Sharp aquos LC-40LE810E
+ More Options
Posts
    Re: Sharp aquos LC-40LE810E
    OK: These are are the pin names.
    PD connector
    PIN 1 - 12,9V UR13.2V (SIGNAL)
    PIN 2 - 12,9V UR13.2V (SIGNAL)
    PIN 3 - 12,9V S13.2V (AUDIO)
    PIN 4 - 12,9V S13.2V (AUDIO)
    PIN 5 - 0V SGND (AUDIO)
    PIN 6 - 0V SGND (AUDIO)
    PIN 7 - 0V SGND (SIGNAL)
    PIN 8 - 0V SGND (SIGNAL)
    PIN 9 - 0V AC-DET:
    PIN 10 - 3V PS-ON
    PIN 11 - 4,9V BU5V
    PIN 12 - 12V PNL-POW
    According to the flow chart page 6-1 of the service manual:
    'Is there the pins (9/AC_DET) of P9601 at “H”? So check pin 9 of P9601 (MAIN BOARD CONNECTOR), more likely to show 0Vdc. It should be >2Vdc for NORMAL.
    • freakaftr8
      • Oct 2012
      • 3743
      13.2 volts does travel to the t-con board correct? Try this disconnect both ribbon cables that lead from the tcon board into the panel. On your model in maybe 2 flat ribbon cables and maybe 4. Then power it up and see if you get a solid white led with backlight
        I think he may have AC-DET error problem.
          Pin 12: 12V PNL-POWER is the one for the T-CON.
          • freakaftr8
            • Oct 2012
            • 3743
            Yep just caught that one. Lol
              If I am correct, he should be able to pull AC-DET HIGH by removing the AC-DET wire from the PD connector and then connect that wire to a 330~1K resistor, another end of the resistor is BU5V and see what happen.
              There is also this thread that I found about AC-DET for the same TV model:
              https://www.badcaps.net/forum/showth...AC-DET&page=14
              • Nightmare0
                • Oct 2015
                • 39
                • Slovakia
                #27
                (PD-1-2)UR13.2V(SIGNAL): 12.9V
                (PD-3-4)S13V.2(AUDIO): 12.9V (its not misspelled, its written like this)
                (PD-5-6)SGND(AUDIO): 0V
                (PD-7-8)SGND(SIGNAL): 0V
                (PD-9)AC-DET: 0V
                (PD-10)PS-ON: 3V
                (PD-11)BU5V: 4.9V
                (PD-12)PNL-POW: 0V
                • Nightmare0
                  • Oct 2015
                  • 39
                  • Slovakia
                  #28
                  I am sorry, but pin 12 has 0V. I misspelled that, since I was posting from mobile phone from work
                  • Nightmare0
                    • Oct 2015
                    • 39
                    • Slovakia
                    #29
                    So you want me to cut trace leading to AC-DET. Then connect AC-DET pin to BU5V pin with resistor. Right?
                      Remove the PD-9 wire from the FEMALE connector that goes to the MALE PD connector on the power supply board and then attach the resistor to that wire, another end of the resistor to STNDBY5V, do not cut the trace.
                      PNL-POWER may be another problem.
                      • Nightmare0
                        • Oct 2015
                        • 39
                        • Slovakia
                        #31
                        Okay. I understand. But all resistors I currently have are much over 1kohm (10,21,....)
                        I will be able to get resistor tommorow or monday. As soon I will get resistor I will post results. If I buy 500ohm, is it ok?
                        And what about that PNL-POWER?
                          Anything between 330~1K will be fine.
                          "And what about that PNL-POWER?" That is another problem.
                          So so far you do have power supply board problem due to AC-DET circuitt, and then then PNL-PWR problem.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #33
                            If it is the AC-DET problem, I recommend that all 4 optos be replaced. Read the other thread.
                            • Nightmare0
                              • Oct 2015
                              • 39
                              • Slovakia
                              #34
                              What are optos, are they easy to get and replace? How much they cost? won't be easier to buy whole power supply?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #35
                                The full name of the part is "opto-coupler". Did you look at the other thread? it explains more including a temporary fix. All if your TV has the same problem.
                                • Nightmare0
                                  • Oct 2015
                                  • 39
                                  • Slovakia
                                  #36
                                  not yet. I will read whole thread soon.
                                  you mean that 68k resistor fix? I can try that. Also can you help me to find replacement for optocouplers? In that thread someone use PC817. Can I try them too?
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #37
                                    That's right, the 68k is soldered on top of the the existing 82k or replace it totally with a 33k. Its best to search for the PC817 opto to find what's best available in your area.
                                    Or just play it safe and do nothing else if the resistor mod works.
                                    • fzabkar
                                      • Mar 2009
                                      • 772
                                      Couldn't the main board be switching off PNL-PWR in response to the AC-DET failure?
                                        I do not know what the main board will do when it detects AD-DET problem, I would it should take away the PS-ON signal and then blink and error code, but in this one the PS-ON is still present, it may be true that it will shut down the panel Voltage, that is why he need to fool the main board that AC-DET is OK by pulling the line high and see what will happen next which is what I am waiting to see the result when he gets the resistor.
                                        I believe PNL-PWR is the command pin form the main board, there should be another connector on the power supply board with '12V_PNL' that goes to the T-CON board.
                                        • Nightmare0
                                          • Oct 2015
                                          • 39
                                          • Slovakia
                                          #40
                                          Ok. I have bought resistors. 560 ohm for AC-DET fix.
                                          Also bought 68k smd resistor and also 33k and 4 opto-couplers.
                                          First I will fix that AC-DET and will post results.
                                          Also I got crazy idea. If everything fails, is it possible to buy some lvds to hdmi converter and use this tv only for set-top box? I don't want to do that now. Just if it is possible
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
                                          • olegeisler
                                            SHARP AQUOS LC-70LE836S only blinking - freebie
                                            by olegeisler
                                            Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                            Symptoms :
                                            When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                            A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                            Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                            As I see it mainboard has some kind of life, but does not...
                                            07-23-2022, 07:01 AM
