Ssi_400_14a01
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Ssi_400_14a01
    Yeah will also going to check the drive voltage for them just to be sure that they arnt being push harder than the others. I dont think its a failed lamp or transformer because when it worked image was fine and if that was the case wouldn't the protection circuit shut it down these are sensitive as had one before with a failed lamp connector and it would shutdown instantly? Will check when I get back thanks guys
      Re: Ssi_400_14a01
      The protection circuits only detect open lamps (over voltage) and shorted loads - and usually, the shorted load detection only works by under voltage or power supply cut out.
      So intermittent faults or bad transformers aren't always detected.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: Ssi_400_14a01
        Yeah the shorted mosfets dont blow the fuse but kill the 24v rail and Psu shuts down. Going to start diagnosing now
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Ssi_400_14a01
          Here what I found, also it is 3 Mosfets for the transformers at the top btw there isnt any chain between them all so dont know how they do that here is the resistance readings for the transformers.
          Bottom 2 transformers:
          Secondary resistance readings 1490 Ohms same on both transformers.
          Top large transformer with failed mosfets:
          Secondary resistance 1512 ohms and 1516 ohms on both secondary windings, failed ?
          Top small transformer:
          Secondary resistance 1015 Ohms per winding.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: Ssi_400_14a01
            The controller Ic is a SEM2107 0929 chip, this is included in some repair kits for this INV.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Re: Ssi_400_14a01
              Going to take the transformer off and swap it.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Re: Ssi_400_14a01
                Here is a youtube video of what I have done so far:
                https://m.youtube.com/watch?v=C6zbTDLx3ug
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Re: Ssi_400_14a01
                  The transformer is not at fault but I swapped it anyway, nothing is shorted but however do you think its worth checking the drive voltage for the fets and swapping them out again just to be sure its not the driver circuit ?
                    • 31185
                    Re: Ssi_400_14a01
                    did you check the ceramic caps between the transformers and tubes?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      Re: Ssi_400_14a01
                      The ones on the inverter Pcb buddy ?
                        • 31185
                        Re: Ssi_400_14a01
                        obviously.
                        they stop the tube drawing too much current.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          Re: Ssi_400_14a01
                          Yeah they are fine
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Re: Ssi_400_14a01
                            This one is a pain going to risk it tomorrow and put my new mosfets in and start checking things.
                              • 31185
                              Re: Ssi_400_14a01
                              check everything related to the controller ic.
                              got a datasheet?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Re: Ssi_400_14a01
                                got a datasheet?
                                https://www.badcaps.net/forum/showthread.php?t=36735
                                --- begin sig file ---
                                --- end sig file ---
                                  • 31185
                                  Re: Ssi_400_14a01
                                  btw, i dont suppose you have a logic analyser?
                                  just incase the controller is doing something it shouldnt!
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #37
                                    Re: Ssi_400_14a01
                                    Thats what I suspect the logik Ic is included in some of the Us repair kits now im really starting to think that it could be messing up somewhere. I dont have an analyser though so will have to start checking things tomorrow cheers Stj.
                                      Re: Ssi_400_14a01
                                      Scope would be more useful - logic analyser won't handle the level-shifted gate outputs, or usually anything more than around 5V. Gate drive will go above 24V on this if it has high side N-channel FETs.
                                        • 31185
                                        Re: Ssi_400_14a01
                                        true, but some resistors and zeners would probably fix that, as long as it wasnt running faster than the LA.
                                        i have a new one on the way that can sample at 24Mhz - i couldnt resist for £5!!!
                                        http://www.ebay.co.uk/itm/141694353386
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #40
                                          Re: Ssi_400_14a01
                                          Thanks everyone
                                          • BlackScreen_22
                                            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                            by BlackScreen_22
                                            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                            I had no problems connecting mosfets and capacitors,...
                                            08-27-2024, 12:46 PM
                                          • kotel studios
                                            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                            by kotel studios
                                            Finally got time to fix this board up.
                                            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                            04-22-2025, 05:08 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • flerre
                                            Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                            by flerre
                                            Hi!
                                            Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                            No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                            So, could I safely assume all of these 3 mosfets are...
                                            03-13-2022, 12:14 PM
                                          • DrDos
                                            kenwood kr-6030 Mosfets?????
                                            by DrDos
                                            Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                                            09-20-2025, 04:42 PM
