I turn this on and the led goes from red to blue as in powering on but no picture. Im thinking main board?
proscan PLDED3996A-C2 NO PICTURE POWERS ON
Tags: None
Re: proscan PLDED3996A-C2 NO PICTURE POWERS ON
Can you completely remove the back of the TV and take straight shot pictures of the whole back side of the TV, the power supply/LED driver board (both sides of the board).
That power supply/LED driver board looks familiar.
I would say bad LEDs like this one:
https://www.badcaps.net/forum/showthread.php?t=45652Last edited by budm; 04-16-2015, 09:25 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I tested them red wires on the connector. They all read 20.7 volts. I think them wires are going to the leds? And shouldnt they read 24volts? Also i took picture of this diode. The board looks really brown burned up right under them 2 big diodes, the picture doesnt show it so good but it looks more burnt then shown in picture. But im thinking if them 20 volts is correct then i proly has bad led lights
Did you check both diodes yet? They are connected in parallel.
The 20.7VDC readings on the red wires are ref to the chassis GND, right?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
Yes bud the readings are done as you said, and also not sure what diodes connected in parallel mean but they both read 252 and checked them other way they say 1Comment
If they are in parallel they are supposed to share current equally between them. At least they don't look shorted . If you want to be absolutely sure, lift one terminal and measure again.Comment
I just repaired a proscan PLDED3273A-E, that has a different power board but the circuit may be similar. The voltage from the power supply for the led circuit was around 25-30 volts off the diodes, it then goes through the coil and is boosted to around 70 volts, I suspect that boost circuit is not working, if it is the coil should be getting quite warm. if its not getting warm check the boost circuit.
This video has a circuit diagram which may be usefull https://www.youtube.com/watch?v=GrfSmtzFjCcLast edited by R_J; 04-20-2015, 09:52 AM.Comment
: I have a PROSCAN PLDED3996A-C2 S/N A1305095130002210. I have sound and no picture. I can see the menu when I shine a flashlight on the screen. I cannot determine what part I need to replace, but its either the power board or LED controller board. I don't believe I have an inverter for the LED or its built into the main board. What part do I need? Model No TH390LK01-ACW1
Cell V390HJ1-P02
T201304032Comment
you need to remove the screen and test the leds to find which is badComment
both of you are from Cincinnati? I am from canton area. I have led strips for this model available. what you need to do is test each led with your meter on diode mode. scrap the paint off on each side of the led and test each one they will light up if good just a little from the power on your meter. if they don't light up then its no good, if you need help message meComment
Just for data - I am taking one of these tv's to recycling today because of this same problem. The picture just vanished one day though the sound was good and everything else seemed to be working fine (channels would change/ we could turn it on and off). When I found it was possibly a "video inverter" and that this could be diagnosed by looking for the faintest hint of picture on the screen, I could in fact see a hint of movement when I looked at a severe angle. I took the thing apart after watching a YouTube tutorial that showed how simple it was to pop out an old video inverter and pop in a new one thinking that of course I could order a card and do THAT. Not so simple.
As I said, I'm dropping one of these off to the recycling place today. I wasn't ever even able to find out where the crummy "video inverter" was!Comment
What Voltages did you check out so far?
We also need you to upload good clear pictures of the whole back side of the TV showing ALL the boards and then the pictures of the power supply board top and bottom side.Never stop learning
It's been about 20 years i graduated from electronics school but unfortunately i never worked in the field, went straight to I.T.
I tested the 2 diodes which are in parallel and the 110v input from the connectors on the PCB..I wiggle the PCB back and forth while off and the tv works, i wiggle it back some more and it stops..would be indicator of bad solder, but i redid most of them..
I can post pictures of the power supply back and front but nothing seems darkened or unusualComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by ermalsHi all!
I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
3. I've checked voltages... -
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
Channel: Troubleshooting Computer Displays
- Loading...
- No more items.
