Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
  • BlackScreen_22
    • Aug 2024
    • Sweden
    Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
    Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
    I had no problems connecting mosfets and capacitors, the only doubt I had was connecting Z2 to gnd (because of that arrow on the datasheet). Before connecting everything and powering it I checked the amplifier board thoroughly, every single component seems ok to me, same thing for the main board (the one with the power supply) and finally the jack board if you can call it that... I connected everything to the toroidal transformer, the mosfets short out and the fuse blows, obviously there was and is not a short circuit on any pin, I suspect that the cause of this problem is the low quality mosfets (IRF9640/640 taken from aliexpress), what do you think?
    To ALMOST completely exclude the other two boards I tried to power them first without the amplifier board, and then with the amplifier board but without the mosfets, the fuse does not blow, the LED works and the relay trips. I also measured the voltages on the mosfet pins, more or less around 10 volts, some 9.5 or 7.
    I don't know what to do, I've already asked for some advice but in the end it didn't lead me anywhere, is there anyone who can try to help me? I'm attaching the link to the datasheet and a couple of photos, if you need other photos/information/measurements let me know.
    Thanks in advance
    Datasheet: https://elektrotanya.com/harman_kard.../download.html
    Photos: https://imgur.com/a/QLxfmaz
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • dimis7
    LG 37LS5600 blows main fuse
    by dimis7
    Need some advice to troubleshoot this TV.
    PSU blow the main fuse F100, 3.15A.
    I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
    I checked with DMM for dead sorts but didn't found any.
    Checked bridge rectifier and seems ok.
    Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
    PSU p/n is EAX64405901 (1.6)...
    10-28-2022, 05:15 AM
  • Michale32086
    LG 60LN5400 Blows TCON Fuse
    by Michale32086
    I could have sworn I posted about this before, but I can't seem to find the post..
    To whit..
    I have a 60LN5400 that came in.. Backlights work fine.. No display..
    Traced the problem to the TCON board.. Blown fuse..
    Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
    Got a new Main Video Board.. Replaced the fuse on the TCON..
    The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
    10-30-2019, 09:21 AM
  • jshhh
    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
    by jshhh
    Hi guys,
    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
    Anybody know how to remove this type of fuse?
    (The fuse is toward the bottom of the image labeled F2)...
    06-17-2025, 01:35 AM
  • kotel studios
    Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
    by kotel studios
    Finally got time to fix this board up.
    At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
    Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
    04-22-2025, 05:08 AM
