
                                          03-27-2025, 01:44 AM
                                        • alltvrepairs
                                          JVC lt-32vah3000 no sign of life apart from Digital Audio Laser port is lit RED
                                          by alltvrepairs
                                          HI,
                                          Have this set that does not respond to remote functions. It is either bricked or main faulty as the power supply is on and mainboard supplies seem present. I have noticed the red light from the digital audio out.
                                          This is an android on a vestel main board 17MB171
                                          Regards,
                                          Darren...
                                          01-31-2025, 09:58 AM
                                        • pc_okay
                                          LENOVO LEGION HY660 NM-D562 REV3.0 Power on but no sign of life
                                          by pc_okay
                                          I have this board, power button light on only when pressing power button, no fan spinning, nothing else.
                                          I mesure those signals:
                                          • ON/OFF# react normaly
                                          • EC_RSMRST# 1.69V
                                          • RTC_CLK missing
                                          • PBTN_OUT# 3V when plug power but stay stuck at 0V after pressing button
                                          • PM_SLP_S5# PM_SLP_S3# SYSON all missing...
                                          I have a doubt on the cristal YC1, i see 1.77V on pin 2 and only 0.64v at pin 1 with a dirty oscilation fluctuating between 4 and 25khz
                                          Cristal YC2 have 0.86V on both pin 1 & 3 with a clean oscilation at 48Mhz.
                                          Any help please ?
                                          12-09-2024, 05:26 AM
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
