JVC lt-32vah3000 no sign of life apart from Digital Audio Laser port is lit RED
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    HI,
    Have this set that does not respond to remote functions. It is either bricked or main faulty as the power supply is on and mainboard supplies seem present. I have noticed the red light from the digital audio out.
    This is an android on a vestel main board 17MB171
    Click image for larger version  Name:	image.png Views:	0 Size:	223.6 KB ID:	3561210
    Regards,
    Darren
  • Dimon bos
    • Mar 2025
    • Молдова
    Добрый день .
    умение такая же проблема .как вы её решили
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8349
      Sounds bricked to me. Had same thing on a TCL.
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • i_am_patch
        Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
        by i_am_patch
        Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
        04-30-2024, 08:20 PM
      • Bektronics
        Schematic Digital Audio mixer RCF type M18
        by Bektronics
        Hello dear audio friends.
        I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
        The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
        I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
        Thanks in advance if anyone can help me with this schematic.
        Of course, all information about this digital mixer and possibly references...
        07-24-2023, 06:40 AM
      • UserXP
        Vintage SONY Digital Clock Radio ICF-C12W no audio
        by UserXP
        Dear all,
        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
        My question is, do you know of this brand of capacitors and how bad are...
        07-21-2025, 08:35 AM
      • silver60618
        Macbook M3 A2991 Speaker Audio Amplifier IC
        by silver60618
        Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
        I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
        09-26-2025, 12:25 PM
