TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
  • lepak06
    • Feb 2017
    • 51
    • france
    Hello
    I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
    The TV is faulty with stuck in Standby RED LED. Can't power the TV.
    Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
    All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
    But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power Button . Same problem
    When i remove the the Flash Ic, the voltage on power button is 3.3V .
    The CPU is normaly heating
    I didn't understand this problem. Is the CPU faulty ?
    Here schematics and original dump. Do you have any ideas
  • lotas
    • Jan 2016
    • 4805
    • Russia
    Re: TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
    Try and replace the spi flash with a new one.
    • lepak06
      • Feb 2017
      • 51
      • france
      I already tried to use an other spi flash ic
      Because the original GD25Q64 , i can't erase it with CH341a. I used an MX25L64 from an laptop motherboard
      • lotas
        • Jan 2016
        • 4805
        • Russia
        This MX25L64 may not start your motherboard, you need to find the original GD25Q64 or Winbond W25Q64 (with DUAL/QUAD SPI & QPI support)
        And you can’t erase your own, since it’s more likely to be protected from erasure (status register).
        • lepak06
          • Feb 2017
          • 51
          • france
          Ok, GD25q64 i don't have but i'll try to find Winbond W25Q64
          For the protection i tried use NeoProgrammer for unprotect but didn't work
          • lepak06
            • Feb 2017
            • 51
            • france
            I succeeddd to unprotect write the GD25Q64. Now write and erase work
            I tried you fix dump , and other dumps , All tries didn't work there is same problem.
            When i remove Flash chip, there is 3.3V on keypad ( Power Button) . When the flash chip is solder on mainboard the voltage is 0.6V on keypad .
            • lotas
              • Jan 2016
              • 4805
              • Russia
              What voltage (how many volts) do you have on 8 pin. with GD25Q64 installed and removed?
              • ekozeko333
                by ekozeko333
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
              • praveenramavath
                Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                by praveenramavath
                Hello All,
                I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                https://www.hifivision.com/threads/m...-screen.98243/
                Troubleshooting Summary: Majority Internet Radio - Flash Chip
                04-26-2025, 09:08 AM
              • toty79
                Hisense LTDN50K220WSEU stuck in standby
                by toty79
                Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                As per Hisense tv title LTDN50K220WSEU stuck in standby
                PSU rsag.820.5687 HLL 4855WF
                Main rsag 7.820.5842
                I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                05-01-2022, 04:39 PM
              • lego1234567
                LG 32LB1R - stuck in standby mode
                by lego1234567
                Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                What could be the problem ? Thanks...
                01-21-2024, 03:39 AM
              • Stunt
                Hp Laptop Stuck on Hp protected by hp sure start screen
                by Stunt
                Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                screen that's it and stuck there. I left it until the following day and i still...
                09-02-2025, 01:51 PM
