Ssi_400_14a01
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: Ssi_400_14a01
    Ok replaced the Mosfets again and all is up and working, drive voltages are fine and all other input voltages now to wait and see.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #42
      Re: Ssi_400_14a01
      This is getting strange, the mosfets have blown out again but not the ones I replaced, now its the ones at the bottom of the board and its not the ones that drive the transformer that I swapped over but the one above it Wtf ? Im really starting to suspect that the driver Ic is messing up somewhere and is killing the mosfets but annoying thing is the drive voltage was fine until they popped now its 0 and this time the fuse blew for em mosfets. Now time to try and find a SEM2017 from some where that ships to the Uk. What a nightmare this thing is better keep on checking things.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8325
        Re: Ssi_400_14a01
        Those Mosfets where not any Chinese fake crap ones by any chance? Maybe upgrade the Mosfets with ones that have better specs?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #44
          Re: Ssi_400_14a01
          They are genuine parts same brand as originals, the ones that have now failed were the originals so I now know the lamps and transformers are not at fault here, I have a feeling its the controller.
            • 31185
            Re: Ssi_400_14a01
            controller is probably turning all the fets on together.
            it's a terrible design.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              Re: Ssi_400_14a01
              Your right its total crap, going to take it to my uncles and get it on a scope so can see what that controller is doing. I have a suspicion its pulsing them on and off too fast causing them to over conduct then fail.
                Re: Ssi_400_14a01
                You would want to use two channels: check the upper and lower gate for each pair, and see that there is no overlap. If there is overlap, this will cause cross conduction and heating of the FETs.
                Also check how hot the FETs get - could still be counterfeits if from eBay, etc.
                  • 31185
                  Re: Ssi_400_14a01
                  it's not overlap, you need a gap for the gates to discharge.
                  also known as a "deadzone"
                  that's why circuits that use an invertor between the channels piss me off.
                    Re: Ssi_400_14a01
                    Depends on the FET - modern FETs can work with effectively zero dead time as they are off within a few tens of ns - and it takes at least that time to discharge the gate capacitance. Does depend on the FET of course, PFETs are worse.
                    Still not sure how dead time would change due to a fault, unless some cap or resistor reference has drifted...
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #50
                      Re: Ssi_400_14a01
                      I will try overlap I think it will be for this type of fet, good job is I wont have to order a whole set of fets as have two left over that are good. Will update you tomorrow on what we find too bad his scope is analogue so cant set it to trigger on a wave form if anything messes up from what it normally was, but if they fail as fast as these did then wont have to stare at it for long. This is going to be hard as cant get the probe leads on the fet leg so will have to solder a wire lol. Cheers guys
                        Re: Ssi_400_14a01
                        Make sure to get your ground as close as possible to reference ground. Use a short lead - don't use the probe hook, either. Otherwise, you'll get ringing and you won't get the right result.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #52
                          Re: Ssi_400_14a01
                          Yeah will do I know the game..... well sort of still learning about how to use a scope hopefully getting one this christmas which will be the best as hate having to keep transporting things. Luckily the customer doesn't mind waiting if I do have to order a chip from China.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #53
                            Re: Ssi_400_14a01
                            Im actually looking forward to getting a scope, especially to see the sustaining wave forms generated by a PDP thats what im dying to see and other things, I will be getting a Rigol one like you have Tom soon with in next two months
                              Re: Ssi_400_14a01
                              They really are quite beautiful - I especially like watching them vary as the panel picture changes. The controller software adapts so much due to panel temperature, image brightness and power saving, it's crazy. KURO sustain is completely different - if you ever open up your 428, I'd be interested to see how it compares to a 5090.
                                • 31185
                                Re: Ssi_400_14a01
                                if you bypass the safety, you can probably scope the controller without putting new fets on first.
                                just a thought.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #56
                                  Re: Ssi_400_14a01
                                  Thats why I love Plasma just amazing devices I have opened my Pdp428xd to clean when I got it this time last year so when I get my scope will surely be taking it back apart to see the sustaining wave forms. Everything about Plasma fascinates me
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    Re: Ssi_400_14a01
                                    just a thought.
                                    Yeah im going to remove a fet and turn off that protection circuit so that it will run. Yes the other will be stressed but they are all going to be replaced.
                                      • 31185
                                      Re: Ssi_400_14a01
                                      what size tv is it btw, and how many tubes?
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #59
                                        Re: Ssi_400_14a01
                                        40" Ccfl with 14 lamps.
                                          • 31185
                                          Re: Ssi_400_14a01
                                          maybe just say "fuck it" and put led strips in the back?
                                          a friend of mine tried it a few times with the led strips you get on a 5m roll with good results.
                                          you just need a good 12v feed.
                                          • BlackScreen_22
                                            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                            by BlackScreen_22
                                            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                            I had no problems connecting mosfets and capacitors,...
                                            08-27-2024, 12:46 PM
                                          • kotel studios
                                            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                            by kotel studios
                                            Finally got time to fix this board up.
                                            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                            04-22-2025, 05:08 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • flerre
                                            Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                            by flerre
                                            Hi!
                                            Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                            No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                            So, could I safely assume all of these 3 mosfets are...
                                            03-13-2022, 12:14 PM
                                          • DrDos
                                            kenwood kr-6030 Mosfets?????
                                            by DrDos
                                            Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                                            09-20-2025, 04:42 PM
