Sharp aquos LC-40LE810E
  • Nightmare0
    • Oct 2015
    • 39
    • Slovakia
    #41
    Re: Sharp aquos LC-40LE810E
    Wow. You guys are awesome ! Real professionals.
    I took out pin 9 - AC-DET an just plugged it next to pin 11 - 5v. Without any soldering. It's just touching and TV has started up. Everything seems to be working.
    I will test it tomorrow. If you want, I can make some measurements for you. Is there anything that I should check before soldering it? I will also keep that 68k resistor and optos for future.
    /edit
    I added quick photos I will post more, when You allow me to solder that.
    • rievax_60
      • May 2012
      • 897
      • australia
      #42
      If you do not restore proper function of the AC-DET, you will risk EEPROM corruption. Your TV will have similar function to that of a brick.
        Glad to hear, so now we know that it is the AC-DET failure only, so it is either the resistor for the circuit is marginal or changed in value (goes higher resistance), or bad opto per suggestion by other members.
        The purpose of the AC-DET is not to allow the TV to come on if the AC Voltage feeding the TV is too low, so right now it is the protection circuit is causing the fault due to its own failure.
        • rievax_60
          • May 2012
          • 897
          • australia
          #44
          The function of the AC-DET is also to warn the controller of imminent loss of supply rails so that it wont risk writing to memory resulting in corruption.
          • Nightmare0
            • Oct 2015
            • 39
            • Slovakia
            #45
            I was celebrating too soon.
            I changed all optos. Measured all pins...getting same voltage on all pins like before. Tried that magic trick with resistor again, but this time tv didn't turned on. Not even led. Just red led on mainboard.
            I put all original optos back. Same... Red led on mainboard. When start without that resistor trick, tv is still flashing with same error.code. getting same voltages. Just resistor trick doesn't work anymore.
            Could I burn optos? Or I really screwed something? I will send you photos tomorrow, I am sad and tired, so I am going to sleep now. But there weren't any cold joints, bridges, used flux, everything seemed nice.
            • rievax_60
              • May 2012
              • 897
              • australia
              #46
              The first thing to check is that the optos are fitted the correct way. They dont all face the same way. Take a clear photo of the top before you do anything else.
              • fzabkar
                • Mar 2009
                • 772
                "I took out pin 9 - AC-DET an just plugged it next to pin 11 - 5v. Without any soldering. It's just touching and TV has started up. Everything seems to be working."
                The AC-DET signal is normally tied to the supply via a pullup resistor. By connecting pin 9 directly to the BU5V supply pin, you would have impressed the supply voltage directly onto an MCU GPIO pin. This is not always a safe thing to do.
                Edit: IC2002 is powered from BU+3.3V, so impressing BU5V onto its AC_DET pin would have resulted in latchup without any current limiting. I could be wrong, though.
                • Nightmare0
                  • Oct 2015
                  • 39
                  • Slovakia
                  #48
                  Here are photos, after I changed all optos. I noticed they are not same brand. 2 of them were sharp and 2 of them different. Also I checked if I am fitting them in correct way. There is sign 1 on motherboard for dot in left top corner. Also there are marks on side and motherboard like half circle. So I am sure I fitted them correctly.
                  • Nightmare0
                    • Oct 2015
                    • 39
                    • Slovakia
                    #49
                    Here are photos after I put all original optos back. You can check, they are in same position. I added photo from shopjimmy so you can check they are really in proper way. Also photo of that red led. Red led is not still on. It is flashing like: maybe 20 seconds on, off for few seconds afaing 20 seconds..... after few flashes, led will turn off and nothing else happens.
                    I was not using TV with this fix. I tried that once, when I first tried for maybe 30 seconds until I took photo.
                    After opto change, it started to act like that. So how bad is it? All pins have same voltage. If you need more info just let me know.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      #50
                      Originally posted by Nightmare0
                      (PD-1-2)UR13.2V(SIGNAL): 12.9V
                      (PD-3-4)S13V.2(AUDIO): 12.9V (its not misspelled, its written like this)
                      (PD-5-6)SGND(AUDIO): 0V
                      (PD-7-8)SGND(SIGNAL): 0V
                      (PD-9)AC-DET: 0V
                      (PD-10)PS-ON: 3V
                      (PD-11)BU5V: 4.9V
                      (PD-12)PNL-POW: 0V
                      What are these voltages now? Keep in mind that some of these voltages might not stay up for long after the mains is applied.
                      I think AC-DET can only be high when PS-ON is high. It has been a few months since I worked on s similar model here.
                      • Nightmare0
                        • Oct 2015
                        • 39
                        • Slovakia
                        #51
                        (PD-1-2)UR13.2V(SIGNAL): 13.01V
                        (PD-3-4)S13V.2(AUDIO): 13.01V
                        (PD-9)AC-DET: 0V
                        (PD-10)PS-ON: 3V
                        (PD-11)BU5V: 4.99V
                        (PD-12)PNL-POW: 0V
                        I am getting these voltages only when I plug tv to power. Because after while, tv will show error code and only 5v is present. Should I try that resistor on top of that second resistor?
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #52
                          (PD-9)AC-DET: 0V
                          (PD-10)PS-ON: 3V
                          (PD-11)BU5V: 4.99V
                          (PD-12)PNL-POW: 0V
                          Yes, try that. We need to see AC_DET go high, Also measure the voltage on both pins on the middle opto on the secondary side, the side that is closer to the power supply output. Normally they should be 5v and something a bit lower than 5v.
                          Although it seems that you have another fault also.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #53
                            The opto for the AC-DET is PC7703
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #54
                              I made a mistake before. PC7703 is the lower one.
                              • Nightmare0
                                • Oct 2015
                                • 39
                                • Slovakia
                                #55
                                Ok, i will do that as soon I will get from work.
                                I don't know how these optos work. Which legs should I measure? I will post results of all optos, so you can check that.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #56
                                  You can do a search on the part number or "opto coupler". Measure pins 3 and 4 of PC7703.
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    If the "resistor trick" doesn't work anymore, then I can't see how modifying the sensitivity of the optocoupler will change anything. ISTM that there is now a problem on the main board.
                                    I would check whether AC_DET is shorted to ground on the main board.
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #58
                                      Yes, that is a good idea. I keep thinking about damage on the main board also. I dont understand why there should be damage because he used a series resistor.
                                      • Nightmare0
                                        • Oct 2015
                                        • 39
                                        • Slovakia
                                        #59
                                        PC7703 legs 3 -2.1V and 4 -4,9V
                                        Should I solder that 68k resistor on top of other now?
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #60
                                          Yes, solder in the resistor. pin 3 on the opto needs to be well over 2.5v.
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
                                          • olegeisler
                                            SHARP AQUOS LC-70LE836S only blinking - freebie
                                            by olegeisler
                                            Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                            Symptoms :
                                            When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                            A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                            Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                            As I see it mainboard has some kind of life, but does not...
                                            07-23-2022, 07:01 AM
