Ssi_400_14a01
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #61
    Re: Ssi_400_14a01
    I did attempt this before, the lcd did light up however the light from the Leds was so directional that there were patches on the screen. Also leds could be more expensive than buying a replacement inverter and putting new mosfets on it. Going to see what I find tomorrow. Thanks anyway buddy
      Re: Ssi_400_14a01
      Originally posted by stj
      you just need a good 12v feed.
      Two strips in series run fine from 24V, problem is the lack of dimmability or bl on/off often leads to distortion on the screen during start up (as the T-con has not yet initialised, the screen often flickers a little until it is ready.)
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #63
        Re: Ssi_400_14a01
        Luckily on this set the Tcon initializes after the Blon is turned on, this is a Vestel set btw. Remembering now I do have a set of leds left over from another failed project think its worth it ? This is also one that chains the dimming with the Tcon and the inverter so would removing the inverter cause the Tcon to not work properly or something ?
          Re: Ssi_400_14a01
          The T-con would be initialised on a normal TV before the BL ON signal fires so with a normal inverter the set would show backlight only when the screen was showing video or programmed "black" (or whatever excuse for it that it has, it is an LCD after all.)
          Without the BL ON control (which you will probably not implement) the LEDs turn on as soon as the power supply is ready. In most cases this is before the T-con is ready as the T-con is usually run from the 12V supply generated by the main SMPS -and- the 12V to the T-con is switched by the main board to ensure correct power sequencing.
          Exceptions, of course, always apply, this is just a typical example.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            #65
            Re: Ssi_400_14a01
            Yeah you are correct thinking about it the lcd/tcon will initialize before the Blon I remember on the other one I attempted to convert it to leds there was a strange distortion before any i age was brought up on the lcd.
            At this point im not sure what to do this is a customers tv and doing such a mod could potentially cause them to moan or complain. I will see what I find with this inverter tomorrow. Luckily the customer is someone who has used me in the past several times and recommends me to others and doesn't mind waiting so guess that its good if I have to order things from China etc.
              • 30991
              Re: Ssi_400_14a01
              i wouldnt do experiments on a customers tv, i thought it was yours.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #67
                Re: Ssi_400_14a01
                Ahh right I said in the video I posted haha no worries, hopefully can sort this crappy inverter haha also got lots of others to fix as well haha I dont mimd though enjoy fixing tvs
                  Re: Ssi_400_14a01
                  I didn't tell you this but the dirty little secret no one seems to know about inverters is they are mostly interchangeable. Seriously, as long as it's got the right connectors and is for approximately the right size panel, it'll be good. I have used a completely different part number inverter before on a 37" LG, it was also for a 37" LG panel and had similar specs and matching connectors but was from a 2 year newer set. Worked perfectly, still playing strong.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #69
                    Re: Ssi_400_14a01
                    Ahh I see, I actually already knew that just didnt say, I did the same on a 32" Vestel ages ago still going strong, as long as the lamps are the same size they use pretty much the same current meaning little potential difference to trip the protection circuit. I have been checking some SSI_400_12a01 inverters nearly the same but missing two bulb connectors which is a pain no others seem to correlate to this one they all only have 12 connectors.
                      Re: Ssi_400_14a01
                      Yea, 14 connectors is odd. 7 bulbs, U-shape tubes. Not easy!
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #71
                        Re: Ssi_400_14a01
                        Yep pain in the back side ! The design of this inverter as well is total crap as well in the way it drives them mosfets it pushes them quite hard no wander they fail and probably are what killed the driver with them.
                          Re: Ssi_400_14a01
                          Originally posted by ReeceyBurger123
                          [...] The design of this inverter as well is total crap as well looking at the schematic and the way it drives them mosfets it pushes them quite hard no wander they fail and probably are what killed the driver with them.
                          What makes you conclude that?
                          Schematic link?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #73
                            Re: Ssi_400_14a01
                            No schematic of the mosfets they are being sent a higher pulse or drive voltage from the controller which I think is standard with these.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #74
                              Re: Ssi_400_14a01
                              This is going to be difficult as the way the upper and lowwer mosfets are driven is different, going to test the upper set. The drive voltage is at 5v however seems noisy my ground point is close ??
                                Re: Ssi_400_14a01
                                The top FET is p-channel so it is inverted as the source is more positive and a negative Vgs voltage turns it on or off. P channel is rare due to higher cost and poorer performance (Rdson, Qg, etc.) but driving them is easier.
                                It's pretty much impossible to make a FET short by abusing the gate - you can blow the gate channel open, or short gate-to-source but not drain-to-source (G-S short keeps the FET always open.) But that happens within a few seconds, normally...
                                  Re: Ssi_400_14a01
                                  Best to start with lower FETs.
                                  What probing are you using?
                                  I don't have a photo from work (confidential prototypes, etc.) but the technique (not confidential) used there is to take the probe hook off, solder a flexible but rigid copper wire to the local ground, wrap the ground around the metal shield near the tip, and put the tip right against the SENSE POINT.
                                  Goal being, keep ground and probe signals at the lowest inductance possible, minimising ringing.
                                  In this case the local ground would be the SOURCE of the lower N-FET. Do NOT ground the drain of the P-FET or you will be replacing more FETs.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #77
                                    Re: Ssi_400_14a01
                                    Thats what I have done Tom will get some pics. However quite certain its the controller now as its getting lots of voltage increase and drops its unstable, now also the Bl is dimming and the drive voltage is creeping up and im not even running anything on the screen just the normal back ground so I know that the tcon is not ramping the Bl dim up and down corresponding to whats being displayed.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #78
                                      Re: Ssi_400_14a01
                                      What I might do it heating or cooling the Ic as when these type of Ic's fail they become heat sensitive. Will keep you posted buddy.
                                        Re: Ssi_400_14a01
                                        Gate voltage should be constant - check the Vcc for the controller (usually a lower voltage rail, around 6V or so)
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #80
                                          Re: Ssi_400_14a01
                                          Pop there goes one of the fets, this time I caught the fucker ! The VCC went over 18v when they popped ! It has to be that fricking controller.
                                          • BlackScreen_22
                                            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                            by BlackScreen_22
                                            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                            I had no problems connecting mosfets and capacitors,...
                                            08-27-2024, 12:46 PM
                                          • kotel studios
                                            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                            by kotel studios
                                            Finally got time to fix this board up.
                                            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                            04-22-2025, 05:08 AM
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • flerre
                                            Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                            by flerre
                                            Hi!
                                            Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                            No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                            So, could I safely assume all of these 3 mosfets are...
                                            03-13-2022, 12:14 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
