panasonic tx-p50s10b
  • paulstef
    • Dec 2013
    • 724
    Re: panasonic tx-p50s10b
    You would now need to follow the +3.3V trace in the schematic and check component by component and pray it isn't the big MCU.
    Alternatively you could use a thermal imager if you happen to have one lying around.
    Other than that it will become cumbersome from now on.
    You may also check small ceramic (the brownish) capacitors connected to the 3.3V for any discoloration, this may indicate they are cracked (and shorted).
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
