LF501EM5F No Power, Chirping/Beeping Transformer
    • 31190
    Re: LF501EM5F No Power, Chirping/Beeping Transformer
    Originally posted by shadetreetrader11
    Dick I looked at D655 over and over again. I put them under a Enhanced Vision Magnifer. And to be honest with you I think you should do the same.
    that joint has a micro-fracture.
    it's not the magnifier, it's knowing what your looking at.
    the shadow changes half way up the joint - it has a ring-crack.
    • shadetreetrader11
      • Oct 2015
      • 230
      Well I guess the picture makes it look that way, Because I know what you are saying and I think the the light must be messing with a guys eyes. Just out of curiosity what kind of solder do you use?
        • 31190
        i use Stannol TC with Kristall505 flux.
        when it runs out, i may switch to TC with HS10 or KS115 flux
        it's not as clean as Kristall505, but more agressive on dirty joints.
        • shadetreetrader11
          • Oct 2015
          • 230
          Well maybe that's my problem. I'm using less expensive solder. I guess I'm a tight Dutchman. I'll have to look that up and try it out. Would probably take care of some issues
          • shadetreetrader11
            • Oct 2015
            • 230
            Any luck with schematics. I was thinking It would be cool to fix this thing. I have seen this is a fairly common thing with these tvs. Everybody just buys a knew main board for it and calls it quits. But If we go threw the work and fix it it might help some others. Either way it's up to you. Like I said I can't find the correct schematics.
              No luck on the correct diagrams for either the power supply or the main board, but at this point you know that you have low resistance between the output pin (big tap of the 1117) and GND so maybe you will have to trace that out, and a far as the input goes, you just need to trace it out as to where it goes to.
              • shadetreetrader11
                • Oct 2015
                • 230
                I've tried to trace it back I have shoved tiny wires threw the board (Double sided) and I keep ending up into the main IC 3101 thing has 156 legs. I really need a schematic. My circut level is nothing compared to yours. I'm a little beaten I think. But I did learn a lot from the whole deal. Just had a friend bring over a different tv to look at so maybe I'll move on to that one. Can't say we didn't try. Thanks guys
                  • 31190
                  more likely a shorted ceramic cap
                    Originally posted by budm
                    That reading is with or without the cable between the main and power supply board connected?
                    There is a small ceramic cap C3608 connected between the tab and GND, those kind of cap tends to fail as shorted circuit.
                    Did you check that cap by removing it?
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8326
                      Push some power through with a variable power supply. It should get roasty toasty whatever is bad, unless it is heatsinked somehow.
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        capLeaker. I took your advice and fed about 1.5 to 2 volts threw it and the main IC got warm. I ordered a main board already. I was really wanting to fix that one but o well. I sure learned a lot and I guess that's the main objective.
                          When you get the replacement board, make sure to take some resistance readings for the supposedly 'Good working board' just in case.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8326
                            Yeah... too bad. Maybe you find a replacement IC on aliexpress or ebay. Tinkering with stuff is fun and learning something new is always exciting. I think you did pretty good. Here are quite some knowledgeable folks on this board.
                            • shadetreetrader11
                              • Oct 2015
                              • 230
                              Ok Main Board showed up today and I measured 900 ohms from the large tab of the 3.3 volt regulator to ground. (Much better) So I put the board in the tv and it still won't fire up. Here is a list of the voltages I have. They all seem to be present. It just won't produce the 390 volts.
                              All +3.3 3.3v
                              Amp 13v 13v
                              P-on 21 22v
                                All +3.3 3.3v
                                Amp 13v 13v
                                P-on 21 22v
                                So the power supply is now putting out the correct Voltages now with the new main board which supplies the 3.3V back to the power supply board.
                                So what DCV do you have on the main filter cap? around 230VDC?
                                • shadetreetrader11
                                  • Oct 2015
                                  • 230
                                  Yes you are correct. 218 volts
                                    Per diagram it shows around 230V, so I do not believe that the PFC Boosted Voltage is that high in the 400VDC range.
                                    Since you do have full 13V and full 21V that means the main board is now sending the PS-ON to turn on the power supply to run in full mode.
                                    So do you now have the LED on the front of the TV now since the 3.3V is now present?
                                    Also do you have BL-ON and the dim control signals?
                                    • shadetreetrader11
                                      • Oct 2015
                                      • 230
                                      The red LED is on but not sure about the bl on Sig. I know the back light it's self isn't on. And there's 3 wires that each have 47 volts to ground on them that are going to the back light.
                                        So at least now you do have Red LED on, does it change state when you have activate/deactivate the power switch on the remote or on the TV?
                                        • martystv
                                          • Aug 2014
                                          • 20
                                          • usa
                                          #120
                                          I have the same set(lf501em5f). It was also chirping and I also changed the main board. I now have the same thing as shadetreetrader11. 47 v at the led plug. I'm not sure yet but I think the problem is with the bl-sw circuit. I have 3 jumpers (j116,106,103) all labled bl-sw but all three have 0v.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
