panasonic tx-p50s10b
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Hi All
    After following instructions on flow chart Kindly supplied by TW2005 no relays clicking disconnected plugs as instructed and checked volts at pins on plugs p7 and a6 it advices to replace P board.
    What i was wandering was there any known faults on this board that may now have been discovered or do you have to replace these boards still ?
    Ronhayes
    [/ATTACH][/ATTACH]
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: panasonic tx-p50s10b
    Ive had the Va/Vs switching MOSFETS fail S/C taking out the fuse....
    TELEFIX
    • ronhayes
      TV Engineer
      • Mar 2014
      • 458
      I have checked the fuses on the P board all seem ok.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Only thing to do is the usual fault-find process--just like any other PSU. Check Tom's site for schematics of set.....
        TELEFIX
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Hi Alastair E
          In your last response to me you said to check Tom's site for schematics of set. Do you mean Tom 66 and if so do you have link to his site ? And also should i contact him first before going to his site? and ask for his permission to visit his site.
          Regards Ron
          • vinceroger69
            • Mar 2012
            • 6714
            http://www.toms-service-manuals.com/
            • ronhayes
              TV Engineer
              • Mar 2014
              • 458
              Thank you vinceroger69.
                No permission required
                If all fuses are good & relays not clicking, check 5V standby.
                If absent = concentrate on PSU.
                If not absent = check A board signals, could be bad A board not sending power on signal, etc.
                • ronhayes
                  TV Engineer
                  • Mar 2014
                  • 458
                  Hi Tom
                  Thank you for your input .
                  I have checked the 5v stby on pin 5 of p7 on p board and i get 4.73 at switch on so should i assume that the fault is with the A board?
                  Ron
                    It would be the place I would concentrate on, though 4.73V is quite low for a 5V rail...
                    • paulstef
                      • Dec 2013
                      • 724
                      Originally posted by ronhayes
                      Hi Tom
                      Ron
                      Please post a photograph of the the area with the two connectors to the right. There should be a description of each pin printed on top or bottom of the PCB.
                      Is this your chassis? http://elektrotanya.com/panasonic_tc.../download.html
                      • paulstef
                        • Dec 2013
                        • 724
                        In my previous post there is a link to document containing the schematic of the PSU as well. You can't have it any better than that. It's supposed to be the ETX2MM747MFG.
                        Can you confirm?
                        I attached two pictures of the connectors where you should measure the signals.
                        Measure all the signals on P7 and P25 while the set is in standby and while you try to turn it on. It's important to post any changes that the signals show, like first it's 0V, then after 2sec it's 5V etc.
                        • ronhayes
                          TV Engineer
                          • Mar 2014
                          • 458
                          Hi Paul
                          Yes on the P board it is marked ETX2MM747MF and large letter G on white label just at the end of board number.
                          I have added pictures as you asked but no description on boards as you can see.
                          • ronhayes
                            TV Engineer
                            • Mar 2014
                            • 458
                            Hi Paulstef
                            I see what you are advising but when the P board is connected it is not possible to take measurements from these points as the solder point is under the board ( I would need to solder extension pins on so i could measure in situ) would that be the way you would go?
                            or take the measurements on the A board as it is possible on that board but would have to track each wire to each pin ?
                            Also in the schematics it quotes to A6 and A25 but on my A board the plugs are marked up A7 and A25 but i assume A7 is A6?
                            • paulstef
                              • Dec 2013
                              • 724
                              You should be able to measure directly on the connector from above, where the wire was crimped to the terminal.
                              If your probe doesn't enter use an alligator clip with a rigid wire attached to it.
                              • ronhayes
                                TV Engineer
                                • Mar 2014
                                • 458
                                I have measured volts on connectors P 7 and P 25 volts as follows:-
                                P 7 = PINS 1,2,3,4,6,7,10,11= 0V STBY press button wait 2 seconds or more still 0v pin 5 STBY 0v press button 4.73v pin 8 0v STBY press button 2.84v for one second then 0v pin 9 STBY 0v press button 4.70v.
                                P 25 = pins 1,2,3,4,5,6,7,8,10,11,12,13 =0V STBY press button wait 2 seconds still 0v pin 9 = 0v STBY press button 4.73v
                                • ronhayes
                                  TV Engineer
                                  • Mar 2014
                                  • 458
                                  Would this point to the A board or the P board ?
                                  • paulstef
                                    • Dec 2013
                                    • 724
                                    There are only two input signals from the mainboard, P7/pin6 (F_STBY_ON) and P25/pin11 (PANEL_Main_ON).
                                    The microcontroller obviously runs since the standby on button works, presumably connected to P34, right?
                                    It enables then STBY5V on P25/pin9 and P7/pin5. The mainboard is then supposed to send PANEL_Main_ON and F_STBY_ON, which it doesn't.
                                    It looks more like a A-board fault but I would still verify if the 5V standby voltage (or VDD at pin6 of IC701) is really supposed to be 4.73V.
                                    For this you need to tell us the values of R556 and R555 next to IC551. This determines the output voltage.
                                    If you have a scope measure also voltage ripple at this point.
                                    If the P-board is ok you would probably be able to start it manually disconnecting P25 and P7 from the A-board and manually activating PANEL_Main_ON and F_STBY_ON.
                                    I need to check in which sequence that's supposed to happen.
                                    • paulstef
                                      • Dec 2013
                                      • 724
                                      Does the power LED blink or is it always off?
                                        I still think the 4.73V needs investigation - it is too low for a 5V rail, and could potentially trigger some kind of under-voltage lock-out (unlikely, but worth considering)
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
                                        • Mnawar27
                                          Panasonic CF-H2AU24EF3 bios locked
                                          by Mnawar27
                                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                          I need help to remove it,
                                          thankyou all.
                                          SN; 2FKCA26876...
                                          11-16-2024, 08:00 AM
