Asus N751JK no power, no sign of life
  • Francisc Records
    • Mar 2025
    • 5
    • Brasov
    First of all im glad i've found this forum and i'm happy to start learning new things and sharing my knowledge with others!
    Long story short : I have a laptop from work that has no power and no signs of life. My first question is: A 90W charger(19V 4.5A) is enough for this laptop? Because the original charger was 19V 6,4A(120W), so all the testing was done with the 90W charger because i don't have a 120W charger.
    This being said, i opened up the laptop and i've inspected the MB and the components, everything seems fine, no sings of explosion, burn, or ripping. Then i proceed in measuring the input voltage and output voltage of first and second mosfets, everything seems ok. After a while i noticed that the laptop is taking 0.16 amps all the time, so it must be a shorted ground. Finally i've found that the tps51285a ICs pin 13 (+5VAO) is shorted to ground. Could this be the issue?
    I measured resistances relative to the ground of the IC tps51285a:
    1 CS1 = 39k
    2 VFB1 = 6k
    3 VREG3 = 35k
    4 VFB2 = 9.4k
    5 CS2 = 15k
    6 EN2 = 350k
    7 PGOOD = 17.7k
    8 SW2 = 15k
    9 VBST2 = 45M
    10 DRVH2 = 126k
    11 DRVL2 = 45k
    12 VIN = 2M
    13 VREG5 = 3.2 !!!!!!!!!!
    14 VO1 = 15k
    15 DRVL1 = 140M on pin but 4,7 Ohm on PQ8103
    16 DRVH1 = 66M and rising -> but 130k on PQ8102
    17 VBST1 = goes over 200M
    18 SW1 = 15k
    19 VCLK = 66k
    20 EN1 = 300k
    The output voltage of the 3.3V pin is correct.
    The output voltage of the 5V pin shows 0.5V
    The battery pins voltage on the MB shows 2.6V
    At this point i have no clue where exactly is the short to ground, i know it's on the 5V rail but can it be the IC's fault?
    Thanks in advance.
    Link to boardview https://www.badcaps.net/forum/docume...ptop-boardview
  • mon2
    • 14213
    Hi. Welcome to the forum. Good work on the review.
    yes, this rail is shorted. Often the 5v rail is shorted due to the usb port which are linked to failed usb load switches. These are current limit switches.
    Continue your review to inspect each vbus pin on each usb connector. Also shorted? Test the resistance to ground. Next, take a pic of the local parts of the usb connector before reworking. Flux and remove the load switch. Measure the resistance again. If ok, power up but the 120w adapter should be used.
    • Francisc Records
      • Mar 2025
      • 5
      • Brasov
      Resistance from gnd to Vusb for each usb is 1.6-1.8M
      Resistance from the +5VAO pin of the chip to ground is 4.5 ohm (yesterday was 3.2 ohm)
      +5VAO is going to a single capacitor (MLCC 4.7UF/6.3V), i thought that capacitor is shorted so i desoldered it, i still have the short. According to the schematics, the +5VAO is not going anywhere else.
      I injected 1V on the +5VAO pin, and the only thing heating up was still the IC, so at this point i'm 90% sure the IC is shorted to ground. I won't mind for any suggestions though .​
      • mon2
        • 14213
        You may be right. Suggest to take pics of this regulator area and use low air pressure but high enough heat to melt the solder and remove without disturbing other parts in this region. Watch the pin #1 location for the future replacement. Then be sure the PCB pads are not shorted and test (without power) the resistance to the same rail. Was the short removed? If not, keep injecting a low voltage.
        You are getting close...
        • Francisc Records
          • Mar 2025
          • 5
          • Brasov
          Indeed. Thanks for the tips and suggestions.
          I ordered the IC. Now i hope it's shorted, because I've spent way too much time diagnosing this laptop. I'll keep this thread up to date.
          • Francisc Records
            • Mar 2025
            • 5
            • Brasov
            After removing IC short to ground disappeared. I'm waiting for the new IC to arrive and probably the laptop is fixed.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Reminder-dont power up up the pc without this 3/5V regulator soldered. Else the mb may become unrepairable.
              Lot of guys commit this mistake.
              • Francisc Records
                • Mar 2025
                • 5
                • Brasov
                Replaced IC, now I have a short on the main power rail. A P2003BEA mosfet is heating up and it shuts down the power every few seconds (main power tries to rise, gets cut at 1.5V. At this point I don't think its feasible to continue working on this laptop.
                  ASUS N751JK-T7052H Notebook Specification for Upgrade or Repair
                  This specification for the ASUS N751JK-T7052H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N751JK-T7052H boardview and N751JK-T7052H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-06-2024, 06:20 AM
                • yayayee
                  ASUS GU502GV not powering on - 1285A hot
                  by yayayee
                  I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                  So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                  I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                  01-08-2024, 11:04 PM
                • barry101
                  Apple 820-3662 VCore shorted to ground.
                  by barry101
                  Hi, Would appreciate some help.
                  I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                  Get charger light but no fan spin or chime. No liquid damage.
                  Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                  Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                  With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                  Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                  06-24-2025, 07:34 AM
                • Chaks
                  Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
                  by Chaks
                  TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
                  The specs says ...
                  High antenna efficiency 868MHz ISM Band
                  5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
                  The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
                  1. Should I Fix it with a glue.
                  2. Should I fix it with a double side adhesive tape
                  3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
                  12-09-2024, 11:06 AM
                • someonenotyou
                  Dell Vostro 3501 - no signs of life after BIOS read
                  by someonenotyou
                  Hi.
                  I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                  Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                  After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                  Then I took the motherboard out...
                  01-27-2025, 05:15 AM
