Sharp aquos LC-40LE810E
  • Jstone86
    • Jul 2018
    • 20
    • Ghana
    #121
    Re: Sharp aquos LC-40LE810E
    Originally posted by budm
    Since you do have 3.25V PNL-POW control signal, so do you get 12V at the PNL-12V connector pin?
    Finally I was able to located PNL-12V. I got 2 volts when I Power on the TV and it immediately drop to 0
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4540
      • Italy - Milan
      #122
      Hi, i have the same TV with same problems as Jstone, apart the fact that i have not put any new resistor, i have changed the PC7703 opto with a good one and now i have good AC-DET signal, then i've changed the rest of the 3 opto with no changement, i have from seconds by the power-on and for some seconds a tension of appr. 7V on PNL-12V then it decreases to 0 slowly. Now i will study the PANEL SUPPLY that is probably a separate supply stage.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4540
        • Italy - Milan
        #123
        The 13,2V output supply rail is regulated by the fixed linear regulator KIA378R12PI (Q7909) that outputs 12v normally, with an enable pin, as the d.sheet says the eanble pin (Vc) activates output when is >=2v, mine is 3v from the PNL_POW signal so i think the KIA doesn't work well.
          'KIA378R12PI' That is the common failure Switched 12V LDO regulator IC.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4540
            • Italy - Milan
            #125
            HI Budm, sorry, you are meaning the KIA is a common problem for theese tvs? I have ordered the part from Aliexpress. We will see between 1/2 months maybe.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4540
              • Italy - Milan
              #126
              Damn! Some sad doubts comes... I have supplied externally 12v to the tcon leaving the PSU tcon supply connector disconnected, before i switch on the tv i switch on the ext. PSU, the voltage falls to the same 7V, when i switch on the tv suddenly tcon voltage become 12v but after some secs tv goes in protection with the same 2 flashes and tcon voltage falls to the 7V. I have done researches on tcon, none of the power semicon tests in short with tester current in, also tested one internal mosfet of a pmic. I'm sad...
              • Jstone86
                • Jul 2018
                • 20
                • Ghana
                #127
                I noticed something today, if 8 removed the tcon connector pin power from psu board I get 12volts on PNL pin 1 & 2 2 which immediately drops to 0.but when I connected the tcon I get 2 volts on pnl pin 1 & 2 and drop as usual. By the way the I think there might be some problems with the tcon cuz I see some black mark on the tcon Pl female comector. Here is ten attach pics
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4540
                  • Italy - Milan
                  #128
                  Too much pictures from me, e-ehm... that seems only a pencil mark..
                  • Jstone86
                    • Jul 2018
                    • 20
                    • Ghana
                    #129
                    Hehehe just wants to make sure that I ruled everything out
                      Example:
                      https://www.badcaps.net/forum/showth...ht=KIA378R12PI
                      • Jstone86
                        • Jul 2018
                        • 20
                        • Ghana
                        #131
                        So budm just to clarify for my TV, I need to CHANGE the KIA378R12PI??
                          Disconnect the PL connector on the T-CON board then put the on the PNL12V pin on the power supply board then turn on the TV to see if the output will jump up to 12V or not, if not then more likely to be bad KIA.
                          • Jstone86
                            • Jul 2018
                            • 20
                            • Ghana
                            #133
                            I indeed get 12v when I disconnected the Pl connector. But only 2v flows in when I connected back the Pl. So that means my KIA378R12PI is OK right? What do u suspect the problem is
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4540
                              • Italy - Milan
                              #134
                              You have to put a resistor or a 12v Lamp as load to the PL output so you can judge better if KIA is good or not. If it stays on then the tcon has problems.
                                OK, next test will be with dummy load, you can simulate 1A load by using 12 Ohms 10W resistor to see if it can handle 1A load or not.
                                If you are going to use the lamp, you need to check its cold resistance first since cold resistance will be about 15 times lower than the hot resistance.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4540
                                  • Italy - Milan
                                  #136
                                  Hi Budm, warning: my test with external supply to tcon was faulty due to a defective crocodile test cable used, swapped it with a good one the tv is perfectly working so the problem is merely the only KIA chip that is faulty, BYE BYE to ALL.
                                  • Jstone86
                                    • Jul 2018
                                    • 20
                                    • Ghana
                                    #137
                                    I think i can get 12R 10W resistor from the local electronic shop here but i have also ordered KIA378R12PI from aliexpress which delivery is approximately 2 weeks.by the way can you please show me how i can stimulate or test with the 12R 10W resistor.pictures wud be better .thanks
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4540
                                      • Italy - Milan
                                      #138
                                      I think this test is facoltative, i guess surely your KIA is bad, wait the piece and try it.. bye.
                                      • Jstone86
                                        • Jul 2018
                                        • 20
                                        • Ghana
                                        #139
                                        After theKIA378R12PI (Q7909) arrived, I changed it and as usual TV dosent turn on. Previously I got 2v PL pin 1 and 2 when I turn on the TV but now get 0.67v so memu touch key buttons don't respond only TV remote also the led light blink 2-2 without stopping hmm. If I disconnected the Pl connector I get 12volts on PNL pin 1ansd 2
                                          Next is to keep the DCV meter on the PL connector, remove the ribbon cables between the LCD panel and T-CON to see if the PL connector will jump up to 12VDC or not when TV is turned on.
                                          BTW, did you do the test with the dummy load?
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
                                          • thesharpfella
                                            Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                            by thesharpfella
                                            Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                            07-23-2024, 10:37 AM
                                          • olegeisler
                                            SHARP AQUOS LC-70LE836S only blinking - freebie
                                            by olegeisler
                                            Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                            Symptoms :
                                            When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                            A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                            Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                            As I see it mainboard has some kind of life, but does not...
                                            07-23-2022, 07:01 AM
