LF501EM5F No Power, Chirping/Beeping Transformer
  • SLK001
    • May 2014
    • 264
    Re: LF501EM5F No Power, Chirping/Beeping Transformer
    If you are only getting 160V on your main caps, then C605, C606 or C607 is probably shorted.
    • shadetreetrader11
      • Oct 2015
      • 230
      Have never had 3.3vdc. Doesn't matter if the ribbon cable is plugged into the board or not. 3.3 is not present. As far as the chirping that only happens when the ribbon cable is plugged in. I have not tried to plug the ribbon cable in with the resistor soldered in place.
      • shadetreetrader11
        • Oct 2015
        • 230
        slk001 I'm assuming you are talking about the surface mounted caps on the back side?
        • shadetreetrader11
          • Oct 2015
          • 230
          checked all the surface mounted caps you mentioned on the back side of the power supply and the all measured over 3k ohms and above.
            OK, then we need to look at the ALL+3.3V standby power supply section first then, we know we do have the main DC 160V to run the standby power supply section, we will be working on the power supply board without any other board connected to it at this point and try to get the 3.3V working first.
            I will have to look at the diagrams. BTW, did you do any testing of the Diodes on that power supply board?
            • shadetreetrader11
              • Oct 2015
              • 230
              I check all the diodes. None were shorted. check as many of the surface mount diodes on the back side as I could and they all seemed fine too
                OK, we need to find out what dcv you have on the SMD SMPS IC601 (FA5640N please verify that is the P/N as printed on top of the IC) in the primary side, we need the DCV readings of all the pin with ref to the GND pin pin 4 (or use the negative leg of the main filter cap as the GND ref point).
                Be real careful not to touch anything since you are working in the primary side of the circuit.
                  BTW, what DCV do you have on the AMP+13V and PON+21V jumpers? Notes: just the power supply board by itself.
                  • shadetreetrader11
                    • Oct 2015
                    • 230
                    amp +13 is 8.136 and p on+21v is 13.81
                    This is the measurements of IC601
                    1 8.9 mv
                    2 291.4 mv
                    3 27mv
                    4 Gnd
                    5 22mv
                    6 11.33vdc
                    7 42mv
                    8 166vdc
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      Measure all pin outs on the PSU, post pin name with voltages measured. TV on and TV off, so we have a start point. I went back, but that isn't your thread. Use GND pins 9-14 as your GND reference.
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        Pins 1-8 all 0 vdc
                        Pins 15-18 Are 8.15 vdc
                        Pins 20-23 Are 13.8 vdc
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8327
                          is that with the main board disconnected? If not, unhook everything from that PSU and measure those pins again.
                          • shadetreetrader11
                            • Oct 2015
                            • 230
                            The Main board is disconnected and there is a resistor soldered from the All+3.3volts to the p-on. Budm was stating that 3.3vdc isn't present so we were trying to figure out why that was. He had me start with ic601 and there voltages.
                            • SLK001
                              • May 2014
                              • 264
                              Sorry, I meant D605, D606 and D607. These are your booster diodes, which should boost your voltage to ~300VDC.
                              The Vcc pin on IC601 (PIN 6) is right at cut-off voltage (11V). This means that your driver IC is probably going in and out of shutdown. The voltage on PIN 6 should be in the 20V range.
                              Check the voltage on D614 (a zener diode).
                              • shadetreetrader11
                                • Oct 2015
                                • 230
                                Lifted one leg of D605, D606, and D607 and they were all in good shape. Since it was so damn fun I did every diode on the board. All diodes tested good. As far as the voltage on pin 6 of IC601 it is the same as it was the last time. Still 11.33 volts as is D614. D614 is hooked directly to pin 6 of IC601. D614 also checked good. And as long as I was checking I check as many of the surface mount diodes I could find and they all measured fine.
                                • SLK001
                                  • May 2014
                                  • 264
                                  Should be thru a resistor (R634).
                                  If those three diodes are really good, then check C602. It is a 0.1uF, 310V cap. If you can't test it, then just replace it with a comparable part.
                                  You need to focus on why your booster isn't boosting.
                                  • shadetreetrader11
                                    • Oct 2015
                                    • 230
                                    checked c602 with a esr meter and it checked good.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8327
                                      VCC on IC601 is low. Check esr c620 and c616
                                      • shadetreetrader11
                                        • Oct 2015
                                        • 230
                                        c611 is measuring 17 ohms with esr meter. Seems high but I'm not at all familiar with ceramic caps. I'm going to try and find a parts board from a different TV and try find one with the same value and change them out.
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8327
                                          Only the electrolytic ones.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
