Ssi_400_14a01
    Re: Ssi_400_14a01
    yea, if the controller Vcc rail is unregulated this will be a problem.
    it is definitely a failure on some other inverters though usually it goes the other way (low, causing inverter to stop)
    though the FETs probably only fail because the driver in the controller IC failed (latch up potentially), or P-N overlap occurred due to insufficient turn off margin.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #82
      Re: Ssi_400_14a01
      Thats the failure then now time to order a SEM2017 Ic and a whole new set of Mosfets for this I recon that they killed the Ic in the first place tbh Tom, going to cost me £16 for everything if I order the Ic and more Fets but still cheaper than a new inverter. Cheers Tom going to also check the resistors for it as well
      • diif
        • Feb 2014
        • 6978
        • England
        #83
        Re: Ssi_400_14a01
        Where are you ordering your parts from ReeceyBurger ?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #84
          Re: Ssi_400_14a01
          China buddy, cant seem to find any where closer.
          • diif
            • Feb 2014
            • 6978
            • England
            #85
            Re: Ssi_400_14a01
            Cheers bud, didn't know if you'd found a place in the UK other than the usual sources.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #86
              Re: Ssi_400_14a01
              Why you after a chip mate I will link the one I order later pal
              • diif
                • Feb 2014
                • 6978
                • England
                #87
                Re: Ssi_400_14a01
                Nah,i'm all good thanks i recently ordered a similar IC and some FETS from China, just hoping the quality will be ok.
                I might even have a complete board in my cupboard for yours. It's a 40" Toshiba but i think the insides might be the same ?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #88
                  Re: Ssi_400_14a01
                  Ahh right if you do let me know and can sort something pal cheers
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #89
                    Re: Ssi_400_14a01
                    i'll have a look in a bit for you after my dinner, i've got to pull lots of stuff out of the way to get to it, its still in a tv i think
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #90
                      Re: Ssi_400_14a01
                      Sorry mate, the tv is empty of all of the boards. I haven't used it so i might find it somewhere but i can't guarantee it.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #91
                        Re: Ssi_400_14a01
                        Yeah I have ordered a Ic any way just to try buddy
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #92
                          Re: Ssi_400_14a01
                          Good news is found a Uk supplier as well could be upto 10 days
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #93
                            Re: Ssi_400_14a01
                            Chip arrived going to install it
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #94
                              Re: Ssi_400_14a01
                              I installed mine (from China) a couple of days ago and the damaged Mosfet and the Tv works great now.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #95
                                Re: Ssi_400_14a01
                                Nice one will get on to it later
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #96
                                  Re: Ssi_400_14a01
                                  Got the Control Ic replaced and the failed Mosfets, tv fires on Bl is up haven't checked Vcc just going to see what happens. I have put some thermal pads under the Mosfets to help them disperse some heat to the chassis.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #97
                                    Re: Ssi_400_14a01
                                    Think its all sorted, been running it on full brightness for hours now and working great. Going to test it for a few more days
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #98
                                      Re: Ssi_400_14a01
                                      Nice 1 ReeceyBurger
                                      • wills123
                                        • Jan 2014
                                        • 72
                                        • england
                                        #99
                                        Re: Ssi_400_14a01
                                        Ah wish I caught this sooner I. Have one those boards that wudnt switch backlight u could of had it for the parts for post cost, I resolved mine by switching the good lcd. From that one into a toshiba (vestel ) of same size that had bad panel lol
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #100
                                          Re: Ssi_400_14a01
                                          Ahh no, hopefully now I have repaired it at component level it will be alot more reliable. Just got to wait and see what happens over the next few days
                                          • BlackScreen_22
                                            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                            by BlackScreen_22
                                            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                            I had no problems connecting mosfets and capacitors,...
                                            08-27-2024, 12:46 PM
                                          • kotel studios
                                            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                            by kotel studios
                                            Finally got time to fix this board up.
                                            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                            04-22-2025, 05:08 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • flerre
                                            Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                            by flerre
                                            Hi!
                                            Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                            No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                            So, could I safely assume all of these 3 mosfets are...
                                            03-13-2022, 12:14 PM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
