Acoustic Solutions TV - Stuck on Standby
  • claudyu07
    Claudyu07
    • May 2014
    • 164
    • Ireland
    Re: Acoustic Solutions TV - Stuck on Standby
    Originally posted by ReeceyBurger123
    And you check the smd diodes behind the part you replaced, forgot to mention they are on the underside of the board right next to the leads of the part you replaced.
    d867 , d862 d806, d880 ok. all diodes from the vecinity of that mosfet
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ok 1 min let me take some photos.
      • claudyu07
        Claudyu07
        • May 2014
        • 164
        • Ireland
        i want to ad that SPDIF is flashind every 1 second . just noticed that now . think has something to do with that clicking that i hear every second from power board
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok here is one I repaired same issue as you significant voltage drop, the same Ic that you replaced was bad along with a small diode and resistor also the two capacitors 100uf 25v and 33uf 50v, and the little 8 pin controller was also bad and causing the same issue check all of them to rule them out.
          Photos showing the areas and parts I replaced, also check the diode right next to the heatsink as that can cause this issue as well, let us know if anything tests bad.
          Check:
          C856
          D867
          C801
          C892
          IC806
          • CapLeaker
            Leaking Member
            • 7976
            Those measurements you took... are these with the main board connected? Try to unhook the main board from the PSU and force the PSU on and recheck those measurements. Maybe the main board is dragging the PSU down?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              I think he still has faulty parts on the psu tbh he needs to check all of them toughly.
              • claudyu07
                Claudyu07
                • May 2014
                • 164
                • Ireland
                #27
                i took those measurements with the board only connected to power. Any idea how to force the PSU ?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Its quite hard to find the pin out different for each model just find the 5vstb then short that to ground using a 100-500 ohm resistor, have you checked the parts I said ?
                  • claudyu07
                    Claudyu07
                    • May 2014
                    • 164
                    • Ireland
                    #29
                    C856
                    D867
                    C801
                    C892
                    All ok .
                    IC806 have no idea how to test it . will google it now for datasheet
                    • qussy101
                      • Mar 2015
                      • 13
                      • palestine
                      #30
                      i have the same problem here ..
                      check the CN117 Pins on MainBoard ( 18,20,22) , check 3.3v shorted to ground in Main Board
                      • claudyu07
                        Claudyu07
                        • May 2014
                        • 164
                        • Ireland
                        #31
                        I force powered the board. All voltages according to schematic are ok except Pin27 - +30v
                        In this pin i only get 24V
                        • claudyu07
                          Claudyu07
                          • May 2014
                          • 164
                          • Ireland
                          #32
                          have you schematic?
                          • qussy101
                            • Mar 2015
                            • 13
                            • palestine
                            #33
                            have you schematic?
                            i'm working on it ..
                            i hv the same issue .. when i Run the Power Board alone ( 17pw26-4 )
                            the output voltages seems to be fine .. all working fine , but when i connect the main board i hear a clinking noise and the out voltages flip flops like (12v >~ 4.2v ) and 24v drops to 15v .. i tried everything
                            • claudyu07
                              Claudyu07
                              • May 2014
                              • 164
                              • Ireland
                              #34
                              you are right. i have disconnected pins 18,20,22 from CN117 , clicking stopped and voltages don't drop anymore
                              I don't have schematic for Main board to investigate further more.
                              • qussy101
                                • Mar 2015
                                • 13
                                • palestine
                                #35
                                17mb35-1 schematic download link here ..
                                i'm working on it .. let's us investigate together
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #36
                                  http://www.toms-service-manuals.com/...&Search=Submit
                                    That will be correct since the power supply board will no longer receives the STBY (PS-ON) signal from the main board when the connector is not in place.
                                    So the problem is some where on the power supply board.
                                    I will need to look at the diagram to see how it works first.
                                    What happen if you have everything connected back together but without having the cable (24V) to the inverter board connected, do you get steady 24V?
                                    I also want the pictures of the whole back side of the TV to see how all the boards are connected together.
                                    • qussy101
                                      • Mar 2015
                                      • 13
                                      • palestine
                                      #38
                                      ok.. but there's a short to gnd with pins (18,20,22) on mainboard without PSUB connected .. nd the 24v is stable with inverter connected ,but not with main board .
                                        So you are saying the 3.3V OUTPUT from the power supply board feeding pin 18, 20, 22 (3.3V input pins) on the main board is shorted to GND?
                                        • qussy101
                                          • Mar 2015
                                          • 13
                                          • palestine
                                          #40
                                          YEs
                                          Pin 18,20,22 (3.3v input pins ) on the main board is shorted to GND >> Yes
                                          the power supply is fine
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
                                          • Ukdigger
                                            Samsung UE46f5000AK Stuck on Standby
                                            by Ukdigger
                                            When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                            PSU number bn44-00610A L46SF_dpn
                                            1 B13v 12.4
                                            3 B13v 12.4
                                            5 Vamp 12.4
                                            7 Vamp 12.4
                                            9 GND...
                                            08-08-2024, 09:17 AM
