Bad panel or t-con
+ More Options
Posts
  • tech2014
    • Aug 2014
    • 807
    Bad panel or t-con
    My friends TV was damaged during a recent move. The movers must have dropped it or something. This is what his picture looks like on his LCD TV. Is this a damaged panel or something else. The moving company will replace his tv if it is the LCD panel.
    Re: Bad panel or t-con
    Did you try flexing the screen yet?
    • ozzy214
      • Nov 2013
      • 319
      • usa
      Looks like a bad panel to me, try flexing the screen while it is on and see if it moves or goes away....
      • tech2014
        • Aug 2014
        • 807
        Do I need to do this with the TV apart?
        • CapLeaker
          Leaking Member
          • 8102
          Nope. Flex the screen a bit. You also can squeeze the frame around the screen and see if it goes away. Looks like tab bonds to me.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Looks like a panel tab bond issue to me.
            • budwich
              • Jul 2015
              • 3097
              perhaps the moving loosened some of the cables. Try reseating the cables going to the tcon board to see if things change especially those on the left side.
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • mmartell
                General Questions on the Relationship Between Mainboard, TCON and Panel
                by mmartell
                My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                01-06-2024, 01:32 PM
              • SurrealMustard
                What parts can be salvaged from a plasma with a damaged display panel?
                by SurrealMustard
                I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                03-09-2025, 08:29 PM
              • Lee M.
                Amazon Fire TV Omni K24NE5 tcon or panel bad?
                by Lee M.
                TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
                05-12-2023, 05:47 PM
