Sharp aquos LC-40LE810E
  • Jstone86
    • Jul 2018
    • 20
    • Ghana
    #141
    Re: Sharp aquos LC-40LE810E
    Originally posted by budm
    Next is to keep the DCV meter on the PL connector, remove the ribbon cables between the LCD panel and T-CON to see if the PL connector will jump up to 12VDC or not when TV is turned on.
    BTW, did you do the test with the dummy load?
    After I removed the ribbon cable between lcd and tcon board I got same voltage 0.67v.i couldn't do the dummy test cuz I was waiting for the KIA378R12PI ic I ordered from online. Even then am confused on how to do the dummy test cuz I am a novice so if you can please upload any pics /vdeo or link to any post here with instructions on how to do the dummy test. Thanks
    • marksik
      • Jun 2019
      • 27
      • Spain
      #142
      HI guys.
      I have the same problem as topic starter.
      I already replaced resistor r7019 to new one (33k), also used 560 ohm resistor for this trick with 9-11 cables. I think that after this trick with cables (but before 7019 resistor replacement) I saw that screen turned on for couple of seconds.
      But it was only once. After resistor replacement TV still doesn't work. When I turn it on, for 7 seconds its front V-light turns on without flashing. Also I see that red LED on motherboard turns on after 5 seconds. And then red LED turns off and V-light starts blinking (2 short blinks then nothing, then again 2 short blinks and again).
      Then, if I press Power button on its remote for 2 second, V-light turns off then turns on without flashing, and LED on motherboard turns on and we have the same story as I described above.
      Help me please.
      P.S. I didn't replace optos, just bought them at AliExpress.
      • marksik
        • Jun 2019
        • 27
        • Spain
        #143
        Update. I tried Vol - CH + Power trick. Screen backlight turned on but no image. Just brigth screen. Red LED on motherboard blinking with 5 sec period. When I turn the TV off with remote, it turns off, then U can turn it on again (without image).
        But if I use its hardware button and turn it off, it doesnt turns on again, I have to use Vol - CH + Power trick again.
        • marksik
          • Jun 2019
          • 27
          • Spain
          #144
          And the same happens if I put back cable #9 without resistor. I can turn on the backlight but with no image.
          • Aussie_Matt
            • Aug 2019
            • 7
            Hi guys, I have a Sharp LC
            • Aussie_Matt
              • Aug 2019
              • 7
              Hi guys I have a sharp LC-40LE820X, and the main power board is a DPS-126CP B.
              I can display pictures from a usb for hours on end.
              When on TV function, after a period of time (20 minutes or so) the picture becomes choppy, then appears to turn off: When I try to turn it on it then has a warning similar to "service has been changed, execute auto install".
              I suspect a power supply issue: Does this sound right?
              • Aussie_Matt
                • Aug 2019
                • 7
                I've just brushed the dust off: It appears C7813 s cracked.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4542
                  • Italy - Milan
                  #148
                  Aussie: don't make confusion, you have a different issue, open up your own discussion.
                  Marksik: to make long story short, no need to change any resistors, put back the original ones, and change the optocoupler, if the AC_DET works again try the tv, if it work no more inspect/change the KIA voltage regulator..
                  • marksik
                    • Jun 2019
                    • 27
                    • Spain
                    #149
                    Davi.p, thanks for your answer. I changed all optos (4 pics) and nothing changed. Situation remaining as described above. Can you please point on KIA voltage regulator - where I can find it on the board. Did you mean 4-legs element (kia378r12) which is situated under the metal shield?
                    Thank you
                    • marksik
                      • Jun 2019
                      • 27
                      • Spain
                      #150
                      I ordered KIA378R12PI from eBay. It will come in 2-3 weeks and I will inform about results.
                      Damn, I have been waiting for optos about 1 month and now I have to wait another month
                      • marksik
                        • Jun 2019
                        • 27
                        • Spain
                        #151
                        Just measured voltage at pin 12 of that 12-pin connector and got 3,5V. Also measured pin 1 of PNL-12V connector and got 12 volts.
                        But it all drops in 5-6 seconds, so may be KIA is the real problem...
                          When the 12V at the PNL-12V disappear, is the PNL-POW (control signal to turn on the KIA switched 12V regulator IC) still around 2.5 ~ 3VDC? If the PNL-POW is <1V then there will be no 12V at PNL-12V.
                          The typical failure of the KIA regulator is that the output will be only around 7 ~ 8V when it is bad.
                          • marksik
                            • Jun 2019
                            • 27
                            • Spain
                            #153
                            When 12v disappear (it drops to 0), PNL-POW voltage drops from 3,5v to 0,13v...
                            To be more specific, I still operate with this resistors trick and I have changed all 4 optos to new ones from AliExpress.
                            Now when I turn on the TV it has its V-light solid on the front panel. Also I see red LED on the motherboard (it turns on in 3-4 seconds after TV turned on). Then, in 5-7 second red LED on the motherboard turns of and V-light on the frontal panel starts blinking (2 times then again 2 times loop). Also when red LED disappear I start to hear noise from motherboard - hi-frequency noise.
                              PNL-POW command is from main board, so when it drops below 1V then you'll not have 12V to run the T-CON.
                              • marksik
                                • Jun 2019
                                • 27
                                • Spain
                                #155
                                Could you suggest the possible fail cause?
                                For me it looks like TV starts normally, then in 5-7 second something goes wrong and TV starts blinking with its V-light.
                                  What error code are you getting?
                                  You need to report the Voltage readings on the connector of the power supply that goes to the main board.
                                  • marksik
                                    • Jun 2019
                                    • 27
                                    • Spain
                                    #157
                                    I have 2 short blinks - pause - 2 short blinks pause loop.
                                    PIN 1 - 13,05V UR13.2V (SIGNAL)
                                    PIN 2 - 13,05V UR13.2V (SIGNAL)
                                    PIN 3 - 13,05V S13.2V (AUDIO)
                                    PIN 4 - 13,08V S13.2V (AUDIO)
                                    PIN 5 - 0V SGND (AUDIO)
                                    PIN 6 - 0V SGND (AUDIO)
                                    PIN 7 - 0V SGND (SIGNAL)
                                    PIN 8 - 0V SGND (SIGNAL)
                                    PIN 9 - 4,08V AC-DET: - note - there is no cable from AC-DET side because I put it at pin 11 with resistor
                                    PIN 10 - 3,05V PS-ON
                                    PIN 11 - 5V BU5V
                                    PIN 12 - 3,27V PNL-POW
                                    • marksik
                                      • Jun 2019
                                      • 27
                                      • Spain
                                      #158
                                      I just realised that sometimes when the TV is on and I press Menu button at remote, V-light starts to blink 5 times (5 short blinks) but after 1 cycle of 5 short blinks V-light returns to its common behavior - 2 short blinks.
                                      • marksik
                                        • Jun 2019
                                        • 27
                                        • Spain
                                        #159
                                        Yep, I checked all twice. All above is correct
                                          Your post #153:
                                          Your post #157:
                                          PIN 12 - 3,27V PNL-POW conflict with your result in post # 153.
                                          So is it staying at 3.27V or it drops down to 0.13V?
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
                                          • olegeisler
                                            SHARP AQUOS LC-70LE836S only blinking - freebie
                                            by olegeisler
                                            Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                            Symptoms :
                                            When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                            A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                            Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                            As I see it mainboard has some kind of life, but does not...
                                            07-23-2022, 07:01 AM
