Arquos 70LE640u dead
  • paulstef
    • Dec 2013
    • 724
    Just wanted to know if there are any known issues with this TV.
    It doesn't turn on. Front LED flashes long then short indicating an LED or inverter failure according to SM.
    Primary main voltage stays at 170V, no boost. LED transformer is not driven. How the mainboard knows there is a inverter fault if it doesn't even try to drive it I don't know...yet.
    Board is RUNTKA933WJN6.
    I have 5V nothing else...
  • paulstef
    • Dec 2013
    • 724
    Re: Arquos 70LE640u dead
    The PFC can be made working (goes up to 405V) by shorting PS_ON to BU5V on connector PD.
    Unfortunately there are som many signals it's hard to say which one would control the LEDs. There are DIMMER, PWM1, PWM2, PNL12V, OFL, PNL_POW.
    In the SM it says:
    "ERR_PNL: failure(H). Inverter/Lamp error is detected.
    Note that after five detection counts, the lamp cannot be
    activated except in the adjustment process mode.
    Accumulated counts are cleared to 0 by the setting in the
    LAMP ERROR RESET on the adjustment process mode."
    Now, how would one get into adjustment process mode if there is no backlight????
      Adjustment process mode means the service menu; it's activated by holding keys on the TV (check service manual for further details) usually VOL- and CH- or VOL- and INPUT.
      • paulstef
        • Dec 2013
        • 724
        Thanks Tom, but what I don't understand is they say in order to reset the backlight fault counter I would need to access the service menu. When the counter is higher than 5 the backlight would not be activated (PS_ON stays low).
        Does this make any sense? How do they want us to reset the counter if the backlight is always off? Seems like a contradiction.
        http://elektrotanya.com/sharp_lc-52-.../download.html
        • paulstef
          • Dec 2013
          • 724
          How do I test those backlights? Just applying a high enough voltage (with current limit)?
          There are three sections. How much voltage would I possibly need? The two main secondary voltage caps have a rating of 200V and the other 3 electrolytic caps a rating of 350V...
            Entering the Adjustment mode temporarily inhibits the backlight counter disable. The backlight should come on, if it is not faulty.
            • paulstef
              • Dec 2013
              • 724
                Very hard to tell. It depends on the architecture. Pretty much the only way to be sure involves taking apart the panel to see the LED arrangement (how many are tied in series/parallel etc.)
                • paulstef
                  • Dec 2013
                  • 724
                  I think me taking apart a 70" display is not a good idea, almost certain I'm gonna damage something....
                    Agreed, it's extremely difficult to do.
                    This is the problem with LED TVs - undocumented operating voltages and currents...!
                    • paulstef
                      • Dec 2013
                      • 724
                      The LED strings being sold have 64 LEDs on them , possibly 2x32 in parallel. There are 3 connectors on the wire harness, and there seems to be only one connector on each LED string.
                      Assuming they use really 3 LED strings, what configuration would that be? Two on top, one in the middle? One on the side? Weird.
                        Well each two wire pair will be approx 3.5V x 32 LEDs = 112V DC
                        You can start with a low current limit, and ramp up. Remember LEDs are current driven devices, not voltage driven. So always use a current limiting power supply, or a current limit resistor in series.
                        I wouldn't exceed 50mA total.
                        Not sure on the layout, that is odd. Possibly left & right strips, and one top strip? Weird...
                        • paulstef
                          • Dec 2013
                          • 724
                          Even at 127V there is no current at all through them. Maybe they are all in series...
                          EDIT:
                          When forcing the LED driver chips ON the voltage established at the caps ranges from 194 to 184V AND the backlight turns on.
                          Needed is only :
                          Shorting PS_ON to BU5v
                          Shorting STB to BU5V
                          then
                          Shorting PWM1 to BU5V.
                          PWM2 and DIMMER are not used.
                          Still unclear how to clear the counter in the mainboard without having access to the service menu.....
                            OK I don't have any experience with the LED-backlit Sharp sets but I've had the CCFL ones with lamp failures. On those sets holding the buttons on the side of the set (VOL- and INPUT I think) would bring the TV into "K" mode where it can be adjusted. This would turn BL on even if counter has reached max failures. VOL- and CH- would then enter service menu where counter could be reset.
                            • paulstef
                              • Dec 2013
                              • 724
                              Turns out the backlight has the same problem as other Sharp TVs, I've seen a thread somewere here, lower left edge is barely lit...
                              In adjustment process mode the picture is there ... Awesome :-/
                              • paulstef
                                • Dec 2013
                                • 724
                                Now, did anyone ever succeed in opening such a huge panel and repairing the LED strips?
                                I think it maybe best to remove all the screws that hold the panel together then holding the parts together with tape, flip the whole thing around so it lies on the front and then I could lift up the inner metal plate that holds the LEDs...
                                Will need to try it.
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  That is how I would do it... I do that to even 42" sets just to make sure no abnormal pressures are applied to the LCD. Still a 70" is going to be so fragile vs the weight of the LCD itself and I would not like to be attempting it myself! If I do get one I am going to get those glass suction cups and create a stand with them mounted.... Lock them to the screen then remove the rear panel.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    I do it this way except I use something smaller than the panel to support it (a large footstool) such that it's easier to work around the edges and when the metal bezel is free you simply lower it to the floor. Then you lift the lightbox off the panel.
                                    • paulstef
                                      • Dec 2013
                                      • 724
                                      I managed to open it without breaking the LCD. The backlight is 3 strips with 64 LEDs each all on the lower edge. Apparently it's 2x32 LEDs in parallel on each strip. One LED burnt, half of a strip is dead. Shorted the LED, it works again and voltage is lowered, i.e. current regulation of the driver chip seems to work.
                                      Putting it back together will be more difficult.
                                      • Ltank
                                        • Jun 2013
                                        • 776
                                        Sharp used to make repair kits for the 60 to 70" sets. I kept the pdf at shop but i cant get to it untill June 3rd. I will check to see if you found the instructins. it tells you how to take it apart. if you cant find it Iwill post it when i get back to shop. Its better than nothing
                                        • Mark R
                                          Marantz Model 150 Tuner "NULL" Adjustment..
                                          by Mark R
                                          I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                                          Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                                          12-30-2024, 03:18 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
