Sharp aquos LC-40LE810E
  • marksik
    • Jun 2019
    • 27
    • Spain
    #161
    Re: Sharp aquos LC-40LE810E
    Originally posted by budm
    Your post #153:
    When 12v disappear (it drops to 0), PNL-POW voltage drops from 3,5v to 0,13v...
    Your post #157:
    PIN 12 - 3,27V PNL-POW conflict with your result in post # 153.
    So is it staying at 3.27V or it drops down to 0.13V?
    No, there is no conflict. When I turn on TV with its hardware switch PNL-POW has 3,5v. And in 5-7 seconds after TV is on it drops down to 0,13v.
    It happens at the same time when red LED turns off and 12V at the PNL-12V drops to 0.
    May be my English is not perfect but I hope the situation is clear.
    • marksik
      • Jun 2019
      • 27
      • Spain
      #162
      Your post #153:
      Your post #157:
      So can I get some more advises?
      • marksik
        • Jun 2019
        • 27
        • Spain
        #163
        • nomoresonys
          • 12330
          • U.S.
          #164
          Wondering if they sent jstone86 a bad KIA378R12PI, it's strange that he got even less voltage after the change out.
          • marksik
            • Jun 2019
            • 27
            • Spain
            #165
            I received mine KIA378R12PI, replaced but still have the same problem
            • marksik
              • Jun 2019
              • 27
              • Spain
              #166
              Anybody can help me in this situation? May be some suggestions what's wrong with TV? is it mainboard or something else?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4540
                • Italy - Milan
                #167
                Let's try to remember this old discussion without to read back all...
                The resistor trick was a method to avoid changing the faulty opto, but you changed the optos so there's no need of the resistor, keep it out of the tv!
                • marksik
                  • Jun 2019
                  • 27
                  • Spain
                  #168
                  Yep, but I don't have old one unfortunately.
                  And I don't understand what could make the problem when voltage drops in 5 seconds after turning on.
                  Is this a power board or main board problem?
                  • marksik
                    • Jun 2019
                    • 27
                    • Spain
                    #169
                    Tried to return all original parts (except optos) and cables to their previous places. Situation is the same - after 5-7 seconds voltage drops to 0 and V-LED at fron panel starts to blink 2 times - pause - 2 times pause.
                    And I still try to find out wether it is the problem with power board or main board to be able to detect the problem.
                    • Davidpuffy12
                      • Nov 2019
                      • Portugal
                      #170
                      Originally posted by Nightmare0
                      Ok. I have bought resistors. 560 ohm for AC-DET fix.
                      Also bought 68k smd resistor and also 33k and 4 opto-couplers.
                      First I will fix that AC-DET and will post results.
                      Also I got crazy idea. If everything fails, is it possible to buy some lvds to hdmi converter and use this tv only for set-top box? I don't want to do that now. Just if it is possible
                      Do you still have the links of the things you bought to your sharp TV?
                      I have the same problem as you, and I would like to repair it.
                      • iuliantv
                        • Aug 2009
                        • 36
                        #171
                        40LE810
                        for 2 blinks change Optocoupler
                        pc7701 pc7703 pc7702 pc7901
                        mai mult ca sigur doar unul e defect,dar nu am mai stat sa vad care ,e al treilea intalnit cu acest defect,la primul ma chinuit ceva ore,acum e doar rutina
                        more than sure only one is defective, but I didn't wait to see which one, it's the third time I've encountered this defect, the first time I struggled for a few hours, now it's just routine
                        • scubacamper
                          Sharp Aquos LC-70C6400U Half Screen Dark
                          by scubacamper
                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                          05-03-2025, 12:19 PM
                        • sefoster
                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                          by sefoster
                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                          11-20-2022, 09:29 AM
                        • foxyUK
                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                          by foxyUK
                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                          10-22-2024, 10:27 AM
                        • thesharpfella
                          Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                          by thesharpfella
                          Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                          07-23-2024, 10:37 AM
                        • olegeisler
                          SHARP AQUOS LC-70LE836S only blinking - freebie
                          by olegeisler
                          Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                          Symptoms :
                          When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                          A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                          Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                          As I see it mainboard has some kind of life, but does not...
                          07-23-2022, 07:01 AM
