proscan PLDED3996A-C2 NO PICTURE POWERS ON
+ More Options
Posts
    Re: proscan PLDED3996A-C2 NO PICTURE POWERS ON
    Is that is? Just one board? Where is the "We also need you to upload good clear pictures of the whole back side of the TV showing ALL the boards"?
    • paulstef
      • Dec 2013
      • 724
      When it's NOT working do the following:
      Measure the voltage over the big black capacitor.
      Measure the voltage at the LED output connector (little white one to the left (2nd pic))
      If you have an oscilloscope take a screenshot of what happens at this connector when you try to start to the TV. If a LED is defective it may just give a very short pulse and then shut down.
      Post your findings/measurements here.
      • SamyBoyz
        • Oct 2016
        • 10
        I noticed when i bend back and forth the board near the 110v in, Tv works fine...i redid the solder even popped it in the oven for 10min like we do in I.T. with laptop motherboards and still same issue, bend the board near the 110v in and it works, bend it some more and it doesn't..
        • SamyBoyz
          • Oct 2016
          • 10
          Tv turns on fine sometimes...and it works flawlessly but other times it does not turn on at all, I don't have an oscilloscope unfortunately, i'm wondering if it could be bad caps that work intermittently?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            From your last two posts it definitely looks like a poor solder joint if flexing the board makes it work/not work. Get the magnifier out and resolder all joints once more. Look for a crack in the tracks.
            • SamyBoyz
              • Oct 2016
              • 10
              I redid most of the solders and even put the board in the oven..yet no luck none of the capacitors look bad, and the coils seem ok as well...weird
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                transformer wire issue where its soldered to the legs that go through the pcb? the part you cant see unless you desolder the transformer.
                • SamyBoyz
                  • Oct 2016
                  • 10
                  Ok good, i will have a look!
                  How about the 470 capacitor in the picture (on the upper right side near the wires), does it look ok to you? Thx
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    hard too say in the pictures but does look slightly domed can you remove and test if you have a esr meter also the multi strand wire connector lvds just in front of that capacitor is that fitted right? on all the pins the picture may just be deceiving
                    • SamyBoyz
                      • Oct 2016
                      • 10
                      I believe the problem was the 2 capacitors, i changed them and tv started working more regularly but looks like i de-soldered the old caps without the right tools so now the little spots where i am to solder the capacitor's legs are damaged it seems, i attached 2 pictures of the crappy soldering job i did, was wondering if there was a way to repair
                      • SamyBoyz
                        • Oct 2016
                        • 10
                        Would you by any chance be able to tell me what might cause the red light not to go on anymore? Up until i changed the capacitors the red light would go on but the tv was intermittent, now it just doesn't light up anymore..
                        • SamyBoyz
                          • Oct 2016
                          • 10
                          Anyone?
                          • heavymachines
                            • Mar 2011
                            • 1028
                            if u want help take pic of entire tv set and also try to salvage that board u did soldiering on. What iron you using? Try to clean it with rubbing alcohol and see how bad the damage is. doesn't look so good.
                            Being a multilayered mainboard it is crucial delicate soldiering. Need to see up close and clean to see how bad the pads &Thru-hole is. Since you don't have led anymore it is clear there is either no connection or it is grounded out by nearby tracks and or pads. it will need to be reworked. Make sure you use flux and a good iron with clean tin tipped iron very important, and if you're transferring too much heat to pads you will destroy pads, so no long lingering time on contact let it cool little bit.
                            • Dragonfire78
                              • Jun 2021
                              So i got a proscan PLDED3996A doing same thing turn on black screen. But shine a light and can see the picture im no tec and no idea wth im doing lol but. Found this from was told could be back led lights bad then read could be power supply then read could be bad led video driver board one the hdmi plug into and stuff im lost what check
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                #35
                                Draginfire78
                                Read through the post by RJ which you should find helpful.
                                https://www.badcaps.net/forum/showthread.php?t=45707
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  Every RCA/Proscan/Element/Haier I looked at that turned on with no backlight or flash of backlights had bad backlights. https://techhometravel.com/lg-ln-ser...ed-backlights/
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • ermals
                                    Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                    by ermals
                                    Hi all!
                                    I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                    1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                    2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                    3. I've checked voltages...
                                    08-01-2022, 10:35 AM
                                  • jb_Bak
                                    by jb_Bak
                                    CN6401
                                    Pin 01 NC
                                    Pin 02 NC
                                    Pin 03 "BL_ON": 0V
                                    Pin 04 "N/C"
                                    Pin 05 "STBY 3.3V": 3.5V
                                    Pin 06 "GND": N/C
                                    Pin 07 "AC_OFF"...
                                    09-27-2021, 04:52 PM
                                  • lostone
                                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                    by lostone
                                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                    05-19-2024, 11:40 AM
