Panasonic Toughbook CF-33 mk1 BIOS repair
  • aa10aa10
    • Sep 2024
    • 6
    • Lithuania
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer.
    Now i have 3 ".bin" files (attached):
    1) original BIOS read from Windows using Afuwin before corruption (only BIOS area)
    2) BIOS read from Windows using Afuwin after corruption (FF'ed part of BIOS area)
    3) dump read from the chip itself using EZP2010 programmer (whole chip, but corrupted)
    BIOS areas in these files are not the same: difference is not only in Afuwin FF'ed area, but also some other places have slight differences (I don't know why - maybe Afuwin also edited this, maybe chip was read with errors, maybe ater unsuccessful POSTing there are made some changes in BIOS). I have tried to combine useful file using these files in many different variations without any luck - no post.
    I tried to write the chip using clip without desoldering. Verification passes.
    I thought that EZP2010 couldn't write these chips correctly, ordered and tried with CH341A - still no luck.
    I have also read BIOS chip from another similar Panasonic CF-33 and flashed it to the bricked machine also without any luck - bricked machine doesn't post.
    Maybe someone could have a look what i am doing wrong?​
  • aa10aa10
    • Sep 2024
    • 6
    • Lithuania
    Maybe somebody have an idea what else could I try? Should I clear ME?
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • eukal
      Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
      by eukal
      Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
      I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
      I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
      I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
      07-01-2023, 01:00 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
      by Vesko356
      08-11-2023, 03:27 AM
