Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
  • kotel studios
    • Dec 2024
    • 243
    • Poland
    Finally got time to fix this board up.
    At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
    Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't switching. CPU is stone cold (tested in another machine, works) and stuck in reset... I do have an ADP3166 to replace the ADP3168, but pin 6 on both are different. On 3166 it's CROWBAR which can short 12v to GND on demand, while on 3168 it is VID5. Not sure if I can use the 3166 here....
    Drivers get their 2.8v on pin 3, original ADP3168 also has 1.2v on pin 11, so there shouldn't be any problems here. I see the high side MOSFETs getting 12v on their gates, but nothing on the outputs, low side get their 12v on source, but nothing on drain.....
    Any ideas?
  • kotel studios
    • Dec 2024
    • 243
    • Poland
    After some troubleshooting I found the culprits, missing FB, FBRTN, PWRGD which makes the VRM not switch (no PWD 1-4 voltage). FB and FBRTN are all connected to their respective rails. Injecting FB makes PWRGD still stay low....
    Injecting Vcore directly onto the coils makes the CPU get out of reset, but it's still not posting...
    All I know is that the ADP3168 sees some unknown fault and halts the switching of the VRM and that's it.
    Any ideas?
    • ribcage
      • Sep 2020
      • 45
      • Earth
      It's very common for one capacitor to fail on this board. Often it's nichicon HM(M) 2200µF 10V, between RAM and SATA ports. It causes intermittent POST.
      • kotel studios
        • Dec 2024
        • 243
        • Poland
        Well, it might've been the case earlier on, now this board is total e-waste....
        Not only did I order the wrong chip (ADP3166), I also destroyed pin 11 (EN) on the original chip and the pads bellow them onboard......
        Sure, trace repair is possible, but is it really worth putting in another 50zł just to not have a guarantee if it's not gonna work?
        • c_corr
          Asus P4C800-E VRM issues
          by c_corr
          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
          This board uses mext ICs and Mosfets in VRM:
          - ADP3180 PWM controller - in 3 phase mode
          - ADP3418 as Modfet drivers
          - High side Mosfets STD38NH02L (from ST)
          - Low side Mosfets STD90NH02L
          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
          02-08-2025, 11:59 PM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • User 4574
          Asus , board 532lws R1..3 Power rail 5v , 3v dsw
          by User 4574
          Hi everyone .
          I have model g712l And In stuck.
          Originally this laptop has a short on main Power rail . Thé main short is gone, i have found 2 pea16b mosfets Next to the SN51285ARUKR shorted , and the Chip Intself was Also shorted , i have removed them and main Power rail IS not shorted anymore , but right Now im still eating for this parts And in checking rest of the board . But pin 14 od the SN51285ARUKR when this chip od removed is shorted to ground Its +5VSUS has 6ohms , And that can not be , i have check mosfets All over the board And i have found ONLY one tahat ís shorted its...
          Bad cap
          0%
          0
          Shorted internal layer in thé motherboard
          0%
          0
          06-21-2026, 07:50 AM
        • pavithra_uk
          Optiplex 3050 Vcore Mosfet short
          by pavithra_uk
          it is 3+2 vrm
          vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
          gate drive chip (NCP81166) also gone.
          any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
          odd question:
          what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
          10-21-2025, 11:32 AM
        • zlr8r
          Lenovo YOGA Slim 6 14IRH8 - blowing 4 mosfets every time i plug type-c charger in, why?
          by zlr8r
          ive changed out the, BQ25720, TPS65994BF, ALL the mosfets around the battery connector (with exact same versions), and there are NO shorts that i can find, and nothing gets hot (just mildly warm , like 38C)...
          Where else on this board should i check ? Cant be replacing a load of mosfets on each charger plug-in...... any pointers welcome ...
          Mosfets inside RED square keep blowing when USB-C Charger is connected (any USB-C laptop charger)...
          Blue square items,...
          06-28-2026, 02:22 PM
