Acoustic Solutions TV - Stuck on Standby
  • claudyu07
    Claudyu07
    • May 2014
    • 164
    • Ireland
    hi guys. this is my first time when i try to touch tv for fix.
    i have experience with laptop / pc / xbox / ps3 but today my tv got broken and i want to try to fix it .
    Model number : LCD26761HDF
    As title describe the problem , is stuck on stand by.
    When i have opened , no visible broken capacitors or bleeding capacitors.
    I have tested PL816 for output and i got the following :
    ST_BY 2.1V
    +12V_1 - 3.5V
    +5v STBY - ok
    +3.3V STBY - ok
    +24v - 16v
    +12v - 4v
    +33v - 15v
    +3.3v - ok
    +5v - 2.1V
    +24V A - 16V
    +30V - 16V
    I would like to mention is also a clicking Noise every 1 second.
    PL802 connector to inverter i get aswell 16V insted of 24.
    When Motherboard is disconnected from power, clicking noise it's gone and all points that i have remarked few rows up are showing me proper voltages , only +30V show 24V
    Any help will be appreciated .
    POWER BOARD : 17PW26-1
    MOTHERBOARD : 17MB35-1
    Re: Acoustic Solutions TV - Stuck on Standby
    Please start with this:
    https://www.badcaps.net/forum/showthread.php?t=39740
      • 30928
      unplug the power from the mainboard and meter resistance between each of those voltage-points and ground.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Ugh--VESTEL VOMIT!
        Check all the diodes on that '26.x PSU on the output side....
        TELEFIX
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Common fault with these boards is the diode that generates the 24v fails its labled d893 check that first.
          • CapLeaker
            Leaking Member
            • 7982
            Unplug everything on the PSU and force it on. Measure everything again.
            Here is a schematic for the PSU cording to SJ it should have.
            • claudyu07
              Claudyu07
              • May 2014
              • 164
              • Ireland
              Thank you all for your answers.
              first i will post pictures as budm suggested.
              second I have tryed to locate D893 but it's not on board and according to schematics from CapLeaker (Thanks) and it's not on schematics aswell.
              I will try force power on the board and make readings Again and then test resistance to ground from all those pins though i don't know what i should get.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Sorry my bad, its different on the different models, its labled diode d881 check that.
                • CapLeaker
                  Leaking Member
                  • 7982
                  I couldn't find that D893 yesterday either.
                  Good idea to disconnect everything and forcing the PSU on. Seems like most of the voltages you measured are low. Maybe you want to check the battery in your DMM.
                  • claudyu07
                    Claudyu07
                    • May 2014
                    • 164
                    • Ireland
                    will do now. just doing research how to do it. i have to bridge +5V STBY with PS ON from what i saw on different threads but it's not any PS ON on my board.
                    I will remove now D881 and test it
                    Battery on DMM is grand .
                      If it's not D881, then Q844, on the primary, will sometimes fail leaky. When this fails, the output voltages will bounce around. In my case it had about 300 ohms between collector, emitter and base.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Its d881 my notes were for the 17pw26-4 that I think its labelled different, if not check the primary transistors they sometimes fail and cause messed up voltages.
                        • claudyu07
                          Claudyu07
                          • May 2014
                          • 164
                          • Ireland
                          d881 ok. 400 reading on my dmm. wil check now q844 and primary transistors
                          Q844 is gone. will find replacement and post back if fixed. Thanks you
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Good to hear, hopefully bring that tv back to life also I would advise you replace the gluxon brand capacitors as they probably will fail shortly and bring the set down again.
                            When I get home I will take a photo of a 17pw26-4 I recapped.
                            • claudyu07
                              Claudyu07
                              • May 2014
                              • 164
                              • Ireland
                              Q844 replaced . still same problem.
                              Test the board again for output voltages on PL816 and all voltages are correct except pin 27 which supposed to be 30V but is only 24V
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Have you checked the diode behind it ?
                                • CapLeaker
                                  Leaking Member
                                  • 7982
                                  what about R1017? D881 and the caps after that?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Can you take some close up photos of the psu, the parts you replaced.
                                    • claudyu07
                                      Claudyu07
                                      • May 2014
                                      • 164
                                      • Ireland
                                      d881 OK . R1007 looks like missing???
                                      Capacitors after D881 ok
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        And you check the smd diodes behind the part you replaced, forgot to mention they are on the underside of the board right next to the leads of the part you replaced.
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • toty79
                                          Hisense LTDN50K220WSEU stuck in standby
                                          by toty79
                                          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                          As per Hisense tv title LTDN50K220WSEU stuck in standby
                                          PSU rsag.820.5687 HLL 4855WF
                                          Main rsag 7.820.5842
                                          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                          05-01-2022, 04:39 PM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
                                        • Ukdigger
                                          Samsung UE46f5000AK Stuck on Standby
                                          by Ukdigger
                                          When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                          PSU number bn44-00610A L46SF_dpn
                                          1 B13v 12.4
                                          3 B13v 12.4
                                          5 Vamp 12.4
                                          7 Vamp 12.4
                                          9 GND...
                                          08-08-2024, 09:17 AM
